Thunder Tiger ST-1 suspension plate problem
Tower Hobbies
Logged in as Guest
  Printable Version
Team Losi Muggy - RTR
Seller:  PastorVee
Details:   $1,100.00   |  10/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> Thunder Tiger ST-1 suspension plate problem
Page: [1]
Login
Thunder Tiger ST-1 suspension plate problem - 7/18/2008 12:33:17 AM
mxracer183
Status: offline
Hello guys,
After a big crash I broke the suspension plate (rtr one) and the hinge pin. So I upgraded to the red 7075 one and it broke too on the first tank! with a small crash...and the hinge pin bent...
Does someone else have the same problem?
       Post #: 1
RE: Thunder Tiger ST-1 suspension plate problem - 7/18/2008 12:53:36 AM
Chedzter
Status: offline
You should check over the entire truck and make sure nothing is lose which weakens the plate. Also try not to land awkward or you will break stuff. Everytime I have breakage on my st-1 I have had a bad landing. Good luck
(in reply to mxracer183)
       Post #: 2
RE: Thunder Tiger ST-1 suspension plate problem - 7/18/2008 1:07:40 AM
ericem
Status: offline
How did you manage that?? Check the screws on the bottom, make sure there all snug. Stock one seems impossible to break let alone.
(in reply to Chedzter)
       Post #: 3
RE: Thunder Tiger ST-1 suspension plate problem - 7/18/2008 2:22:22 PM
mxracer183
Status: offline
everything seem fine...
so even the stock one suppose to hold up great?
I wiil probably buy the stock it lasted a lot longer than the other one
(in reply to ericem)
       Post #: 4
RE: Thunder Tiger ST-1 suspension plate problem - 7/18/2008 11:42:49 PM
twomanytoys
Status: offline
Everything stock on the st1 is super solid. If you broke it then you must have hit something really hard. These are as tough as it gets.
_____________________________
J et A ssisted T ake O ff
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
