Rcpilot
Joined: 3/20/2002 From: Arvada, CO, USA Status: offline
I did it once but I can't remember how long my header was. Seams like I ended up cutting off about 1.5" or 2" It was HOWLING with a 22-10 prop. I ended up deciding on a 23-10 that was turning around 7100RPM. It's been a long time though, and I ain't getting any younger. Can't remember the brand of prop. It was a Macs header and pipe. I had the setup on a test stand. The intention was to mount it on an 85" Extra, but I didn't want to cut up the plane to put the pipe on the outside and properly support it. All I had was a 90* header. At the time, I had no idea a DA 50 header would bolt up. Had I known that, I'd have ordered K&S parts to make my own drop header and ran the pipe right down the bottom of the fuse, like everybody does nowadays. I was extremely impressed with how the engine responded to the pipe. I had done a handful of glow engines on pipes over the years but never managed to get one that wasn't "peaky" It was no big deal to get a glow engine tuned to run nicely at WFO. The problem was they had very little throttlability at idle and mid range. It was like having an ON/OFF switch on my throttle. The G62 was not like that at all. It had smooth power from idle to WFO. No mid range burbling or thumping idle. It was like a Swiss watch on steroids!!!!! I actually picked up between 800 - 1200 RPM, depending on which prop I tried. I'm anal and I had lots of time on my hands at the time. I'd put a prop on it and tach it. Then a different prop. Then another one. I'd record all the RPMs on the different props and then cut 1/4" off the header. Slap all the props on again and write it all down. Cut off 1/4" and do it again. Unfortunately, the notebook was ruined in a flood when I lived in Pueblo, CO. We had a 500yr storm roll through and the basement window wells filled up with water until the windows actually exploded and filled the basement. I had knee-deep water in the basement. That notebook was never found. I'm jealous. Wish I had the time and money to do it again right now. Other priorities.
_____________________________
Airplanes have expiration dates. It''s just not printed anywhere on them. I''m not really an airplane pilot; but I did stay at a Holiday Inn Express last night.
