T-maxx wants to go only in reverse
Tower Hobbies
Logged in as Guest
  Printable Version
FS Racing Monster Truck 4WD 1/5 Scale Blue - RTR
Seller:  pmwtrading
Details:   $755.00   |  8/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> T-maxx wants to go only in reverse
Page: [1] 2   next >   >>
Login
T-maxx wants to go only in reverse - 7/18/2008 2:07:48 AM
bud_senior150
Status: offline
Hi i finally got the max started, i did away with that blue wire an now use my sons ignitor. It works really great. Anyway me and my son got the truck to idle really good and got a good amount out of the pipe. But when we tapped the gas it wanted to run backwards and not forward, why is that. I flipped the switch on the controller and it didnt make a difference. personally i dont even know if it was in reverse or forward to begin with when we started it. So can someone help me figure it out? Also is it better to run the dual pipes or the single stock? thanks mark
       Post #: 1
RE: T-maxx wants to go only in reverse - 7/18/2008 2:09:59 AM
t-maxxmaniac
Status: online
What model t-maxx is it? 3.3? 2.5? 2.5r?
(in reply to bud_senior150)
       Post #: 2
RE: T-maxx wants to go only in reverse - 7/18/2008 2:10:53 AM
carlbellybutton10
Status: offline
the reverse servo is probably burnt out. did you buy it used?
       Post #: 3
RE: T-maxx wants to go only in reverse - 7/18/2008 2:11:31 AM
bud_senior150
Status: offline
yes i bought it used. Its the 2.5
(in reply to carlbellybutton10)
       Post #: 4
RE: T-maxx wants to go only in reverse - 7/18/2008 2:13:29 AM
t-maxxmaniac
Status: online
well sometimes i have 2 have the breaks on when shifting.....is the pin on the left side of the tranny in or out?
       Post #: 5
RE: T-maxx wants to go only in reverse - 7/18/2008 2:17:01 AM
bud_senior150
Status: offline
um can you post a pic of that pin im a little confused. When i pushed the switch up and down the servo moves, im new to the maxx, my son drives truggy so were both new
(in reply to t-maxxmaniac)
       Post #: 6
RE: T-maxx wants to go only in reverse - 7/18/2008 2:21:26 AM
t-maxxmaniac
Status: online
sry my sister has the camera an shes not home....you say you see the servo moveing...and the little bar/servo arm conected to that is to....in the past i have had trouble with the servo moveing but sliping off the arm
       Post #: 7
RE: T-maxx wants to go only in reverse - 7/18/2008 2:57:30 AM
bud_senior150
Status: offline
yes i see it moving ill try holding the brake, but when u get the camera from ur sis can u post a pic. thanks
       Post #: 8
RE: T-maxx wants to go only in reverse - 7/18/2008 3:05:45 AM
matts6887
Status: offline
Well, first off, does the forward/reverse micro servo still work at all? If it does, then try shifting from reverse to forward by flipping the switch several times; if that does not do anything, then it sounds like it could possibly be time to open up the trans case and have a look inside to see what migfht be possibly going wrong here....
_____________________________
"If U havent broken anything....U arent driving it hard enough"
       Post #: 9
RE: T-maxx wants to go only in reverse - 7/18/2008 3:08:23 AM
bud_senior150
Status: offline
yep every time i flip the switch it goes back and forth. im going to try it agian tommorow
(in reply to matts6887)
       Post #: 10
RE: T-maxx wants to go only in reverse - 7/18/2008 3:13:53 AM
t-maxxmaniac
Status: online
mine got stuck once....the servo pulled out the rod 2 far
       Post #: 11
RE: T-maxx wants to go only in reverse - 7/18/2008 3:15:53 AM
EpoweredRC
Status: offline
while were on this subject is there a way to lock out reverse and not hav the 3rd channel?
I just got a t maxx and found out the tx is crap and only have a 2 channel radio to use with it, will get a 3 if have to but rather not.
Mini Edge 540,BP Edge 540 profle ,MST, E rustler ,With DX2.0. /GF"S-Blade CX,Slow stick. A123 Batts all the way! 5 glow
       Post #: 12
RE: T-maxx wants to go only in reverse - 7/18/2008 3:16:23 AM
bob5429
Status: offline
try moving the pin by hand with the truck off, or take the horn off of the servo and move it in and out. sometimes the clutch can hang making it difficult to move.
       Post #: 13
RE: T-maxx wants to go only in reverse - 7/18/2008 3:20:45 AM
DaveG55
Status: offline
that transmission is rpm sensitive when shifting from forward to reverse
the internals of the transmission have to be completely stopped (or very nearly so) before it will shift
if the idle speed is high enough to cause the forward/reverse pawls to expand then the tranny will not shift
i suggest trying to shift from reverse to forward with the engine off, then start the engine to see if it changed gears
since you're unsure which way the controler is set you may have to try this twice nd/or by hand to see it it shifts
if you can make it shift like that then the idle is too high
if you cannot make it shift that way then a foray into the tranny may indeed be in order
Any technology, sufficiently advanced, will appear as magic
       Post #: 14
RE: T-maxx wants to go only in reverse - 7/18/2008 3:21:48 AM
matts6887
Status: offline
the bob above is right on what he said.....also....it is possible that there is something that is causing the shift fork to "hang" up in between gears, which might mean u have to open the trans case up to have a look inside like i mentioned above....
(in reply to bob5429)
       Post #: 15
