screwy idle
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> screwy idle
Page: [1]
Login
screwy idle - 7/17/2008 3:44:21 AM
rclugnut10
Status: online
i'm havein' idle trouble with my savage and low end as well but i tuned that problem out of it, its idleing really high and doens't like to be richened 1/8 of a turn, it cuts, and wont start (roto to) unless i lean it a bit, and then it ildes really bad up and down and misses everynow and then, any help
i geuss i should tell you what i'm running,
k4.6
trinity monster HP, 20%,
os #8 plug,
stock shoes and springs,
its alwasy idled high but not this bad
thanks
and last i checked my clutch was fine (just read the post from tomanytoys,)
opps double posted my bad sorry
the lug
< Message edited by rclugnut10 -- 7/17/2008 3:45:32 AM >
_____________________________
HPI SAVAGE X SS
DTX EVADER PRO + SIDEWINDER 4600
       Post #: 1
RE: screwy idle - 7/17/2008 3:46:52 AM
Baxy
Status: offline
pull off your air filter and see how far the slide is open
dirt in carb
carb loose
start from scratch turn your mixture screw all the way in and back it out 2 1/2 to 3 turns that will get you in the ball park
(in reply to rclugnut10)
       Post #: 2
RE: screwy idle - 7/17/2008 3:49:30 AM
twomanytoys
Status: offline
How much run time do you have on teh k4.6. The k4.6 is super easy to tune. The springs also loose its memmory effect and get weak. Have you tuned the high speed needle first? How did you check your low speed to see if it was right? Also using a hot plug will make it start and idle so much easier.
J et A ssisted T ake O ff
       Post #: 3
RE: screwy idle - 7/17/2008 4:06:02 AM
rclugnut10
Status: online
okay thanks i'll try that, i probally got a gallon and half - 2 gallons not so sure, my high speed was great, fenominal, in fact once it stopped bogging it would take off and be gone, then i even fixed the boggin problem,
i puched it to test my tune i basically would start it at my feet give it about 1/2 throttle grab some break cut a turn then WOT and let it go abit the lots o breaks spin around puch it and bring it back and ajust, then again, i had it pretty good and the idle had started to settle a bit but, i took it to the track later and it was back again then i stripped the servo horn, on lap # 3
btw i was looking at hot plugs and tower says the # 8 is a med hot just throwin' that out thier
the lug
< Message edited by rclugnut10 -- 7/17/2008 4:09:36 AM >
HPI SAVAGE X SS
(in reply to twomanytoys)
       Post #: 4
RE: screwy idle - 7/17/2008 4:30:34 AM
twomanytoys
Status: offline
Well your low speed test is not really that effective. What you need to do is get truck up to operating temps. Make a few wide open runs. Bring truck back and do the pinch test. Once you get the truck back pinch the fuel line about 1" from the carb. The truck should stall within about 3-4 seconds. When this happens the idle will raise slightly then die within the 3-4 seconds. If the idle raises high then dies for longer than 3-4 seconds then you are too rich. If it dies immediately you are too lean. You have to do this on a hot truck and right after a wide open run. Thats the best way to get your low speed set but only once your high speed is set.
       Post #: 5
RE: screwy idle - 7/17/2008 4:32:03 AM
rclugnut10
Status: online
okay thanks i'll try that tommorow
the lug
HPI SAVAGE X SS
       Post #: 6
RE: screwy idle - 7/17/2008 4:44:32 AM
twomanytoys
Status: offline
Also once you get your low speed set you can readjust your idle screw. You want it high enough to not turn the wheels but low enough to not stall. I prefer having a slightly higher idle.
       Post #: 7
RE: screwy idle - 7/17/2008 4:50:39 AM
rclugnut10
Status: online
thanks again i've tried a few tuning methods but never the pinch i've had to pull my feul lines, cuz i fogot my quick stop and i was a nimrod and fired it up with both rx and tx off... it did idle for the right time but that was the winter and it ran great then
the lug
HPI SAVAGE X SS
       Post #: 8
RE: screwy idle - 7/17/2008 5:00:22 AM
twomanytoys
Status: offline
Anytime you need to kill the engine you can pinch the fuel line or plug the exhaust. Either way it will stall adn it wont hurt the engine. Pinching the line works the best and quickest.
       Post #: 9
RE: screwy idle - 7/17/2008 5:08:37 AM
rclugnut10
Status: online
i accually have found the exaust plug with this http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFRN7&P=7 very easy, but the plug is a good way to cuz then you don't need to burn anything off, which i often forget to do,
the lug
HPI SAVAGE X SS
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU1
