YS110 question: mount the disc valve properly
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> YS110 question: mount the disc valve properly
Page: [1]
Login
YS110 question: mount the disc valve properly - 7/21/2008 12:24:30 AM
nonstoprc
Status: offline
My YS110 would not start after I replaced the backplate and carb gasket. It will run only several seconds and quit. On top of my head, I would guess the disc valve may not be installed correctly (aligned?) as I did not pay attention to it.
Just wonder how the disc value should be aligned. Thanks a lot.
< Message edited by nonstoprc -- 7/21/2008 12:26:27 AM >
       Post #: 1
RE: YS110 question: mount the disc valve properly - 7/21/2008 12:53:14 PM
huey-pilot
Status: offline
When you remove the backplate you will see a triangle shaped opening, next to that is the fitting that the end of your crankshaft fits in.
(in reply to nonstoprc)
       Post #: 2
RE: YS110 question: mount the disc valve properly - 7/24/2008 3:45:45 AM
nonstoprc
Status: offline
Thanks. You are right. The fitting on the valve should be aligned with the crankshaft. The engine comes live once the problem is corrected.
(in reply to huey-pilot)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.172RCU1
