t-maxx help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> t-maxx help Page: [1]
Login
t-maxx help - 7/18/2008 7:50:04 PM
bud_senior150
Status: offline
ok guys, i got the reverse problem fixed and got it fired up, but shut it off because it wanted to take off. We turned the needles all to stock setting but cant get it to fire, but it sounds like it wants to. It blows alot of fuel out of the duel pipes but the one seems like its a dummy. Because the one doesnt really blow fuel out like the other. Anyway when we did get it started there was alot of smoke out the pipe. But now we cant get it to fire. The ez start battery seems weak and last time we checked it was puttng out 6 somthing volts. But it started the motor after a full charge. Anyway here is a vid, pleasse help. im really stuck and frusterated so please help
http://www.youtube.com/watch?v=xcb2-aOF2uE
< Message edited by bud_senior150 -- 7/18/2008 7:52:06 PM >
       Post #: 1
RE: t-maxx help - 7/18/2008 8:01:19 PM
jayrguidaben
Status: offline
i think your problem is your battery on your wand or the motor of the ez start. and your engine is getting flooded
< Message edited by jayrguidaben -- 7/18/2008 8:04:10 PM >
(in reply to bud_senior150)
       Post #: 2
RE: t-maxx help - 7/18/2008 8:04:34 PM
bud_senior150
Status: offline
so take it all out and get a pull start? But it started it before
(in reply to jayrguidaben)
       Post #: 3
RE: t-maxx help - 7/18/2008 8:10:33 PM
nitro rc
Status: online
no, don't get pullstart, ez starts are good. it fires up my tmaxx everytime within 5 seconds. the battery in the glow ignitor is probably dead if you have been trying to start it for a long time now. Put in a new battery and it looks like it should fire right up. And while ur at it charge the ez start battery also.
_____________________________
Go FAST or Go Home
T-maxx 2.5
       Post #: 4
RE: t-maxx help - 7/18/2008 8:14:49 PM
bud_senior150
Status: offline
i really think the ezstart bettery is bad but it fired it up. My glow ignitor is good. Idk ill just try it tommorow
(in reply to nitro rc)
       Post #: 5
RE: t-maxx help - 7/18/2008 8:18:50 PM
jayrguidaben
Status: offline
mine does that before and sounds like that too. i borrowed 3 batteries and still no start same sound as yours. and the problem is the ez start motor. less than $10 for that motor. no need to change to pullstart its gonna be harder to start it.
       Post #: 6
RE: t-maxx help - 7/18/2008 8:34:39 PM
bud_senior150
Status: offline
so what i just buy a new motor? what did you do?
       Post #: 7
RE: t-maxx help - 7/18/2008 9:34:41 PM
nitro rc
Status: online
the ez start motor is perfectly fine that is wat it should sound like. It just isn't firing. Your glow plug is prolly dead from trying to start it for so long. change the plug for a new one then try. Also make sure the ignitor battery is good.
Go FAST or Go Home
T-maxx 2.5
       Post #: 8
RE: t-maxx help - 7/18/2008 10:43:11 PM
t-maxxmaniac
Status: offline
ez start motor is fine!! ...mabe check ur glow plug....i have never had 2 change mine more than 2 times in a year but sometimes people do, didnt sound like it had any fire at all and you say its getting fuel so it has to be ignition problems
       Post #: 9
RE: t-maxx help - 7/18/2008 10:48:45 PM
nitrorevo33
Status: offline
check glow plug
charge both batteries
is there feul to the carb
(in reply to t-maxxmaniac)
       Post #: 10
RE: t-maxx help - 7/19/2008 12:34:42 AM
nitro rc
Status: online
quote:
ORIGINAL: t-maxxmaniac
thanks for repeating exactly what i just said.
Go FAST or Go Home
T-maxx 2.5
       Post #: 11
RE: t-maxx help - 7/19/2008 12:42:45 AM
bud_senior150
Status: offline
yep but it blows fuel out the pipes alot idk wwe will see tommorow
       Post #: 12
RE: t-maxx help - 7/19/2008 12:54:56 AM
matts6887
Status: offline
Well for one thing, like some of the others may have mentioned already; if the batt. pack is only putting out 6 volts, u should check it because it should be putting out 7.2 at the minimum after a FULL charge. If that has been done and it still dont want to do nothing, then check ur plug and igniter....make sure the plug is good and the igniter has a full charge. Also, since u said it somehow managed to start with only a 6-volt pack, and it was spewing a lot of fuel out the pipe(s), then it definately sounds too rich. I would l lean out the high end needle 1/8-1/4 turn and go from there....
"If U havent broken anything....U arent driving it hard enough"
       Post #: 13
RE: t-maxx help - 7/19/2008 1:03:28 AM
bud_senior150
Status: offline
ok thanks
(in reply to matts6887)
       Post #: 14
RE: t-maxx help - 7/19/2008 1:31:34 AM
t-maxxmaniac
Status: offline
sry nitro i neglected to read urs somehow
       Post #: 15
