BT-24A Installation questions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Fuji-Imvac Engines Support >> BT-24A Installation questions
Page: [1]
Login
BT-24A Installation questions - 7/19/2008 3:45:00 PM
steinhorst
Status: offline
Hello everyone,
I've recently bought a BT-24A (magneto version) to power my Rascal 110. It's my first gas engine and I have
some doubts about it's installation:
1) With the prop, washer and spinner backplate stacked together, there's only about 7mm left on the prop bolt to go into the prop hub. That's about 3 full turns of the bolt. Is that sufficient? I'm using a 16x8 APC prop and a 6mm spinner backplate.
2) I'm using allen bolts with 4 mm width and lock washers to bolt the engine to the firewall. Strong enough?
3) This engine has two round allen bolts to attach the prop hub to the fly wheel. Does it need washers? Because it didn't come with any, and looking at the pictures on fujis website it doesn't look like they've used it either. The thing is the user manual says you should use lock washers and flat washers with it. But then again the manual is a little confusing at times, for instance, referencing the EI module when this is a magneto engine.
Any help appreciated.
Eduardo
       Post #: 1
RE: BT-24A Installation questions - 7/22/2008 3:20:59 PM
Bax
Status: offline
1) Tighten the propeller well and you'll be OK.
2) 4mm bolts should be OK.
3) The two bolts do not use washers as they come from the factory.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to steinhorst)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU1
