Lars from Norway
Joined: 6/30/2008 From: Norheimsund, NORWAY Status: offline
quote:
ORIGINAL: Wicked!! The connection from the on/off switch and the battery melted causing some major screw ups. Luckily for me the only thing that went was that servo. Batt, rx, and Th servo are fine. Not to sure what happen though. This happened to my FG too,the current that went through the wires and the on/off-switch was too strong and the wires too thin,causing the wires to melt and even melt through the wires to the servo and shortcut it.The servo got totally grilled,it smelled like giraffepoo Im not using any on/off-switch anymore,i.m.o. totally unnessesery as it is causing a weak link in the electric,and i never store the battery in the car either so i dont have the problem with draining the batteries.I have made a connector on the radiobox,i just plug the battery in there
< Message edited by Lars from Norway -- 7/20/2008 3:12:07 PM >
_____________________________
What seems to be the officer,problem? Got all under cnotrol!
