spiral_72
SC, USA Status: offline
quote:
ORIGINAL: joco1 i added 3oz of weight to the tail to get it balanced i had full down trim to get it to stay up and still had to hold way back on the stick! .......added 5 oz more.....it started to help a little it would climb too much flying into the wind and would still drop like a dang rock going down wind thats around .......i have a zinger 12x7 on the front but it takes a whole lot of runway to even get airborne ! any suggestions on what im doing wrong! This doesn't make sense. You added 8oz of tail weight! The plane should do nothing but hover. If the plane requires 8oz of tail weight just to improve, something is very wrong. As a guess, I think you are compounding your problems now. I think the plane is rediculous tail heavy now, with a ton of down thrust on the engine. Check the tail and wing incidence with a long straight edge. You might find the horizontal stab is off with respect to the wing. Second, make absolutely sure you understand where the manual says the CG is at. Sometimes it's called out from the leading edge, sometimes from the spar. Third, get the plane high ASAP and cut the throttle upwind. With the engine at idle, it should glide, slowly losing altitude. The glide test will be very important because it eliminates the motor and thrust angle from the problems leaving only the airframe. If the plane glides at idle, you problem is the engine setup. ...or find someone that's an experienced flyer. If you figure this out on your own though, you'll have learned very valuable experience. .....also, in a perfect world all your controls will be centered. It gives you something to strive for.
< Message edited by spiral_72 -- 7/22/2008 8:23:11 PM >
_____________________________
Wasn't that cool? I meant to do it.
