So I drag raced my Go Tech 7 port tonight...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> So I drag raced my Go Tech 7 port tonight...
Page: [1]
Login
So I drag raced my Go Tech 7 port tonight... - 7/18/2008 2:52:05 AM
Furadi
Status: offline
Against my buddy that runs an RC8 with a Dynamite .21xp. We raced in the parking lot at our track about the length of a football field. We got 1 good run WOT and I pulled him pretty much the whole way. Even launched harder but there different buggys so thats not really comparable.
As far as details go, Were both using Byrons 25%. I'm using 11% oil he's using 9%. He has a 7.5mm venturi I have an 8. Temps were both around 210-220. I also had wheel spin in the beginning due to bald tires.
Anyway, just thought some people would like a direct comparison to another engine.
       Post #: 1
RE: So I drag raced my Go Tech 7 port tonight... - 7/18/2008 2:00:23 PM
Dawman
Status: offline
Not much of a "direct comparison " . Different buggies , different tune , different drivers , different oil %s , and so on .
(in reply to Furadi)
       Post #: 2
RE: So I drag raced my Go Tech 7 port tonight... - 7/18/2008 4:05:35 PM
vnmsgt
Status: offline
Yes but like some guys always say my mustang is faster than your camaro and vice versa. Not a direct comparison but the winner always says he won. I am glad that GO kept up and probably beat it. You won and thats what counts regardless of who had what. 2nd place is the first loser!
_____________________________
CASTER RACING K8T, ZX-1R, Fusion EX-1
HOLESHOTHOBBIES, GO TECH, AVID BEARINGS, Don''t jump on the bandwagon...CRUSH IT
(in reply to Dawman)
       Post #: 3
RE: So I drag raced my Go Tech 7 port tonight... - 7/18/2008 6:05:55 PM
Furadi
Status: offline
quote:
ORIGINAL: Dawman
What does that have to do with anything? Its pretty much just mash the throttle and try to keep it straight. As far as the different oil %, I think that shows that I should have been at a disadvantage.
       Post #: 4
RE: So I drag raced my Go Tech 7 port tonight... - 7/18/2008 7:25:43 PM
911
Status: offline
What about your 8mm restrictor to his 7.5mm??
Read my post twice before replying cause you might not get my sarcasm the first time around...
       Post #: 5
RE: So I drag raced my Go Tech 7 port tonight... - 7/18/2008 7:27:32 PM
Furadi
Status: offline
quote:
ORIGINAL: 911
/shrug, How much difference would it make?
(in reply to 911)
       Post #: 6
RE: So I drag raced my Go Tech 7 port tonight... - 7/18/2008 7:39:17 PM
Nathan9492
Status: offline
.5mm difference
       Post #: 7
RE: So I drag raced my Go Tech 7 port tonight... - 7/18/2008 7:40:31 PM
911
Status: offline
I don't know, how much of a difference does a 2% "difference" in oil content make??
       Post #: 8
RE: So I drag raced my Go Tech 7 port tonight... - 7/19/2008 1:09:23 AM
mabuecker
Status: offline
sounds like fun ... your 7port had it from the start hands down !
l o s i 8 roller rossi 21-jp3 z9100ts losi alum & 8t roller werks 28-dynamite053 z9100ts khz alum
(in reply to 911)
       Post #: 9
RE: So I drag raced my Go Tech 7 port tonight... - 7/19/2008 4:33:20 AM
Hyper7driver
Status: offline
Set up, not just engine alone, is just as important in drag racing as off-road racing. Clutch shoes, pipe, fuel type and percentages, traction, drive train resistance, overall weight, reciprocating weight, on and on, along with an engine that can deliver the power. But you obviously had the better over all set up, good job!
But beware, the Dynamite .21-XP makes good power too. So if your friend starts working on his buggy, like changing clutch type or springs, different pipe, or whatever, you may have to work to defend your title.
(in reply to mabuecker)
       Post #: 10
RE: So I drag raced my Go Tech 7 port tonight... - 7/19/2008 4:38:31 AM
Furadi
Status: offline
quote:
ORIGINAL: Hyper7driver
It was a one time deal, I think... Just wanted to compare. But yea, the Xp impressed me for as much as I don't know about it.
(in reply to Hyper7driver)
       Post #: 11
RE: So I drag raced my Go Tech 7 port tonight... - 7/19/2008 5:26:06 AM
Nik.
Status: offline
quote:
ORIGINAL: Furadi
quote:
ORIGINAL: Dawman
To you peg the throttle "to go faster" or do you roll it?
Team Smiley
Just remember, if the world didn''t suck, we''d all fall off.
       Post #: 12
RE: So I drag raced my Go Tech 7 port tonight... - 7/19/2008 5:40:15 AM
Furadi
Status: offline
quote:
ORIGINAL: Nik.
quote:
ORIGINAL: Furadi
quote:
ORIGINAL: Dawman
In what instance? In a parking lot with 99% traction? I stab it. On the track? It all depends on what the buggy is doing... I start by cracking the throttle open, if it hooks up I usually stab it and go. If it doesn't hook up right away then I'll roll on it. This largely depends on the track too. My home track is very loose so it requires a very smooth hand. But on a high bite track I can just pin it most of the time and let the Losi do what it does.
(in reply to Nik.)
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
