Spur Gear Problems!!!!!
Tower Hobbies
Logged in as Guest
  Printable Version
FS Racing Touring Car 2WD 1/5 Scale BLUE - RTR
Seller:  pmwtrading
Details:   $699.00   |  8/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> Spur Gear Problems!!!!!
Page: [1]
Login
Spur Gear Problems!!!!! - 7/19/2008 3:52:23 PM
CarFreak92
Status: offline
hi guys i just replaced my spur gear on my t-maxx with the same stock part and on the first tank of fuel it has stripped again. This is the second time and I am really annoyed. my spur also seems to be wonky or off center. I made sure my gear mesh was adjusted properly but still the gear stripped. Also what should be the slipper nut adjustment because i did it 1/8th turn out from totally in. So can someone please help me out here.
Here's a link to show you how off center the spur gear is: http://www.youtube.com/watch?v=VzOnfayl2hU
_____________________________
T-MAXX 2.5 with 3.3, motorsaver airfilter, robinsons racing brake kit, traxxas wheelie bar and RPM skid/wear plates
       Post #: 1
RE: Spur Gear Problems!!!!! - 7/19/2008 4:30:20 PM
bigblock.21
Status: offline
How are the slipper pegs? Have you checked the bell clutch bearings? How about the metal spacer that the spur gear mounts on. Did your motor mount move? Are the motor mount screws still tight? And last but not least, and with all due respect, are you buying cheap spur gears or traxxas stock parts? There will be one common factor that is causing this, it'll take some time but we'll figure it out sooner or later.
< Message edited by bigblock.21 -- 7/19/2008 4:34:22 PM >
Once is coincidence, Twice is happenstance, Third time is enemy action. Quoted by Al Capone
(in reply to CarFreak92)
       Post #: 2
RE: Spur Gear Problems!!!!! - 7/19/2008 4:34:22 PM
matts6887
Status: offline
Sounds to me like ur gear mesh is not set properly, which is probably the most likely cause for stripping the spur gear(s). To set the mesh properly, try this which should solve ur problem: take a sheet of paper and slip it between the clutch bell and the spur gear, then line up the end of the clutch bell and push the engine toward the spur gear until the clutch bell lines up with spur; keep pushing it toward the spur and spin the cb with ur finger; it should spin freely with little play. The spur gear should also spin freely. Hope this helps out some..
"If U havent broken anything....U arent driving it hard enough"
       Post #: 3
RE: Spur Gear Problems!!!!! - 7/20/2008 1:08:25 AM
t-maxxmaniac
Status: offline
happens to my old 2.5 some times .... its ushualy motor mounts comeing loose and moveing because of its torque and slipper posts out of line
(in reply to matts6887)
       Post #: 4
RE: Spur Gear Problems!!!!! - 7/20/2008 8:28:55 PM
CarFreak92
Status: offline
yh i actually hit something just before it stripped so the engine mount mayhave come loose. and aslo the spu is off center as when i spin it connected to the clutch bell there is more friction on one part of the spur when i spin it. so its off centre and i need to correct that. how do i do it???
(in reply to t-maxxmaniac)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.672RCU1
