How to find Speed?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car General Discussions >> How to find Speed?
Page: [1]
Login
How to find Speed? - 7/21/2008 9:34:27 PM
TRXRUSTLER
Status: offline
I was wondering how fast my Rustler went, but I don't have a radar gun so I don't know any other way to find out...................Thanks.
       Post #: 1
RE: How to find Speed? - 7/21/2008 9:45:11 PM
guver
Status: online
You can time it (distance/time) or maybe plug you numbers into here http://www.scriptasylum.com/rc_speed/_top_speed.html
OR post your specs and someone can guess really close.
_____________________________
you hear that silence?
(in reply to TRXRUSTLER)
       Post #: 2
RE: How to find Speed? - 7/21/2008 11:43:59 PM
elf232
Status: offline
Just set up a 40 yard run on a parking lot and do the math.
Bah, I haz 2 much toys.
(in reply to guver)
       Post #: 3
RE: How to find Speed? - 7/22/2008 12:34:09 AM
TheIronMaiden
Status: offline
some gps units can measure speed, if you have one of those you could strap it to your car and see how fast it goes.
(in reply to elf232)
       Post #: 4
RE: How to find Speed? - 7/22/2008 12:59:11 AM
sloppyG
Status: offline
distance/time= speed
just make sure to get your units correct
(in reply to TheIronMaiden)
       Post #: 5
RE: How to find Speed? - 7/25/2008 7:53:53 PM
nissanlove
Status: offline
is it inches/seconds?
(in reply to sloppyG)
       Post #: 6
RE: How to find Speed? - 7/25/2008 8:29:20 PM
calvino
Status: online
quote:
ORIGINAL: nissanlove
that would work to
RC18T 6800 Sidewinder Micro 2s lipo, 1980 Goldpan (needs electronics), ST-1, Slow Stick $15 outrunner combo 3s lipo †
(in reply to nissanlove)
       Post #: 7
RE: How to find Speed? - 7/25/2008 9:21:19 PM
dsales
Status: offline
quote:
ORIGINAL: calvino
that would work to
are you sure about that?
The official units are:
Speed = m/s (metres/second)
Distace = m (metres)
Time = s (seconds)
ahh, it was the 1st thing i learned in physics...
(in reply to calvino)
       Post #: 8
RE: How to find Speed? - 7/26/2008 5:22:25 AM
SAVAGEJIM
Status: offline
quote:
ORIGINAL: dsales
quote:
ORIGINAL: calvino
that would work to
Time = s (seconds)
In the US, we use the British Imperial system (feet, seconds, pound mass). Funny, we dont call it the British Imperial system, we now wrongly call it the "Standard" or "American Standard" system, even though the foot was actually based off of old England's King Henry the 1st (or at least the legend goes). So, it is very funny that the British now use the Napoleonic SI instead of their own British Imperial system. Again, more historical irony, King Lewis (Louis en Francias ) the 16th who made metric system the standard French measurement was killed. The French Republic kept the system, and due to Napoleon's influence, the metric system became the SI and was sperad all over Europe.
Personally, I prefer to calculate most things in SI, speed, as in this discussion, becomes very easy to convert from Km/hr from m/s and so forth. I can even do it mentally without the aid of a pencil & paper. In the British Imperial system, it is much harder, converting from ft/s to mi/hr is much harder. There are 12 stupid inches in a foot (Why cannot it be TEN inches per foot?). King Henry ole #1 should have had his foot cut off by the toes! Then, feet would be much more easier to work with because there would be 10inches to a Henry foot! Worse, there are 5280 surveyed feet in a statute mile! They should have made a concept of a kilo foot, or at least a kilo yard. That way converting from ft/s to mi/hr would be much easier.
Sorry for the rant, this is my beef with the British Imperial system when calculating speeds. I like to do things mentally, but because of the Brit Imp system not being divisible by ten, I have to resort to a calculator, spreadsheet, etc when converting ft/s to mi/hr (or even yd/s to mi/hr)
< Message edited by SAVAGEJIM -- 7/26/2008 5:26:31 AM >
I hate stray Tomcats
(in reply to dsales)
       Post #: 9
RE: How to find Speed? - 7/26/2008 5:23:18 AM
JATO TO THE MAXX
Status: offline
Or you could just buy the Venom Speed Meter
http://www.venom-group.com/itemdesc.asp?ic=VEN%2D0615
T-Maxx Big Block, Jato 3.3, RC18T Brushless, RC10L3 Oval, RC10 Gold Pan
       Post #: 10
RE: How to find Speed? - 7/26/2008 8:34:12 AM
Gex_61
Status: offline
Do it without ever turning your car on.
http://www.teamassociated.com/racerhub/techhelp/marc/JScripttable.html
http://www.teamassociated.com/racerhub/techhelp/marc/gearform.html
Gexunderscore61
(in reply to JATO TO THE MAXX)
       Post #: 11
RE: How to find Speed? - 7/26/2008 9:40:10 PM
SAVAGEJIM
Status: offline
quote:
ORIGINAL: JATO TO THE MAXX
I have one of those, I used it on my R40. Nifty gadget to see how fast a car goes on a straight, but it unfortunately only adds unwanted weight on the track.
My only problems I have with this Speedo is getting the oll-out corect. Then, as the foam on the tires wear down, doing another roll-out to account for the reduced wheel's diameter.
       Post #: 12
RE: How to find Speed? - 7/26/2008 9:44:49 PM
SAVAGEJIM
Status: offline
quote:
ORIGINAL: Gex_61
Those are very nifty, and I use those very same formulae on an Excel spreadsheet. The only problem with that is the part of the RPM. You really dont know if your car will turn those RPMs unless you actually do some field testing. For example, an engine is advertised to reach 42000RPM (and virtually all RC advertisers are lying snakes). Put high gears on the engine and run that car on the street, wnd you will discover very quickly that the engine simply does not have the torque @ 42000RPM to turn those gears. The engine might reach 35000RP max on those high gears, so the calculated speed at 42000RPM on high gears is moot.
(in reply to Gex_61)
       Post #: 13
RE: How to find Speed? - 7/26/2008 11:29:46 PM
sloppyG
Status: offline
it's whatever you want
you have to convert from whatever distance you time (say 50-100 feet) to miles, and convert the time into hours
you'll get something like (random here) 30 feet/second, figure out how many feet/hour, then convert the feet to miles/hour
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
