Replace the pin on DL50 piston possible?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Replace the pin on DL50 piston possible?
Page: [1]
Login
Replace the pin on DL50 piston possible? - 7/17/2008 2:50:30 PM
nonstoprc
Status: offline
I am in the process of getting a new ring in in my DL50 and found the pin is too short to prevent the ring from rotate. See the pictures attched.
My question is whether a longer pin can be put back. What is the method?
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 1
RE: Replace the pin on DL50 piston possible? - 7/17/2008 3:29:49 PM
skillet92
Status: offline
The pin is to short even when the ring is on and compressed in the cylinder?
(in reply to nonstoprc)
       Post #: 2
RE: Replace the pin on DL50 piston possible? - 7/17/2008 4:22:59 PM
Bob Pastorello
Status: offline
quote:
ORIGINAL: nonstoprc
Those are compression pins which have a gap that expands when they are driven in. If there is enough meat to grab onto, simply compress the pin, and retract it. Replace with a longer one, but "uncompressed" diameter is what will be important to keep the new one in there.
Call Bob and DL USA, see if he has any in stock.
While you have the piston out, I'd go ahead and clean up all the flow ports, too.
_____________________________
Bob Pastorello www.rcaerobats.net
Learn from others...you can't live long enough to make all the mistakes yourself....
       Post #: 3
RE: Replace the pin on DL50 piston possible? - 7/17/2008 4:50:06 PM
Truckracer
Status: offline
quote:
ORIGINAL: Bob Pastorello
quote:
ORIGINAL: nonstoprc
I wouldn't mess with replacing the pin, just replace the piston. They don't cost that much.
(in reply to Bob Pastorello)
       Post #: 4
RE: Replace the pin on DL50 piston possible? - 7/24/2008 3:43:30 AM
nonstoprc
Status: offline
Talked to Bob at DLUSA and he did not carry the pin.
Ordered the piston and the ring and have them installed. Compression comes back right away. Nice!
(in reply to Truckracer)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
