RE: Discussion - Tony Nijhuis Sunderland
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Seaplanes >> RE: Discussion - Tony Nijhuis Sunderland Page: <<   < prev  1 2 3 4 [5] 6   next >   >>
Login
RE: Discussion - Tony Nijhuis Sunderland - 5/8/2009 11:50 PM
siddus74
Score: 100
Last Login: 11/7/2009
Status: offline
Bob: Really really pleased . . . couldnt help one but have one more dry fit!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
siddus74
Hide Signatures
(in reply to Mustang Fever)
       Post #: 101
RE: Discussion - Tony Nijhuis Sunderland - 5/9/2009 3:21 AM
Mustang Fever
Score: 112
Last Login: 11/8/2009
Status: offline
I with you. Setting it all up just to see how it looks is half the fun
Bob Hunt
Hide Signatures
(in reply to siddus74)
       Post #: 102
RE: Discussion - Tony Nijhuis Sunderland - 5/9/2009 6:04 PM
siddus74
Score: 100
Status: offline
We had a water plane meeting today, had to try it on the water.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by siddus74 -- 5/9/2009 6:06 PM >
siddus74
Hide Signatures
       Post #: 103
RE: Discussion - Tony Nijhuis Sunderland - 5/12/2009 8:51 AM
siddus74
Score: 100
Status: offline
Final wing radio installtion complete. Rudder left & right to throttle banks right & left mix active in flight mode 2 programmed for water steering. I have GWS gyro on it's way for the rudder. 30 degrees of flaps as well. Lots of wiring for such a small wing.
Click for fullsize
Click for fullsize
Click for fullsize
siddus74
Hide Signatures
       Post #: 104
RE: Discussion - Tony Nijhuis Sunderland - 5/12/2009 1:04 PM
Mustang Fever
Score: 112
Status: offline
Scott: Looks like you're in the copper business. Which radio are you using, and was it very difficult to program the diff steering?
Bob Hunt
Hide Signatures
       Post #: 105
RE: Discussion - Tony Nijhuis Sunderland - 5/12/2009 2:16 PM
siddus74
Score: 100
Status: offline
lol, if took a bit of thought be not really difficult . . . I have a JR PCM10X heli handset.
Mix 1 Throttle to AUX2 100% (this is so the engines operate as one but are on left and right banks) AUX2 switch is dissabled (mix enabled in all flight modes)
Mix 2 Rudder to Throttle 65% on left rudder 0% on right rudder (Only active in flight mode 2)
Mix 3 Rudder to Aux2 65 on right rudder 0% on left rudder (Only active in flight mode 2)
Thats it!
Engine test / run it at the weekend, I think Im about 15 hours away from completion now . . .
Scott.
siddus74
Hide Signatures
       Post #: 106
RE: Discussion - Tony Nijhuis Sunderland - 5/12/2009 3:41 PM
Mustang Fever
Score: 112
Status: offline
Thanks, Scott. That sounds very similar to the way the Futabas work.
Best of luck on the maiden.
BTW: can you take a quick look at your Mars plans and tell me the outside diameter of the cowls? (I'm going to look for some in FG, and I also want to assess the possibility of glow engines. I always like to do cost and weight comparisons before deciding on electric or glow.)
Bob Hunt
Hide Signatures
       Post #: 107
RE: Discussion - Tony Nijhuis Sunderland - 5/12/2009 3:46 PM
siddus74
Score: 100
Status: offline
Bob,
Maiden will not be a month or so, but need to get those engines as perfect as I can.
Will do on the cowls etc, may not be untill the weekend I fear . . . btw, I dont really see glow being an option on the Ivan Mars plans if im honest - he really does design and build in sparse manner, your see what I mean if you get the plan . . . When I build mine It will be electric (just dont tell anybody )
Hows the Cat?
Scott.
siddus74
Hide Signatures
       Post #: 108
RE: Discussion - Tony Nijhuis Sunderland - 5/12/2009 6:39 PM
Mustang Fever
Score: 112
Status: offline
Scott:
I'm thinking you're right about the glow option, based on looking at Ivan's when it was in bones. Looks kinda light. However, the amount of rigidity that 100% 1/32 inch balsa sheeting adds is amazing, considering that it weighs almost nothing.
I actually did a little work on the Cat last night- made a nice cradle for it out of pink foam. One of the things that has slowed me down is that I wasn't happy with my scheme for connecting all the electricals during the wing mounting process at the lake. I sat down yesterday and re-routed some things to make it easier, including a hatch on top of the wing for doing the final battery plug in before flight. The wind has been so goofy here that there isn't much opportunity to fly, so I should start gluing some more balsa today.
Click for fullsize
Click for fullsize
Bob Hunt
Hide Signatures
       Post #: 109
RE: Discussion - Tony Nijhuis Sunderland - 5/13/2009 10:35 PM
siddus74
Score: 100
Status: offline
Bob, we too have suffered with crummy weather, well at the weekend when im off anyway
Bit of silver tonight . . .
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by siddus74 -- 5/13/2009 10:38 PM >
siddus74
Hide Signatures
       Post #: 110
RE: Discussion - Tony Nijhuis Sunderland - 5/14/2009 9:36 PM
siddus74
Score: 100
Status: offline
Pleased with the red paint, just the detailing to do now, final ballance and throws . . .
Final wieght dry is a shade over 8lbs not great but thats the recommended weight with electric and I have flaps on my side - only time will tell?
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
siddus74
Hide Signatures
       Post #: 111
RE: Discussion - Tony Nijhuis Sunderland - 5/14/2009 9:57 PM
Mustang Fever
Score: 112
Status: offline
Scott:
When will you be starting trips to the orient? Fine china and white linen for the meals, no doubt? Sleeper berths?
Bob Hunt
Hide Signatures
       Post #: 112
RE: Discussion - Tony Nijhuis Sunderland - 5/14/2009 10:02 PM
siddus74
Score: 100
Status: offline
Indeed, could not be doing with another drab militray model . . . yes it will have windows for the passengers and ample room to pick up the Air Mail
Hope fully if I can get a resemblance to this I will be happy.
Click for fullsize
siddus74
Hide Signatures
       Post #: 113
RE: Discussion - Tony Nijhuis Sunderland - 5/14/2009 11:07 PM
Mustang Fever
Score: 112
Status: offline
Well, I think she's looking pretty nice. Do you ever imagine how commercial aviation might have developed had WWII not been fought, and all those runways never been built that didn't exist prior to the war? Maybe we'd be flying around in turbine powered flying boats and landing in the various lakes and lochs. Sure would be a lot more fun.
Bob Hunt
Hide Signatures
       Post #: 114
RE: Discussion - Tony Nijhuis Sunderland - 5/14/2009 11:35 PM
siddus74
Score: 100
Status: offline
Bob if you want some serious inspiration grab youself a copy of this 2 disc DVD boxset - it's awsome - every thing from the conception of the Curtis flyin boats right through to the extintion of the flying boats, Canadairs, Mars, Sunderland, Cats there all there . . .
I wish they were still in everyday use holidays would be so much more pleasurable . . .
Scott.
Click for fullsize
siddus74
Hide Signatures
       Post #: 115
RE: Discussion - Tony Nijhuis Sunderland - 5/16/2009 3:11 PM
siddus74
Score: 100
Status: offline
Finished to the point where it needs to be flown before before any more detail is added . . . All radioed with the inclusion of a gyro on the rudder, ballanced and ready to go.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
siddus74
Hide Signatures
       Post #: 116
RE: Discussion - Tony Nijhuis Sunderland - 5/16/2009 10:48 PM
Mustang Fever
Score: 112
Status: offline
Truly magnificent, Scotty.  I hope you can get someone to video her.
Bob Hunt
Hide Signatures
       Post #: 117
RE: Discussion - Tony Nijhuis Sunderland - 5/31/2009 7:55 PM
siddus74
Score: 100
Status: offline
Managed to do an engine test prior to the maiden @ the water plane meet next sunday  (weather permtting) . . . wish me luck!
< Message edited by siddus74 -- 5/31/2009 7:56 PM >
siddus74
Hide Signatures
       Post #: 118
RE: Discussion - Tony Nijhuis Sunderland - 5/31/2009 10:02 PM
Mustang Fever
Score: 112
Status: offline
That is really impressive, Scott.  I believe that airplane is ready to fly.  Best of luck, but most of all, enjoy it.
Bob Hunt
Hide Signatures
       Post #: 119
RE: Discussion - Tony Nijhuis Sunderland - 6/1/2009 9:32 AM
chinehamgeorge
Score: 100
Last Login: 9/14/2009
Status: offline
Hi Scott
It's looking very good and the engines sound very sweet and balanced.
Please do me a favour and cut off the excess arms on the servos and paint them white, it'll look a whole lot better
Cheers
George
PS it would have looked better with motors
Growing old is compulsory, Growing up is optional
Hide Signatures
       Post #: 120
RE: Discussion - Tony Nijhuis Sunderland - 6/1/2009 9:42 AM
siddus74
Score: 100
Status: offline
G,
If it flies right I'll finish it off nicely . . .The fuselage sides of the Martin Mars are done now!
Oh, do you know where I can get a pair of brushed 40 > 50 amp lipo compatable ESC from?
Scott.
siddus74
Hide Signatures
(in reply to chinehamgeorge)
       Post #: 121
RE: Discussion - Tony Nijhuis Sunderland - 6/1/2009 5:24 PM
chinehamgeorge
Score: 100
Status: offline
Hi Scotty
The only place I found high amperage ones was on ebay
Cheers
G
Hide Signatures
       Post #: 122
RE: Discussion - Tony Nijhuis Sunderland - 6/1/2009 6:28 PM
Mustang Fever
Score: 112
Status: offline
Scott:  Take a look at these.  http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKBF6&P=0
Bob Hunt
Hide Signatures
       Post #: 123
RE: Discussion - Tony Nijhuis Sunderland - 6/30/2009 9:44 AM
siddus74
Score: 100
Status: offline
After flying the sunderland on IC sucessfully I have decided to convert it to electric, although it did fly quite well it felt like it needed to be flown at full throttle and I was not comfortable with doing that, keeping 2 engines lit can be tough but 4 small ones was problematic, but still fun.
In hind sight the need for it to be flown flat may have not been entirely correct as I failed to take into consideration the drag factor and the fact that it may have reached it's maximum airspeed at maybe 3/4 throttle, but by the time I had contemplated this I have removed the engines / tanks and servos and cut the firewalls out. :-(
I managed to pick up a job lot of 4 x 400watt Turnigy C3656-1300 brushless outrunners and matching 40amp ESC for £90 (Appologies G, funds are tight!) that although slightly overpowered as the plan calls for 4 x 200W seemed value for money. The motors ideally suit 9x6 or 10x5 but I have opted to try 4 x 8x6 APCE to start with.
The Watts meter suggested @ 11000 rpm the current draw was 29amps / 310watts so with an UAW of 8.5Lb gives me reasonable power to weight, if all is good I may try 4 x 8x4 APCE props in the futrure to bring down the current draw.
I was not concerned about the extra weight of the motors and the wiring as they are all far foward of the CG where the weight is required due the scale short front end. Having remade and mounted the original formers and engine firewalls I cut into the LE of the wing to ensure the wire run to the ESC's although still to long IMO are as short as possible, the wire guage is 55amps for 5 Minutes so hopefully should go in my favour with regards the long wire rule. TN suggested ESC's in the Nacles were ok on his so it's good enough for me, also putting them in the fuselage will restrict the cooling to much I feel, Im still concerned about cool of the Lipo's though.
The lipos were from a friend and @ £60 for both packs (Hyperion 3S 3700mAh 20c) seems a good price as I knew the history of them and they were light for the capacity, mouting them @ the correct depth in the nose took some concideration, the end result was a tray that could be slid in to the correct possition with the lipos mounted.
The ballance is correct with a standard 4 cell RX pack in the nose and I have adjustment as the Lipos position can be adjusted on the mount. Loads of pictures as the ballance over battery mounting for me was problomatic as was the motor and wiring
configuration, so they may inspire other builders! The inner motors are powers as a pair from one battery as are the outers, however the throttle controls are on 2 separate RX channels on a mix to give water / ground handling, also I am considering putting the gyro on the rudder back in as I have heard of a fellow sunderland builder loose his electric model in crash due to a motor / esc failure.
I'm going to fly it first before tidying it up I think, wish me luck! :-)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
siddus74
Hide Signatures
       Post #: 124
RE: Discussion - Tony Nijhuis Sunderland - 6/30/2009 10:11 AM
chinehamgeorge
Score: 100
Status: offline
Scotty
The 8x6 are too much for the 1300kv version plus the current will stress the LiPo's.
You have so much power there you will be able to prop hang it
The 8x4 are a much better choice plus they will stress the LiPo's less.
Out of interest what is the weight of the model in IC form and electric form ?
Cheers
G
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.344RCU1
