Jett Muffler - Performance Decrease With Deflector.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> Jett Muffler - Performance Decrease With Deflector.
Page: [1]
Login
Jett Muffler - Performance Decrease With Deflector. - 7/18/2008 8:16:03 AM
PlaneHeli
Status: offline
I have purchased two Jett Red Tuned mufflers for my OS 46AX and OS 55AX engines.
I see silicone exhaust deflectors have been used with your mufflers.
What sort of power decrease (if any) could I expect to see using silicone exhaust deflectors.
I noticed you recommended an internal diameter larger than the exhaust outlet. I would fit one as you recommended.
Cheers
_____________________________
Useless Things...Runway behind you, Sky above you, Air in your Tanks, Engine Oil in the Hanger.
       Post #: 1
RE: Jett Muffler - Performance Decrease With Deflector. - 7/18/2008 5:55:43 PM
bob27s
Status: offline
No effect on power output or performance.
You want a tube that has an inside diameter that slips over the tail piece on the muffler. Then secure it with a thin zip tie. Try and keep the length to a minimum.... under 2.5" is a good target.
Typically the 40-90 size deflectors from Great Planes and Dubro work ok. You would want to avoid anything much longer than that.
Click to see fullsize image.
Click for fullsize
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to PlaneHeli)
       Post #: 2
RE: Jett Muffler - Performance Decrease With Deflector. - 7/19/2008 12:46:24 AM
PlaneHeli
Status: offline
Thanks bob27s.
Will do.
(in reply to bob27s)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.266RCU1
