best setup for rustler xl 5
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> best setup for rustler xl 5
Page: [1]
Login
best setup for rustler xl 5 - 7/20/2008 12:51:25 AM
rotor head33
Status: offline
just picked up one today and i want to know the best race set up and the best bash setup as far as shocks, slipper clutch, etc. but......i want to stick with only stock parts if possible. thanks
       Post #: 1
RE: best setup for rustler xl 5 - 7/20/2008 1:24:25 AM
Always Dreamin
Status: online
quote:
ORIGINAL: rotor head33
Ah, the xl-5. Where I started my Stampede journey.
Ok well, first things first. You need to get familuar with the truck. Start to scope it out and see the strong and weak points. Also, see how to take it appart. Now, first thing I would do is buy a Rpm front bumper. Blue or black, doesn't matter. This will protect the front of your truck against many crashes that you will have. Next, take out the transmission and replace the differential CASE ONLY with steel ring gears, and the idle gear with steel. This should cost about $15 total, and you can use any kind of grease really. Use thick grease in the differential casing, and marine or car grease in the casing. If you have some extra cash, get bearings/carriers. Don't forget, if Rpm makes it, it's worth having!
Get started with that stuff. Trust me, I know my Rustlers and Pedes.
_____________________________
Got a Stampede, Bandit, Rustler roller. Don''t know what to do with them. P.M. me if you have any interest.
(in reply to rotor head33)
       Post #: 2
RE: best setup for rustler xl 5 - 7/20/2008 2:56:25 AM
ohgrfreak
Status: offline
If RPM makes it, it's worth having, that pretty much sums it up! But I think you'll want RPM front and rear arms near the top of the list. When/if you get new carriers, you will also need new ball bearings. I say this because when I had an XL-5, the stock bushings were smaller than the what the aftermarket RPM carriers need.
Nitro>BL Evader-Midnight Pumpkin-Firestorm BL
Venom Micro Heli - Dragonfly Heli
(in reply to Always Dreamin)
       Post #: 3
RE: best setup for rustler xl 5 - 7/20/2008 3:08:18 AM
rotor head33
Status: offline
always dreamin can you get the link from a website for those parts that away i can check with the lhs thanks.
(in reply to ohgrfreak)
       Post #: 4
RE: best setup for rustler xl 5 - 7/20/2008 6:29:24 AM
Always Dreamin
Status: online
quote:
ORIGINAL: ohgrfreak
I wouldn't add the A-arms. They don't need to be replaced until you break the stock ones, and that's pretty hard to do! Save your cash, you'll be glad when something really needs to be replaced.
       Post #: 5
RE: best setup for rustler xl 5 - 7/20/2008 6:34:00 AM
ohgrfreak
Status: offline
It was easy for me, and the first thing that broke on my XL-5.
       Post #: 6
RE: best setup for rustler xl 5 - 7/20/2008 6:35:36 AM
Always Dreamin
Status: online
quote:
ORIGINAL: Always Dreamin
Will protect the front of your car in a crash.
Front bumper blue - http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPUP9&P=ML
Front bumper black - http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEV91&P=ML
Reduce friction = more speed and runtime, also cooler temperatures!
Front bearing carriers - http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNY89&P=M
Rear bearing carriers - http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNY90&P=M
Cheap 5x11 bearings - http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD122&P=M
Beef up that transmission -
Idle gear (steel) - http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSGZ3&P=ML
Steel differential gear - http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSHA2&P=M
Output yolks, cheap, good looking, stronger then the white ones - http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSHC2&P=ML#partsusage
Other parts by Rpm (all good)
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=rpm+rustler
       Post #: 7
RE: best setup for rustler xl 5 - 7/20/2008 6:37:21 AM
Always Dreamin
Status: online
quote:
ORIGINAL: ohgrfreak
Not me. A simple foward to reverse and the Idle gear is stripped. You have to hit something pretty hard to break a A-arm, and there is a chance you might never break it! I only broke one, my dad has never broken any. Plus, when they do break, they are a simple swap. Still don't think it's needed from the start. Things like the bumper can actually SAVE you money. Buying new A-arms before they break is just wasting money.
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.672RCU1
