MVVS 45 IRS Idle SLow to Return to correct setting
Tower Hobbies
Logged in as Guest
  Printable Version
BCMA-MT 57 Pro - RTR
Seller:  blackbaron
Details:   $430.00   |  8/16/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> MVVS 45 IRS Idle SLow to Return to correct setting
Page: [1]
Login
MVVS 45 IRS Idle SLow to Return to correct setting - 7/20/2008 12:13:13 PM
barney00
Status: offline
I have a new MVVS 45 which I've just completed running in (well I've finished the bottle of run-in oil that came with the engine mixing as per instructions and am now running specified mobil oil). After running at high throttle for approx 30 seconds or more, when returning to idle, the engine remains at a high idle and will only return to the correct idle after approx 30 seconds. (This happened both with the run-in fuel and current fuel). I have checked the throttle linkage for any slop (which there is none) and am using a digital servo so I don't believe that this is causing the problem with the idle. This is my first gasser engine, so any advice will be welcome.
       Post #: 1
RE: MVVS 45 IRS Idle SLow to Return to correct setting - 7/20/2008 7:59:51 PM
pe reivers
Status: offline
you are running the idle too lean. Richen it up a bit, and readjust idle rpm with throttle servo.
_____________________________
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl
There is sanctuary in analisys.
(in reply to barney00)
       Post #: 2
RE: MVVS 45 IRS Idle SLow to Return to correct setting - 7/30/2008 6:07:53 PM
BaldEagel
Status: offline
Pe
Ten days gone past and no one has said thank you, so accept my thanks anyway.
Mike
< Message edited by BaldEagel -- 7/31/2008 1:22:33 PM >
No matter what anyone says 100% is the maximum you can get.
(in reply to pe reivers)
       Post #: 3
RE: MVVS 45 IRS Idle SLow to Return to correct setting - 7/31/2008 1:53:58 PM
pe reivers
Status: offline
I am not sure if Barney's problem is solved. Why would you say thank you on his behalf? Still feeling guilty of sending those poor blokes down under in chains eh?
(in reply to BaldEagel)
       Post #: 4
RE: MVVS 45 IRS Idle SLow to Return to correct setting - 7/31/2008 2:09:08 PM
BaldEagel
Status: offline
Could be, very well could be. LOL
Mike
       Post #: 5
RE: MVVS 45 IRS Idle SLow to Return to correct setting - 7/31/2008 10:13:16 PM
pe reivers
Status: offline
Hey Barney, where are you?
       Post #: 6
RE: MVVS 45 IRS Idle SLow to Return to correct setting - 8/1/2008 12:37:14 AM
barney00
Status: offline
Hi Guys,
I'm back on-line at last. I still haven't solved my problem due to illness and at this point in time will not be able to fly for at least another 2 to 4 weeks.
Thanks for your responses. I'll let you know how I go when I am able to get back my local field.
(BaldEagle: Thanks for your reply in my absence. I bet you're the guy at the local field helping people learn to fly and solving their issues. Its good to have people like you involved in our hobby/sport!!!)
       Post #: 7
RE: MVVS 45 IRS Idle SLow to Return to correct setting - 8/1/2008 12:01:34 PM
BaldEagel
Status: offline
Barney
Hope you get well soon and back to flying, your description of me is about right, I try to help when I can.
Mike
       Post #: 8
RE: MVVS 45 IRS Idle SLow to Return to correct setting - 8/1/2008 11:46:04 PM
pe reivers
Status: offline
Today we had a similar issue with a Zenoah engine. It was a bear to start, until the idle was richened. As a consequence, the engine settled into a nice put-put idle faster. Before that, it tended to linger at slightly higher rpm before settling down.
       Post #: 9
RE: MVVS 45 IRS Idle SLow to Return to correct setting - 8/25/2008 12:49:13 PM
barney00
Status: offline
Pe, Mike,
Thanks for your help and your well wishes. First day back at the field and the problem is fixed. It was just as you said, the idle was too lean.
Thanks Again!!!
Barney
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
