25cc Weed Eater Featherlite Blower Conversion
Tower Hobbies
Logged in as Guest
  Printable Version
O.S. Engines O.S. BGX-1 3500 w/ BCM #4224 Pitt
Seller:  jmhernan
Details:   $200.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> 25cc Weed Eater Featherlite Blower Conversion
Page: [1]
Login
25cc Weed Eater Featherlite Blower Conversion - 7/17/2008 12:36:17 PM
plasticmaster
Status: offline
I converted a 25cc Weedeater Featherlite Blower engine and test ran it. I did the bare minimum to get it converted. Basically, I put a spacer on the shaft so I could mount a prop and that's it. I ran it with the original carb and muffler and with the original flywheel and coil ignition. With a Master Airscrew 16x8 prop, I got 6600 rpm. I then removed the muffler (very loud) and got 7300 rpm. I know I can put a larger carb on it for more power. Is there any way to open up the muffler to remove the contents? It appears to be sealed together really well. Are these numbers reasonable? What have others gotten with this engine?
       Post #: 1
RE: 25cc Weed Eater Featherlite Blower Conversion - 7/17/2008 9:43:10 PM
microsprint9
Status: offline
Have you read thru this thread http://www.rcuniverse.com/forum/m_2480581/tm.htm
(in reply to plasticmaster)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU1
