Adjustable aftermarket tabs for the SV27
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - Electric >> Adjustable aftermarket tabs for the SV27
Page: [1]
Login
Adjustable aftermarket tabs for the SV27 - 7/21/2008 7:38:04 PM
Nitroguy01
Status: offline
I read somewhere on here that there is a better set of aftermarket trim tabs for the SV27 that are adjustable with out having to remove the tabs from the hull. Where can you get them? Not that it really matters but do they mount in the same locations with the same screw holes? If i can find them i'd like to order a set.
       Post #: 1
RE: Adjustable aftermarket tabs for the SV27 - 7/21/2008 9:35:04 PM
Genettico
Status: offline
right here!
yes... they are a bolt on: They work great!
http://www.offshoreelectrics.com/proddetail.php?prod=ose-tab1015
(in reply to Nitroguy01)
       Post #: 2
RE: Adjustable aftermarket tabs for the SV27 - 7/22/2008 2:02:41 AM
GRANT ED
Status: offline
Or you can make your own. I made these in about an hour with stuff I had around the house. I have since trimmed the adjusting screw and painted the bracket. Looks good, works great and didn't cost a thing.
Click to see fullsize image.
Click for fullsize
_____________________________
He who dies with the most toys wins.
(in reply to Genettico)
       Post #: 3
RE: Adjustable aftermarket tabs for the SV27 - 7/22/2008 3:24:41 AM
Nitroguy01
Status: offline
quote:
ORIGINAL: GRANT ED
Are you using the origional SS tabs?? I see exactly how you made the adjustment bracket, but those SS tabs are hard to bend.
(in reply to GRANT ED)
       Post #: 4
RE: Adjustable aftermarket tabs for the SV27 - 7/22/2008 9:23:36 AM
GRANT ED
Status: offline
Yep I used the origional SS tabs. Just take them off and bend them so they sit slightly above the hull. Use the adjusting screw to push them back down to what ever setting you want. They are stiff but thats ok, the screw bends them fine.
       Post #: 5
RE: Adjustable aftermarket tabs for the SV27 - 7/22/2008 4:34:32 PM
SV27dayton
Status: offline
Those are pretty nice Granted! I would probably opt to replace them with thinner material but those look as nice and the OSE's nice job.
Scott Custom Graphics (vinyl graphics for your boat)
I error so that others may learn.
       Post #: 6
RE: Adjustable aftermarket tabs for the SV27 - 7/23/2008 9:20:26 AM
1RiverRat
Status: online
Here is a set you might want to look at. Has an upgraded water pickup also. http://www.kintecracing.com/Supervee_27_upgrades.html
(in reply to SV27dayton)
       Post #: 7
RE: Adjustable aftermarket tabs for the SV27 - 7/24/2008 12:30:59 AM
Nitroguy01
Status: offline
quote:
ORIGINAL: 1RiverRat
I was looking at that site and noticed the SV27 Latch upgrade and wondered if anybody knew what it is that is in the cowl channel on the SV27 that is shown in the example. Looks almost like some type of foam, i have been thinking about doing something like that to make a water tight seal so as to not have to use so much tape.
(in reply to 1RiverRat)
       Post #: 8
RE: Adjustable aftermarket tabs for the SV27 - 7/24/2008 10:10:37 AM
1RiverRat
Status: online
It looks like some sort of cut weather strip. You can make a good seal yourself.
First, Fill the channel in the boat with silicone.
Second, Wrap the edge of the lid with saran wrap or some kind of thin cling wrap and coat with light oil, wd40, 3m.
Third, Lay the lid in the silicone where you want it and let sit overnight.
Forth, Remove cling wrap after silicone is dry.
This will make a perfect water seal. I dont know if it will work with the stock latch, but with the bolt on unit your good to go. Tape is always a good idea though.
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU1
