RE: Flyeagle F18F    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Flyeagle F18F
Page: <<   < prev  61 62 63 64 65 66 67 68 69 [70]
Login
RE: Flyeagle F18F - 7/16/2012 3:07 PM
alanjets
Score: 100
Last Login: 3/29/2013
Status: offline
I only use my flaps when there is no wind i have to put some down in or it just keeps floating on and on if there is a wind try it without flaps first then mix some in to your liking it will pitch up its best to put a little more down elevator in so when landing u are putting a little elevator up in instead of pushing down in to get it down on the ground .It will fly nice on that engine mine is alot heaver and still floats real nice flying plane
Hide Signatures
(in reply to FELIrc)
       Post #: 1726
RE: Flyeagle F18F - 7/16/2012 4:42 PM
rbxbear44
Score: 100
Last Login: 5/23/2013
Status: offline
Alanjets, is this for the 1/6th or 1/7th scale F-18? I just did the maiden on the 1/6th at 230mm as the factory said and it was tail heavy for sure! Got it back fine but it was a pretty touchy all the way through the flight.
Rex
Hide Signatures
(in reply to alanjets)
       Post #: 1727
RE: Flyeagle F18F - 7/16/2012 5:48 PM
alanjets
Score: 100
Status: offline
Its the 1/7 scale just about fits in the van u wouldnt put a 160 in the 1/6 scale would not be enough
Click to see fullsize image.
Click for fullsize
< Message edited by alanjets -- 7/16/2012 6:33 PM >
Hide Signatures
(in reply to rbxbear44)
       Post #: 1728
RE: Flyeagle F18F - 7/16/2012 6:25 PM
rbxbear44
Score: 100
Status: offline
HAHA, your right! I have two 160Vx EvoJets in this bird! Just checking to make sure. The factory said 230mm on this 1/6 and by the way it flew tail heavy, I am thinking it is closer to 210-200mm.
Hide Signatures
       Post #: 1729
RE: Flyeagle F18F - 7/16/2012 6:32 PM
alanjets
Score: 100
Status: offline
yep the 1/6 is a big plane lol love the f18 think they look one of the best jets
Hide Signatures
       Post #: 1730
RE: Flyeagle F18F - 7/16/2012 6:47 PM
FenderBean
Score: 119
Last Login: 5/22/2013
Status: offline
I was about to say at that weight the 1/6 would be light! lol hey rex how goes it? I wish I lived closer to you guys over there could deff use some help with my current projects
_____________________________
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
       Post #: 1731
RE: Flyeagle F18F - 7/16/2012 7:06 PM
rbxbear44
Score: 100
Status: offline
FB, all is well my friend. Had a great time at KY. Maidened this big bird, finally. Saw the F-14's fly a bunch...man, they have worked out the bugs on those for sure! Rock solid now! I'd give "B1 Bob" a ring on the F-14, he seems to have his in the "sweet spot" and so does James Chen's brother. There was a guy there with his in EDF (no clue why to have an F-14 in EDF) that had his flying great too. I'd run your issues by those guys and see what they say.
best of luck to you on your projects!
I'm building another Hawk for a friend...love that bird!
Rex
Hide Signatures
(in reply to FenderBean)
       Post #: 1732
RE: Flyeagle F18F - 7/20/2012 11:51 AM
japan3d
Score: 108
Last Login: 5/9/2013
Status: offline
I have been emailing GJC about this aircraft, and he reccomended I start with Viper or Velox. I've been flying R/C for 37+ years, almost everything from 1/2A to 50% giants along with helicopters. Is this plane that difficult to fly? What are it's bad flying habits? Is 200+ feet of grass runway enough to takeoff and land? If I get it, it will be powered by KingTech 170-180.
Hide Signatures
       Post #: 1733
RE: Flyeagle F18F - 7/21/2012 9:10 AM
alanjets
Score: 100
Status: offline
quote:
ORIGINAL: japan3d
I stoped flying jets for 4 years and i only did 3d planes and large petrol like carf 2.6 planes then i got this f18 it is so easy to fly It realy is easy people was telling me to get something else to get back into it aswell what a load of crap, yep in the turns u have to use alittle power my merlin 160 powers it great nice big loops if u want to go straight up to the stars put a 200 in it but u will have plenty power. people think u have to be special to fly,jets special needs more like sometimes the only problem i had there was no wind the one day and i used the flaps and it wouldnt come down but i have put more down in now and no problems
Hide Signatures
(in reply to japan3d)
       Post #: 1734
RE: Flyeagle F18F - 7/21/2012 12:54 PM
japan3d
Score: 108
Status: offline
I know I'll need to buy servos and the turbine, what other electronics will I need? I want to buy all the stuff I will need to finish the plane all at once, so it will be just a matter of installing the turbine and radio gear. Thanks in advance.
Hide Signatures
       Post #: 1735
RE: Flyeagle F18F - 7/30/2012 8:37 PM
FELIrc
Score: 100
Last Login: 4/26/2013
Status: offline
Hello! F-18 drivers. I flew my f-18f 1/7 scale honeycomb version, this past Sunday. I am powering the jet with the new k-180 and running the engine with diesel. The jet flew well. Stable platform, no bad tendencies and plenty of power for scale flying. The only thing I had a problem with was with the flaps and mixing of the elevator. On the first flight after selecting the flaps down for landing the jet pitched down onto a 45 degree dive. I decided to retract the flaps and performed a no
flap landing. The other two flight I flew the jet without flaps for t/o and landings. I will mix some up elevator for the next flight and see how that goes. Anyone here using up mix on the elevtor when the flaps are deployed? Thanks in advance!
Hide Signatures
       Post #: 1736
RE: Flyeagle F18F - 8/2/2012 8:37 PM
alanjets
Score: 100
Status: offline
quote:
ORIGINAL: FELIrc
I dont use the flaps if there is abit of wind i have mixed alittle up elivator when flaps are deployed but i need to take a little out as it dosnt want to come down but i havnt mixed alot i i will measure and let u know
Hide Signatures
       Post #: 1737
RE: Flyeagle F18F - 8/3/2012 1:59 AM
FELIrc
Score: 100
Status: offline
Thanks! Alan. I will try my new setting this coming sunday. I
Hide Signatures
       Post #: 1738
RE: Flyeagle F18F - 9/8/2012 2:19 PM
EDFJim
Score: 100
Last Login: 5/24/2013
Status: offline
Some flying at E-jets after hours.
http://m.youtube.com/watch?v=K_K_m8sfFcA
Jim "Bullet"
Hide Signatures
(in reply to Mr DJ)
       Post #: 1739
RE: Flyeagle F18F - 10/1/2012 3:10 PM
EDFJim
Score: 100
Status: offline
super jet south 2012 great fun with a great flying model!
Click for fullsize
Click for fullsize
Jim "Bullet"
Hide Signatures
(in reply to EDFJim)
       Post #: 1740
RE: Flyeagle F18F - 10/1/2012 3:14 PM
EDFJim
Score: 100
Status: offline
http://www.youtube.com/watch?v=lU_A6S6Ubr8
dont know if this link worked before
Jim "Bullet"
Hide Signatures
       Post #: 1741
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
