Electronic Questions: Gun Flash using Super bright Krypton Lamp (Mini Maglite)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> Electronic Questions: Gun Flash using Super bright Krypton Lamp (Mini Maglite)
Page: [1]
Login
Electronic Questions: Gun Flash using Super bright Kryp... - 7/19/2008 12:09:13 AM
caragan1970
Status: offline
Hi guys,
I bought this Mini Maglite Super Bright Krypton bulbs and was thinking of making
it a muzzle flash. The bulb uses 2-Cell AA source (1.5 x 2= 3.0 volts) supply, I was wondering would this work?
Where do you normally connect the the gun flash LED in an RX13 board? Where if there is EL-MOD Booster fitted?
How much voltage does a normal flash LED use? Where can I get 3.0 volts if I want to use this?
Do I need to series a resistor, if so how many ohms?
Wacky I know your expertise in this area, can you advice?
SORRY for asking too much..
Best regards,
Patrick C.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
1/16 HL Tiger 1, HL M26 Pershing, WSN T34/85, 1/24 VStank Pro M1A2 Airsoft, M1A2 Sparkling, Type 90, Leo2 A5, 1/12 Hailang M
       Post #: 1
RE: Electronic Questions: Gun Flash using Super bright ... - 7/19/2008 1:23:51 AM
ostketten
Status: offline
This is a cool idea, I'm intrigued by it.. Presumably your Mag light bulb is a typical "white spectrum" type of light like most flashlight bulbs are unless they have a colored lens over them, I wonder if they make these in a yellow or red version, they might make for a little more realistic looking "muzzle flash", but this is still a great idea in any case.
(in reply to caragan1970)
       Post #: 2
RE: Electronic Questions: Gun Flash using Super bright ... - 7/19/2008 5:23:26 AM
blitzkrieg65
Status: offline
A super Bright LED works great no resistors needed if you are going to EL MOD,, connection point below and all this info is in the manual!
See booster manual to follow the locations with the pictures. I am not sure what that lamp will get you, 10,000.00 lum Super Bright LED's are pretty bright!
ThinkTank TLS
1 EMNet-Connection (cable 1)
2 signal input
3 supply for turret unit
4 auxiliary light (ex. rear light) (cable 3)
5 optional muzzle flash
6 optional servo connection for horizontal main gun movement.
7 optional servo connection for vertical main gun movement.
L1 power LED
L2 command LED
Here are the connection points for the Heng Long board is you want to use that you can also,, but you need at least a 75 ohm resistor soldered to the positive side of your Super Bright LED!
The Blitz
Click for fullsize
< Message edited by blitzkrieg65 -- 7/19/2008 5:42:12 AM >
(in reply to ostketten)
       Post #: 3
RE: Electronic Questions: Gun Flash using Super bright ... - 7/19/2008 6:29:54 AM
swathdiver
Status: offline
Patrick,
The hokey HL recoil still works if you press the button with El Mod. With the 3-1 gearboxes its hardly noticeable. Is this the button you want to activate the gun firing? If so this is the picture I saved from a fellow forum member.
Click for fullsize
James -
You do have spare boards, don't you?
       Post #: 4
RE: Electronic Questions: Gun Flash using Super bright ... - 7/19/2008 7:30:20 AM
blitzkrieg65
Status: offline
James those points are very hard to solder too that is why on my board i have followed the trace out to easier / safer / stronger points to make the solder connections and it is the exact same trace!
The Blitz
(in reply to swathdiver)
       Post #: 5
RE: Electronic Questions: Gun Flash using Super bright ... - 7/19/2008 7:59:53 AM
swathdiver
Status: offline
Gotcha, but your picture is so small I'd need a magnifying glass to see it!
James -
(in reply to blitzkrieg65)
       Post #: 6
RE: Electronic Questions: Gun Flash using Super bright ... - 7/19/2008 9:52:28 AM
caragan1970
Status: offline
Hi guys,
Thanks, Blitz which color wires are those in your Picture, I can't tell. Is this points 5 volts?
Swath, I would like the flash to work when the gun is firing and recoil using Asiatam recoil unit,
similar to Tamiya's function.
About the HL jerky (track) recoil, you mean if I use the EL MOD Booster HL this function is still there?
How can't I get rid of it?
Keep tanking
Patrick C.
       Post #: 7
RE: Electronic Questions: Gun Flash using Super bright ... - 7/19/2008 11:43:08 AM
blitzkrieg65
Status: offline
Patrick, not sure of the voltage the resistior it to aviod the draw away from the sound card from producing its blast sound!
The cannon flash leads are the two coming up the center of the picture, one red and one black. The Red is positive and it should connect to the 3rd trace down on the left hand side of the sound card that is verticle in the center of the picture. The Black line is the negative should be on the same trace as the bottom 4 traces on the opposite side of the sound card as shown below. If you are making your own LED you need to add a 75-ohm resistor to the positive side of the LED lead! See easy soldering points below and I recommend you us a little super glue or sticky tape to make a strain relief for these wires to keep them from pulling off of the PC board, this is not shown in the picture below!
Click for fullsize
       Post #: 8
RE: Electronic Questions: Gun Flash using Super bright ... - 7/19/2008 3:25:18 PM
jakeand
Status: offline
quote:
ORIGINAL: caragan1970
Keep tanking
Patrick C.
Hi Patrick,
I use same setup (EL MOD Booster HL) in my PzIII and the jerky recoil is gone.
Regards
Jake
"Object on Ebay are closer than they appear" (Heavysled)
http://minipansar.ecommunity.se/
       Post #: 9
RE: Electronic Questions: Gun Flash using Super bright ... - 7/19/2008 4:29:22 PM
swathdiver
Status: offline
Haven't done the flash thing yet so I'll defer to Blitz. As for the recoil, when I press the cannon sound button on the TX the sprocket barely moves now but it does move. I attribute the lack of movement to the 3-1 gears soaking it up.
James -
       Post #: 10
RE: Electronic Questions: Gun Flash using Super bright ... - 7/19/2008 6:18:00 PM
jakeand
Status: offline
quote:
ORIGINAL: swathdiver
Hi Swath,
I find this strange, I have standard metal gears (Not Stug or 3:1) With HL electronics the jerking is present. With HL + Booster the jerking is gone, sounds remain.
Does the "mass inert simulation" prevent the jerking?
Blitz, could you fill us in on this?
Regards Jake
< Message edited by jakeand -- 7/19/2008 6:40:23 PM >
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
