jaketrouble
VA, USA Status: offline
i had the same exact problem with mine.. after letting it set for a week or so i decided to drive it.. when i turned it on i heard a buzzing sound and the green light on the opti drive was blinking.. i knew it was working perfect when i last used it. so i read the book,,asked questions and looked it over. like you i took off the cover and saw nothing that i could see that was wrong. so i replaced the cover,,charged the battey and then it was fine.. maybe your batteries are weak???/ i use the hump pack and that is what i charged.. so what ever you are using either charge or replace and make sure nothing is binding against the opti drive case.. you should be alright..jake
