Blade CP Pro controls messed up?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> Blade CP Pro controls messed up?
Page: [1]
Login
Blade CP Pro controls messed up? - 7/20/2008 8:10:18 PM
Ta4life
Status: offline
I might have to use a video to describe this but ill try words first. Iv been staying on the ground for awhile just messing with the controls and realized iv been relearning this all wrong. to keep it straight i have to use right stick a lot to make it so it does not go left while going forward or right while going backwards. same goes for left to right, it seems to want to go front to back. i have adjusted the control links, used 2 other eflite remotes to make sure it was not that, and adjusted trim of course. with the motors disconnected it looks like everything is working right. when the main rotor is spinning, it is way off
help would be appreciated!
       Post #: 1
RE: Blade CP Pro controls messed up? - 7/20/2008 8:14:14 PM
Ta4life
Status: offline
btw, i can get it to hover straight. but also the tail rotor, i have to have my left stick like all the way left to get it to hover without spinning and i adjusted gyro and the remote has trim all the way left too.
(in reply to Ta4life)
       Post #: 2
RE: Blade CP Pro controls messed up? - 7/20/2008 8:52:24 PM
evdreamer
Status: online
Is your swashplate level with the motors unplugged at half throttle in idle up? If you hold the flybar with the battery attached to the helicopter is the mainshaft perpendicular to the ground? You need to adjust the proportional potentiometer instead of the gyro gain. The gain won't help at all if the motors aren't proportioned right. Try turning the proportional potentiometer counter clockwise until the tail won't rotate with the rudder trim centered. Then turn the gain up until the tail looks like it is wagging then turn it counter clockwise a little. Are your blades tracking in the same plane? Did you switch any of the servo wires or reverse a servo channel on the transmitter?
Nick
_____________________________
Since I started this hobby money seems to keep disappearing. :)
T-Rex 450SEV2, Gaui 200 SD
       Post #: 3
RE: Blade CP Pro controls messed up? - 7/20/2008 10:14:34 PM
Ta4life
Status: offline
I think i got it a tuned in a lot better! i can actually hold a hover for a couple seconds and drop it down slowly
Thanks!
(in reply to evdreamer)
       Post #: 4
RE: Blade CP Pro controls messed up? - 7/21/2008 4:41:33 AM
evdreamer
Status: online
Your welcome. Keep up the good work.
Nick
       Post #: 5
RE: Blade CP Pro controls messed up? - 7/21/2008 4:59:04 AM
Ta4life
Status: offline
iv been doing it in my basement, seems a lot easier than grass for me...idk why But outside i was using symmetrical blades and now have flat plastics.
       Post #: 6
RE: Blade CP Pro controls messed up? - 7/21/2008 5:06:25 AM
evdreamer
Status: online
I fly with black flat bottom plastic blades and it seems to work just fine for what I do.
Nick
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.828RCU1
