pooka2hot4u
Joined: 6/12/2007 From: Brooklyn, NY, USA Status: offline
quote:
ORIGINAL: jbrcflyer 2 -The rest is a request, in plain english, of the purpose / features of the Transmitter........in this order: > Trans mitter battery LEDs: only red and yellow light up, no matter what batteries I put in....so I will assume, I'm lucky I got that?? > GYRO switch: Appears "normal" position is forward....away from you?...is this correct? And, what happens when you switch is back....towards you? > Idel Switch:Forward = normal, back = What? Hov Pit knob on top - left: "0" normal.....turn left or right?? What does it do? Hov Pit knob on top - right: "0" normal.....turn left or right??....what does it do? I have downloaded the ESky transmitter manual (which in MY opinion should have been a seperate manual in the box) and am translating as I type. ok....that is nuf for now http://www.rcgroups.com/forums/showthread.php?p=5863143&highlight=+gyro+sw+#post5863143 Had the same question, here's where I learned. IDLE UP N/1: Basically lets you fly upside down and all that fun stuff. Set it to "N" ( where it should be if you're just learning) and applying more throttle increases the blade's pitch and the rotor speed. Set it to "1" and the rotor speed remains pretty much the same and you just change the blade pitch. This mode allows you to give the blades a negative pitch, letting you do things like inverted flight and autorotation. ^TRN: I guess you have to turn this on when using a simulator. If I try to flick it toward me when not with a sim, it just flicks back once I let go, so not like you get a choice. I don't have a sim so can't tell you much about this switch. HOV. PIT: Uuumm.....refer the link above, although after reading it, I'm still not sure about this. Moving the knob does seem to change my blade's pitch. I just have it set to - for now, haven't played around with it in flight yet, waiting on a motor. PIT. TRIM: Same as above. GYRO. SW: As the link quotes from the manual, this one doesn't apply to this heli. I tried it in both positions, doesn't seem to make a difference either way. So I just leave it up. I hope you know what the two sticks are, seeing as you fly giant nitro planes POWER: Gives you super-human powers, ON ALL THE WAY!!!! j/k The servo reversers let you reverse the controls of the sticks. I have them all set down to normal except the ELE which is set to reverse. Also I get just yellow and red lights on my Tx too, though the greens shine a bit on new batteries, I guess they have to be completely off for you to start worrying. BTW is it just me or does the Gyro seem to work better when set to reverse? In normal, it makes me rotate either right or left depending how much throttle I apply, I would have to continually work agains it with the stick. In reverse, it's alot more stable, the heli just turned to one side, so I tweaked the servo and trimmers. Now I just have to fix my heli gliding to the left all the time even with full trim against it. Also what exactly does the Gyro's gain trimmer do?
