borealis
I haven't assembled mine yet, so no pictures, sorry. As far as I have understood from the parts I have, the left stick activates the recoil motor and the integrated muzzle flash. The microswitch located inside the transmitter is operated by the left stick itself, when its pushed forward,and it closes the 'K' contacts, in order to add the tank 'boom' sound + full tank recoil. This way, when you push the left stick you have: muzzle flash, barrel recoil, cannon sound, tank recoil all together. If this recoil unit is integrated with the DBC, you can have: muzzle flash, barrel recoil, custom cannon sound, IR beam (+optional tank recoil, if not disabled) all together. The only matter is that since the recoil motor is not disabled by the DBC, you could shoot a 2nd shot just after the first, but it would be limited to the muzzle flash and barrel recoil (since the sound and IR beam whould be disabled until the reloading time has elapsed). If the recoil unit muzzle flash is disconnected and changed with the DBC one, at least you won't have the muzzle flash during the reloading time. I wonder if putting a NO relay with coil connected somewhere on the DBC could stop the barrel recoil too during reload time. What about that Blitz?
< Message edited by borealis -- 7/19/2008 10:42:05 AM >
