RE: Flyeagle F18F    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Flyeagle F18F
Page: <<   < prev  61 62 63 64 65 66 67 68 [69] 70   next >   >>
Login
RE: Flyeagle F18F - 8/1/2011 10:34 AM
olmaugeard
Score: 100
Last Login: 12/5/2012
Status: offline
Just for fun, attached the F18 1/7  (P200) and big F16 ( P200) and F14 (2xP160) all from Fly Eagle Jet. Photo taken on juni 31th during the Jetmeeting  of AMBERIEU EN BUGEY ( FRANCE)
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to olnico)
       Post #: 1701
RE: Flyeagle F18F - 8/2/2011 2:02 AM
Wap4life
Score: 110
Last Login: 5/22/2013
Status: offline
olmaugeard
Just add the mig 29 and that's going to be my line up of jets
I love this thread, i read it twice.  I want 1/6 f18.
_____________________________
Wap
Hide Signatures
(in reply to olmaugeard)
       Post #: 1702
RE: Flyeagle F18F - 8/2/2011 11:45 AM
David Jackson
Score: 111
Status: offline
quote:
ORIGINAL: olmaugeard
I have a 1/7 scale F-18 from Fly Eagle that most recently was posted in the RCU Market Place for sale. After reading a few entries to this post and seeing more flight videos of this plane, I am beginning to lean more toward assembling the plane for personal use. Just curious, did you use the pipe that came with the kit? Also, was it necessary to modify the engine area to install the P-200.
Hide Signatures
       Post #: 1703
RE: Flyeagle F18F - 8/2/2011 12:55 PM
olmaugeard
Score: 100
Status: offline
I heard  that there was problem with the pipe  of origin FEJ, I thus ordered other unje at US TAMJET. In the balance sheet  almost the same mass +( 60g ) but especially a better quality and thus a better return. It is important considering the loss of power with the  Y pipe . For the installation of P200 I moved it at most (see the photo) and I modified the wooden supports for better one . For the electronics of the engine (ECU, etc.) I installed   the all component  near  the engine by removing one small tank.
Click for fullsize
Hide Signatures
(in reply to David Jackson)
       Post #: 1704
RE: Flyeagle F18F - 8/3/2011 11:37 AM
olmaugeard
Score: 100
Status: offline
David,
to help you, here some pictures  about the new engine bay design , the  by-pass with  based ceramic coating inside  (" Heat Shield + "  from BVM) .
Click for fullsize
Hide Signatures
       Post #: 1705
RE: Flyeagle F18F - 8/3/2011 11:59 PM
David Jackson
Score: 111
Status: offline
Thanks for the photos.
Hide Signatures
       Post #: 1706
RE: Flyeagle F18F - 8/17/2011 5:56 PM
Timo44
Score: 100
Last Login: 9/4/2012
Status: offline
a short clip of my third season flight no. 40 with the FA18 F - all stock -
push the P200 to the limit
the bird still handles perfect.
Best regards
Hide Signatures
       Post #: 1707
RE: Flyeagle F18F - 9/30/2011 12:23 AM
heliman48
Score: 100
Status: offline
Timo Hi
I am ready to fly my 18 which is the same size and scheme as yours , would you be so kind to put your control settings & the Cof G for your A/C on the forum , I would like to see what you are using compared to what I have set mine too .
Cheer's Nate
Hide Signatures
(in reply to Timo44)
       Post #: 1708
RE: Flyeagle F18F - 11/16/2011 8:03 PM
FELIrc
Score: 100
Last Login: 4/26/2013
Status: offline
Any updates on the new airframe or landing gear? What is the new weight of the honeycomb airframe?
Hide Signatures
(in reply to heliman48)
       Post #: 1709
RE: Flyeagle F18F - 4/7/2012 10:25 PM
Timo44
Score: 100
Status: offline
See my converted Behotec C50-F with Lado's electric actuators.
I decided to convert the originally pneumatic system at my 2009 - FA18 F Fly Eagle Jet, with the electric one.
All the three legs are running at 2s Lipo (separate power supply) due to the heavy legs.
At 7,4 V the drive has no issue with the heavy weight of the legs.
Still using the pneumatic system for the gear-doors.
Sequence between gear up and closing doors is about 14 seconds - regulated by a jettronics doorsequencer.
Best regards
Hide Signatures
(in reply to FELIrc)
       Post #: 1710
RE: Flyeagle F18F - 4/13/2012 12:23 AM
Wap4life
Score: 110
Status: offline
hey timo any flight video?
Wap
Hide Signatures
       Post #: 1711
RE: Flyeagle F18F - 4/30/2012 12:56 PM
bidrseed2
Score: 100
Status: offline
Would someone be old enough to measure the width of the model with the stabs attached?
Secondly the length from the tailcones up to where the fuselage splits in half.
I need to decide if it would fit in my car.
Thanks in advance.
Hide Signatures
(in reply to Wap4life)
       Post #: 1712
RE: Flyeagle F18F - 4/30/2012 5:36 PM
salibaj
Score: 100
Last Login: 12/19/2012
Status: offline
quote:
ORIGINAL: bidrseed2
Thanks in advance.
See page 10 and page 11. There are all the measurments.
Regards
Joseph
Hide Signatures
(in reply to bidrseed2)
       Post #: 1713
RE: Flyeagle F18F - 4/30/2012 5:54 PM
bidrseed2
Score: 100
Status: offline
Thanks Salibaj, that's quite helpful.
I'm afraid though it's missing the one which could really be the problem, the width of the model with the stabs attached.
Hide Signatures
(in reply to salibaj)
       Post #: 1714
RE: Flyeagle F18F - 4/30/2012 6:06 PM
salibaj
Score: 100
Status: offline
quote:
ORIGINAL: bidrseed2
I see when I can measure mine and post them over.
Hide Signatures
       Post #: 1715
RE: Flyeagle F18F - 4/30/2012 6:37 PM
bidrseed2
Score: 100
Status: offline
Thank you, that would be much appreciated.
Could I trouble you to measure from the nose to the leading edge of the leading edge extension( lex)
Hide Signatures
       Post #: 1716
RE: Flyeagle F18F - 5/26/2012 11:12 PM
Wap4life
Score: 110
Status: offline
with stab 74 inch.
tailcone to split is 52 inch
a beautiful jet.
Wap
Hide Signatures
       Post #: 1717
RE: Flyeagle F18F - 7/15/2012 4:48 PM
alanjets
Score: 100
Last Login: 3/29/2013
Status: offline
Just getting mine ready for some more flights and waiting for the weather to get better here in the uk got lots of flights on it now and they look the part in the air.Still going strong on my merlin 160 with a tamjets pipe and the timer on the transmitter is set for 7.5mins then i land on about 5.5ltr of fuel i never fill the tanks full,If u have a look at my other videos u will see it fly and it land real nice
http://youtu.be/NjLpnx5zf8o
Hide Signatures
       Post #: 1718
RE: Flyeagle F18F - 7/15/2012 11:15 PM
FELIrc
Score: 100
Status: offline
Hi! Alanjets. I have one of these f-18 almost ready for the maiden flight. What CG are you using? Did you balanced the
jet with fuel? Thanks in advance.
Hide Signatures
(in reply to alanjets)
       Post #: 1719
RE: Flyeagle F18F - 7/16/2012 1:41 AM
Wap4life
Score: 110
Status: offline
hey FELIrc
never balance jet with fuel.
Wap
Hide Signatures
       Post #: 1720
RE: Flyeagle F18F - 7/16/2012 2:15 AM
FenderBean
Score: 119
Status: offline
Well balance it with UAT full but the rest empty.
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
       Post #: 1721
RE: Flyeagle F18F - 7/16/2012 9:52 AM
alanjets
Score: 100
Status: offline
yep never with fuel in tanks just uat full the C/G i still have the marks on it it was set where the wing joins the body and it is 90mm.U will love this plane if its alitttle windy i never use flaps it lands so slow i use alittle on take off with no elivator change
Click for fullsize
Hide Signatures
(in reply to FenderBean)
       Post #: 1722
RE: Flyeagle F18F - 7/16/2012 12:47 PM
FELIrc
Score: 100
Status: offline
Thanks for the help. I will try that setting for my firtst flight.
I will keep you updated.
Hide Signatures
       Post #: 1723
RE: Flyeagle F18F - 7/16/2012 2:05 PM
alanjets
Score: 100
Status: offline
Just one of the takeoffs i had to take afew things out to keep it under 20kg waight here in the uk it come out at 19.8 lol but u have to add 5.5ltr of fuel to that.with the merlin 160 mark 3 that puts out nearly 40lb of thrust it fly's real nice
http://youtu.be/0jSASy7VeOU
Hide Signatures
       Post #: 1724
RE: Flyeagle F18F - 7/16/2012 2:42 PM
FELIrc
Score: 100
Status: offline
The F-18 that I have is the new honeycomb light. The total weight dry is at around
34lb + fuel. I will install a K-180, witch puts out the same thrust (40lb). One more question. When you
lower the flaps for landing, do you have elavator mix to compensate for pitch changes? Flaps down, will the nose
pitch up or down? Thanks again, Alanjets.
Hide Signatures
       Post #: 1725
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.125RCU1
