Does Spektrum offer a 2.4Ghz Module solution for a Futaba 9C?
Tower Hobbies
Logged in as Guest
  Printable Version
JR R2000, JRPR2000 10CH RX, and JR Synth TX Module
Seller:  Erick Royer
Details:   $400.00   |  9/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Does Spektrum offer a 2.4Ghz Module solution for a Futaba 9C?
Page: [1]
Login
Does Spektrum offer a 2.4Ghz Module solution for a Futa... - 7/16/2008 5:10:07 PM
3D Romeo
Status: offline
Hi,
I was wondering if Spektrum offers a 2.4Ghz module solution for a Futaba 9C radio, that can be quickly swapped in and out with the existing 72Mhz module?
The reason I ask is because I'd like to use the new technology on a large scale project that I'm working on, but I'd also like to keep using all my 72Mhz receivers, too. So I was wondering if Spektrum makes a module with an integrated antenna, that can be swapped out in seconds, so I can fly 2.4Ghz, or 72Mhz, without much fuss.
I know there are other brands that offer what I'm looking for, but I'm already committed to Spektrum. So my only concern is whether Spektrum makes a module that will do what I'm looking for.
Thank You,
Mark
_____________________________
See I told you I was a good Pilot...Doh!...Never mind...
       Post #: 1
RE: Does Spektrum offer a 2.4Ghz Module solution for a... - 7/16/2008 5:53:01 PM
BarracudaHockey
Status: offline
Yep. Since the radio has to be in ppm mode to interface with the module you only get 8 channels, thats the only limitation.
http://www.spektrumrc.com/Products/Default.aspx?ProdID=SPMMSFUT7
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
(in reply to 3D Romeo)
       Post #: 2
RE: Does Spektrum offer a 2.4Ghz Module solution for a... - 7/16/2008 6:18:13 PM
3D Romeo
Status: offline
Thanks for the reply Andy!
I was looking at that module just yesterday, but it looks like you have to replace the existing 9C antenna with the Spektrum antenna for it to work? Is this a quick change-over? Because I'm looking for a solution that I can do in seconds, between flights at the flying field.
Almost all my planes are still on 72Mhz, but I'd like the new plane to be on 2.4Ghz. So I need to be able to switch over from one to the other quickly, and easily, at the field.
I was originally hoping to just put the new plane on my 6ch Spektrum, but by the time I mix in the 2 aileron and 2 elevator servos, it leaves me with no mixing functions left. I also love the feature on the 9C where you can program your timer to start with the throttle. The Spektrum only allows you to assign it to a switch, and I NEVER remember to flip the switch before each flight!
Mark
(in reply to BarracudaHockey)
       Post #: 3
RE: Does Spektrum offer a 2.4Ghz Module solution for a... - 7/16/2008 8:11:40 PM
rhd-RCU
Status: offline
All you have to do is unscrew the original ant. and insert there dummy ant. Then snap the 2.4 ant. to it. Swap out the modules and atach the cable. Probably a couple of minutes work.
rd
       Post #: 4
RE: Does Spektrum offer a 2.4Ghz Module solution for a... - 7/16/2008 8:31:51 PM
3D Romeo
Status: offline
Thanks for the reply rd!
I just downloaded the Spektrum Module Manual a few minutes before your reply, and like you said, it looks like a real easy change-over!
Mark
(in reply to rhd-RCU)
       Post #: 5
RE: Does Spektrum offer a 2.4Ghz Module solution for a... - 7/16/2008 8:35:17 PM
GBR2
Status: offline
I think changing the 9C antenna out is more work than simply unscrewing it, if I remember correctly. In any case you could just get a 2.2db antenna and just screw it to the connection on the module. I did that with my JR XP9303 as I thought the wire from the module was hokey and an accident waiting to happen. Haven't had any problems with that setup. Ideally it would have been better if Spektrum had made the antenna connection near the top of the module and pointing up so the antenna could be screwed to it and sit between the handle and the transmitter, similar to what XPS did.
       Post #: 6
RE: Does Spektrum offer a 2.4Ghz Module solution for a... - 7/16/2008 8:52:00 PM
3D Romeo
Status: offline
GBR2...Do you have any photos of your antenna setup you can post?
(in reply to GBR2)
       Post #: 8
RE: Does Spektrum offer a 2.4Ghz Module solution for a... - 7/16/2008 9:27:37 PM
exeter_acres
Status: offline
there is also the direct drop in from FUtaba
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRTT6&P=0
I would like to earn your vote for IMAC Southeast Regional Director
       Post #: 9
RE: Does Spektrum offer a 2.4Ghz Module solution for a... - 7/16/2008 10:10:40 PM
3D Romeo
Status: offline
exeter_acres...That would have been the best solution. But as you can see by my first post, I'm already committed to Spektrum.
Mark
(in reply to exeter_acres)
       Post #: 10
RE: Does Spektrum offer a 2.4Ghz Module solution for a... - 7/19/2008 7:52:49 PM
Dan767
Status: offline
Have you seen this thread?
http://www.rcuniverse.com/forum/m_6476841/tm.htm
Dan
www.ctf.org www.caringbridge.org/visit/ashleyv Isaiah 40:31
       Post #: 11
RE: Does Spektrum offer a 2.4Ghz Module solution for a... - 7/20/2008 12:33:23 AM
3D Romeo
Status: offline
Thanks for the link Dan!
My friend told me about a thread where somebody described how to internally mount the Spektrum system in a 9C, but I never was able to find it. Looks easy enough, and much better than the external cable. Unfortunately, right now I'm looking for a solution that will allow me to switch back and forth between 72Mhz, and 2.4Ghz, quickly at the flying field. I may end up doing the internal conversion some day if they end up banning 72Mhz in the future. But for now, I got way to many planes on 72Mhz to switch them all over.
Mark
(in reply to Dan767)
       Post #: 12
RE: Does Spektrum offer a 2.4Ghz Module solution for a... - 7/20/2008 12:57:17 AM
iflyj3
Status: offline
quote:
ORIGINAL: GBR2
Not true. The 9C antenna simply unscrews from the top of the xmitter. Drop in the Spektrum plastic subsitute and snap in the Spektrum module and go fly.
Dan Thompson (Long live the ACE MicroPro 8000)
Visit www.groups.yahoo.com/group/mp8k for support
(in reply to GBR2)
       Post #: 13
RE: Does Spektrum offer a 2.4Ghz Module solution for a... - 7/20/2008 2:00:19 AM
exeter_acres
Status: offline
quote:
ORIGINAL: 3D Romeo
Mark
may I ask why you are "committed" to a different brand solution?
       Post #: 14
RE: Does Spektrum offer a 2.4Ghz Module solution for a... - 7/20/2008 3:01:14 AM
3D Romeo
Status: offline
Because I already own 7 Spektrum receivers that I got for my Spektrum DX6i, and I'd like to be able to use them with my 9C, as well. No use buying more VERY expensive Futaba receivers, when I can just use the Spektrum receivers I already own.
Mark
