G26 prop stud removal
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> G26 prop stud removal
Page: [1]
Login
G26 prop stud removal - 7/17/2008 7:39:29 PM
GBR2
Status: offline
Can the prop stud be unscrewed from the engine without removing the prop hub?? Other question about the prop stud, are the threads going into the engine threaded normally, in orther words, to unscrew you turn the stud counter clockwise (when viewed from front) or are the threads reversed such that turning it counter clockwise for instance, it would actually tighten rather than loosen it? Lastly, what is the easiest way to unthread the stud - grab the non-threaded portion with pliers or such? Thanks.
       Post #: 1
RE: G26 prop stud removal - 7/17/2008 8:10:14 PM
Antique
Status: offline
Take the spark plug out...Put some rope in the cylinder..Grab the stud with Vise Grip pliers...Normal thread, CCW to unscrew...Heat the hub with a propane torch, tap it sideways with a hammer handle...
Reverse to install...Easy on the tightening, the stud is only 6mm on the end and has been known to break off flush with the end of the crank...
(in reply to GBR2)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.189RCU1
