stg61abc
Joined: 4/19/2005 From: Catuaba do Sul SP, BRAZIL Status: offline
Hi Rider, 18% oil its ok on most modern engines, like ABN/ABC and in some racing motors. But in steel/iron piston and cylinder and in other "Hotter" aplications (ducted fan, helicopters,and others...) most people prefer to add some more oil to ensure a longer engine life, and better overall setting, and also added by people that use plain bearing motors, that require a litle bit more oil. Also, if you check at some of the OS Max engines owners manual for example, you´ll notice that 18% is the minimum indicated by this brand in various of their 2 stroke engines... (They also warn to use this percentual by volume and not by weight as some brands prefer to use...) cheers
