Prop saver centering Question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> Prop saver centering Question
Page: [1]
Login
Prop saver centering Question - 7/17/2008 10:03:06 PM
darticus
Status: offline
How do you keep a prop centered on the prop saver if the prop saver is too small for the hole in the prop and it tends to wobble?
_____________________________
Thanks for your help Guys, FORGEDABOUTIT! Ron
       Post #: 1
RE: Prop saver centering Question - 7/18/2008 12:54:37 AM
Matt Kirsch
Status: offline
Does the prop saver have a wider hub on the back side?
Besides that, if your prop didn't come with bushings (like APC electric props do) the only other option is a different prop or a different prop saver.
(in reply to darticus)
       Post #: 2
RE: Prop saver centering Question - 7/18/2008 1:07:36 AM
darticus
Status: offline
The other side of the prop saver has a v shaped hub but the prop could tilt on it. Ron
(in reply to Matt Kirsch)
       Post #: 3
RE: Prop saver centering Question - 7/18/2008 3:55:33 PM
whitecrest
Status: offline
My prop savers are a little small for the GWS props I am using. I use the deep "V" side and find that the prop self-centers with no vibration if the O-rings used to secure the prop are not too tight. I loosen up stiff O-rings by flexing with some needle-nose pliers. I have found the prop savers to be very effective.
Some things that count can''t be counted, and some things that can be counted don''t count. << A.E.
       Post #: 4
RE: Prop saver centering Question - 7/18/2008 8:49:57 PM
Sir Raleigh
Status: offline
I use the cone-shaped side of my prop saver with my GWS props, the ones with the nut cutout on each side of the hub. They fit and center just fine.
Bill
(in reply to whitecrest)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
