BME 44 won't spool up past midrange
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> BME 44 won't spool up past midrange
Page: [1]
Login
BME 44 won't spool up past midrange - 7/20/2008 9:11:13 PM
stunt-man
Status: online
I have a BME 44 with CH Ignition that has run flawlessly for years. Yesterday, the engine suddenly lost it's top end and wouldn't advance past the midrange. Thinking that something got plugged in the Walbro carb, I disassembled it, cleaned it out and installed new float and gasket kit and filter.
Started up the engine, seemed fine, and then it resorted back to the same problem. When I advance the throttle past midrange, it starts to miss and won't spool up.
Anyone else had this problem. Could my CH ignition module have gone bad.
Any suggestions would be appreciated.
Jeff Shimo
       Post #: 1
RE: BME 44 won't spool up past midrange - 7/21/2008 12:51:17 AM
Rcpilot
Status: offline
Check the tank? Maybe the clunk is clogged? Or bad lines in the tank?
_____________________________
Airplanes have expiration dates. It''s just not printed anywhere on them.
I''m not really an airplane pilot; but I did stay at a Holiday Inn Express last night.
(in reply to stunt-man)
       Post #: 2
RE: BME 44 won't spool up past midrange - 7/21/2008 5:08:29 AM
RTK
Status: offline
Also load test your battery, make sure it is charged and up to snuff.
(in reply to Rcpilot)
       Post #: 3
RE: BME 44 won't spool up past midrange - 7/21/2008 8:33:27 AM
Bass1
Status: offline
What RTK said. . Could/might be a voltage issue.
(in reply to RTK)
       Post #: 4
RE: BME 44 won't spool up past midrange - 7/21/2008 3:03:57 PM
RTK
Status: offline
And if that is all good look at the Hall sensor.
(in reply to Bass1)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU1
