RE: Flyeagle F18F    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Flyeagle F18F
Page: <<   < prev  61 62 [63] 64 65 66 67 68 69 70   next >   >>
Login
RE: Flyeagle F18F - 9/12/2009 10:50 PM
Timo44
Score: 100
Last Login: 9/4/2012
Status: offline
..OK nuno, I unfortunately got it wrong - didn't know, that the main gear sits less deeper in the fuselage than the
stock one ... anyway here is a vid including my flight no. 8 with landing ...
all stock !
The bird is equipped fully with AR9100 Spektrum receiver hitec servos and a P200 -
which makes it quite ballistic in the sky - but the power is needed for the rough gras track.
In my opinion the normal main gear handles quite well even on gras, as long as you don't
"race to much" around on the runway.
As soon as I saw the different problems with the stock pipe, I went for an original JetCat central single pipe (Titanium)
even more power and only a small optical issue for "scale freaks" - but performance is unbeatable with it.
Up to now what makes me concern:
After a couple of flights, the gear mechanics is getting more and more "slope / play" -
the material of the alu is to weak !
Anyhow before winter starting here in middle Europe - I disassemble the gear and let it modify with better material -
so it can even withstand 70 landings ....
Check the vid:
http://www.youtube.com/watch?v=Dwsh3NECLD8
_____________________________
Best regards
Hide Signatures
(in reply to olnico)
       Post #: 1551
RE: Flyeagle F18F - 9/13/2009 10:20 AM
salibaj
Score: 100
Last Login: 12/19/2012
Status: offline
Timo nice flight, also nice landing.
Oliver, thank you for the photos. So I think that the rails are glued from one side to the former to allow the flex, correct?
Regards
Joseph
Hide Signatures
(in reply to Timo44)
       Post #: 1552
RE: Flyeagle F18F - 9/13/2009 1:52 PM
olnico
Score: 120
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: salibaj
Regards
Joseph
No Joseph, they are not glued at all.
They cannot move because I made a small indent in the plate ( the former plate hole is slightly sorter on one side)
It is essential that the flex plates are not glued so that they can flex...
Oli.
Hide Signatures
(in reply to salibaj)
       Post #: 1553
RE: Flyeagle F18F - 9/13/2009 3:38 PM
salibaj
Score: 100
Status: offline
Ok, I thought they were not glued but wanted to be 100%
Thank you
Regards
Joseph
Hide Signatures
       Post #: 1554
RE: Flyeagle F18F - 10/22/2009 4:06 AM
ash 26
Score: 100
Status: online
Hi Olnico
I am thinking of using polyuretan flexy sealer to glue in the new formers and the flex plates this should act as an extra damper .
How is your new pipe working ?
I am just in the process of ordering one from Alex as I am also going to use a P200 instead of the simjet nexus as most of my
flying is off grass.
ASH 26
Hide Signatures
       Post #: 1555
RE: Flyeagle F18F - 10/22/2009 10:51 AM
olnico
Score: 120
Status: offline
I have not flown the 18 for a month or so. I had a mouse in the workshop while I was on vacations. She elected to make her house in the 18. She ate all the ceramic blanket, had her needs everywhere + also ate the elevator servo lines and some plywood formers.
That a big mess...
I am placing the new P-200SX in it for test purposes. Stay tuned...
Any flexible glue would do the trick. Just make sure that the flex plate can be removed in case of a big shock.
Also make sure that you use the plywood and carbon thickness that I mentioned.
In case of a big shock, the plywood will brake but not the carbon plate. So it is very easy and inexpensive to repair.
After each flight, just check the 3 struts for flexibility. If you find them move flimsy than before, this means that you have broken one of the plates.
you might also want to take some spare plywood plates with you at the field just in case...
Oli.
Hide Signatures
(in reply to ash 26)
       Post #: 1556
RE: Flyeagle F18F - 10/22/2009 6:11 PM
DelGatoGrande
Score: 105
Status: offline
instal a cat Oliver
Best Regards George SKYMASTER-A/D JETS-JETCAT-POWERBOX www.rcjet.gr "props are for boats"
Hide Signatures
       Post #: 1557
RE: Flyeagle F18F - 10/22/2009 6:13 PM
schroedm
Score: 103
Status: online
quote:
ORIGINAL: DelGatoGrande
instal a cat Oliver
George, he is - he said he's installing a 200SX
Hide Signatures
(in reply to DelGatoGrande)
       Post #: 1558
RE: Flyeagle F18F - 10/22/2009 6:49 PM
olnico
Score: 120
Status: offline
Yes that's a 25 kg cat. Pretty heavy
Oli.
Hide Signatures
(in reply to schroedm)
       Post #: 1559
RE: Flyeagle F18F - 10/22/2009 7:47 PM
DelGatoGrande
Score: 105
Status: offline
lol i didnt expect to be any good reply on me to be honest..but you got me
Mark saved you big time on this one my friend
..see you around
Hide Signatures
       Post #: 1560
RE: Flyeagle F18F - 12/31/2009 4:53 AM
heliman48
Score: 100
Last Login: 4/26/2013
Status: offline
Well Merry Christmas to all : My mane is Nate R . I live in Edmonton Alberta Canada , I am building the Tiger meet F-18 1/6 , I have now over the last three days taken the time to read all 63 pages of this build & purchase forum . It has been very enlightening but that's what a forum is for , Oliver thanks for the info passed the other day to get your three issues from RCJI , but unfortunately 100.00 us is to much to pay , I have had the pleasure to install the mod kit supplied from FEJ to widened the main gear stance and it works well and definitely beefs up that section of the A/C , as for the noise section leg, the servo frame does interfere with the cock pit kit so I will install the cables , I fitted the USA version of the AMT 450 it fits well and everything is in the back except the Boost pump and UAT , I did follow up with the carbon fiber in the Flap & aileron cutouts so hopefully there is more reinforcement at that location : now there is definitely a lot conversation on the tail pipe as well . you can order three different versions of the pipe , I believe that if you want strength & not have a weight issue you look for different metals both in thickness and integrity , I will order the tams unit but will complete ground runs on this unit . I am using a calculated Cof G spread sheet and the Cof G comes out to 174.8 is not a big deal , depending on the temp and winds as well altitude .
Can any one flying the A/C give me their true settings I am using a Futaba radio .
By the way I appreciate all the info on this site it really has helped me allot I will post some photos soon .
Nate
Hide Signatures
       Post #: 1561
RE: Flyeagle F18F - 12/31/2009 6:56 AM
David Searles
Score: 115
Status: offline
Nate,
I am just finishing up a new 1/7 F-18F that will have a Futaba 14MZ installed and powered by a Jet Central Mammoth. The one I'm still flying has a JR 12X. I'm setting the throws up pretty much as shown in Olivier's article and confirmed by my flights as well.
I have scanned copies of his Jet International articles saved on my computer. If you PM me your direct email I will send them to you.The files are too big for the RCU system to handle. The info in the articles is excellent.
CG will need to be adjusted to your own preference and flying style. My cg is pretty close to 190 but 174.8 will be safe until you get some flights on it. Be prepared for a completely honest, great flying jet!
David S
Hide Signatures
(in reply to heliman48)
       Post #: 1562
RE: Flyeagle F18F - 1/1/2010 8:42 PM
David Searles
Score: 115
Status: offline
Guys,
Those of you who emailed me requesting the copies of Olivier's articles. The files are even larger than I remembered. 180MB total. I'm running into difficulty figuring out how to send such large files. I scanned them at pretty high quality, not really thinking about the email aspect, I just wanted to preserve them on my computer. If any of you are computer whiz's and can tell me how to reduce the size for emailing, please let me know.
David S
< Message edited by David Searles -- 1/2/2010 8:38 AM >
Hide Signatures
(in reply to David Searles)
       Post #: 1563
RE: Flyeagle F18F - 1/1/2010 9:07 PM
USSCAT
Score: 100
Status: offline
David,
you can break the file down to multiple sections that could end up being around 50 seperate files. Next best thing is to put them on a CD and have the folks take care of the cost.
I doubt if you can reduce the file size or zip it to a manageable size for email.
" It is not the fall that hurts, it is the sudden stop. "
Hide Signatures
       Post #: 1564
RE: Flyeagle F18F - 1/2/2010 3:57 AM
heliman48
Score: 100
Status: offline
David
Question ::
I am installing brand new Hi Tech HS 7950 TH servos all around Today I powered up the tail section & the elevators are jumping up & down ,unless I put some pressure on them they stop . I am using a HFP - 20 programmer , am I doing anything wrong , or is it just not enough power ?? Rudder servos are just fine .
Nate
< Message edited by heliman48 -- 1/3/2010 11:14 PM >
Hide Signatures
(in reply to USSCAT)
       Post #: 1565
RE: Flyeagle F18F - 1/2/2010 4:05 AM
Mr DJ
Score: 100
Last Login: 5/18/2013
Status: offline
< Message edited by Mr DJ -- 1/3/2010 6:12 PM >
Hide Signatures
       Post #: 1566
RE: Flyeagle F18F - 1/2/2010 4:25 AM
Mr DJ
Score: 100
Status: offline
< Message edited by Mr DJ -- 1/2/2010 5:29 AM >
Hide Signatures
(in reply to Mr DJ)
       Post #: 1567
RE: Flyeagle F18F - 1/2/2010 4:32 AM
Kmarks
Score: 100
Last Login: 5/5/2013
Status: offline
Nate,
This is a huge surface and the hitec 7955 TG servos are only 333 oz torque at 6 volt, I am not sure of the hitec 7950's.
I would only use the JR 8711 servos for this surface. The JR 8711 servos are rated at 403 oz torque on 6 volt. I had these on mine and it worked great.
Best wishes on your project.
Kevin Marks
Hide Signatures
(in reply to Mr DJ)
       Post #: 1568
RE: Flyeagle F18F - 1/2/2010 6:05 AM
heliman48
Score: 100
Status: offline
Hi Kevin
I am looking at the box & it reads 402.7 oz @ 6.0 volts & 486 oz @ 7.0 volts you can find that info on the sin city web ,
If that helps . I am going to power up to 7.0 volts tomorrow & see what happens . Oh I am sure I said HS7950TH
Nate
< Message edited by heliman48 -- 1/2/2010 10:54 PM >
Hide Signatures
(in reply to Kmarks)
       Post #: 1569
RE: Flyeagle F18F - 1/2/2010 7:02 AM
Kmarks
Score: 100
Status: offline
Nate, in that case the servos should work. I had balanced my stabs and would get some titering back and forth on one side. When the stab has just a slight bit of pressure it would not do it anymore. This may also be true with your set up.
The jet as David S. stated is just a pleasure to fly when you get the feeling for it.
Kevin
Hide Signatures
       Post #: 1570
RE: Flyeagle F18F - 1/2/2010 8:37 AM
David Searles
Score: 115
Status: offline
Nate,
Did you use the rubber grommets when you mounted the tail servos?
If not, this is probably what's causing the jumping. You're getting a feedback signal from the aluminum mounts which is making it difficult for the servos to hold center. Digital servos need the insulation provided by the rubber grommets to prevent this feedback. You don't see it very often because most servos are mounted on wood mounts which absorb the vibrations. The all aluminum mounts simply amplify and return it to the servos. Reinstall the servos using the grommets and you should be fine.
The three articles are a total of 21 pages all together. I'll print out a couple copies for those who requested and drop them in the mail. Send me your address via PM.
David S
Hide Signatures
       Post #: 1571
RE: Flyeagle F18F - 1/2/2010 8:46 AM
Mr DJ
Score: 100
Status: offline
Hide Signatures
(in reply to Mr DJ)
       Post #: 1572
RE: Flyeagle F18F - 1/2/2010 9:19 AM
olnico
Score: 120
Status: offline
< Message edited by olnico -- 1/4/2010 9:33 AM >
Oli.
Hide Signatures
(in reply to Mr DJ)
       Post #: 1573
RE: Flyeagle F18F - 1/2/2010 9:23 AM
heliman48
Score: 100
Status: offline
Para : Deleted
< Message edited by heliman48 -- 1/3/2010 11:16 PM >
Hide Signatures
(in reply to Mr DJ)
       Post #: 1574
RE: Flyeagle F18F - 1/2/2010 11:25 AM
salibaj
Score: 100
Status: offline
quote:
ORIGINAL: Kmarks
Kevin
Is there any article of how to balance the stabs?
Regards
Joseph
Hide Signatures
       Post #: 1575
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.031RCU1
