FA56 for a GP Stick 40?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> FA56 for a GP Stick 40?
Page: [1]
Login
FA56 for a GP Stick 40? - 7/22/2008 7:28:02 AM
RappyPilot
Status: offline
Hi guys.
I am keen on getting the Great Planes Big Stick 40, always wanted a stick. I have a Saito FA56 without a home and was wondering if it will have enough power for the plane, I am not interested in overpowering the plane. Just looking for a nice sounding nice, flying plane that can do aerobatics with and that can slow down to a crawl when landing. I fly from a VERY short runway. And I just love the Maltese Crosses he he :-)
The reason for my question is that the manual suggests a .50 - .70 4-stroke while the Great Planes website suggests a .60 - .80 4-stroke. So I am a bit worried that the engine will be a bit under powered.
Any comments on this will be appreciated.
Marcel
       Post #: 1
RE: FA56 for a GP Stick 40? - 7/22/2008 11:45:24 AM
mike109
Status: offline
G'day I have GP Stick 40 which I have used to test various engines and I think you will have no problems with the FA56 in it. Mine started out with an OS 52 Surpass which was fine, then an ASP 52 four stroke which flew it well, it then got an ASP 61 FS which is the same weight and size but a bit more powerful and it too was fine. At the moment, it has a Thunder Tiger 46 Pro which is faster than the four strokes but is still similar in general performance. I have a FA 56 which has been in several planes including a Vmar Apache II trainer (heavier then the Stick and it flew really well), a Sig Kadet Senior (perfect) and a Phoenix Tiger Moth Bi-plane which crashed on its first flight as it had far too much power and I suspect a rear ward CG problem. The 56 is not a heavy engine and should do the job well. Just don't expect it to have infinite vertical performance. And of course, a Saito 72 will drop straight in where the 56 was if you do decide that you need more grunt. More weight though.
Have Fun. Mike from Oz.
_____________________________
If it''s not right on the ground - it won''t get better in the air. Club Saito # 597
(in reply to RappyPilot)
       Post #: 2
RE: FA56 for a GP Stick 40? - 7/22/2008 11:52:34 AM
RappyPilot
Status: offline
Hi Thinks for the info. I am not really looking for unlimited vertical, sort of takes away good piloting and throttle management skills if you ask me
But I feel a bit better knowing that it will work. This will also be my first attemp at using a four stroke so I am quite looking forward to it.
Marcel
(in reply to mike109)
       Post #: 3
RE: FA56 for a GP Stick 40? - 7/22/2008 8:16:56 PM
skyraider71
Status: offline
That Saito .56 should provide your stick with ample power, and sporty
performance. Go for it!
Busting props, and shredding Mono-cote since 1999
       Post #: 4
RE: FA56 for a GP Stick 40? - 7/23/2008 12:35:33 AM
mike109
Status: offline
G'day Glad I was able to help a bit. I learned to fly RC planes back in 1989 and all my engines were two strokes. In 1992, I bought my first ARF - a Thunder Tiger Trainer 40 - and I put an OS 48 Surpass in it. It was a revelation. It was slower in the air but pulled up hill better. I loved it and other people who flew it were also impressed. Since then, I have gradually switched from two strokes to four strokes for most of my models. I like the lower noise levels, the greater torque at lower revs and the sound. I had a pause in my RC flying from about 1994 to 2002 and when I started again, the Saito 56 was my first engine. It is still going strong (despite several quite nasty prangs) and I have just put it back in my Kadet Senior.
You will find that your Saito does not fly the Stick as fast as a two stroke would but it will do a great job at hauling the stick through normal maneuvers. And it will sound great.
Mike from Oz
       Post #: 5
RE: FA56 for a GP Stick 40? - 7/23/2008 1:18:53 AM
Ed_Moorman
Status: offline
I had a GP Big STick 40 that I used for years as an engine test and break-in plane. I recall I had 16 different engines on it, including my Saito .56. It is a nice combination if you're not looking for extended vertical. I used a 12-6 prop and could do all the acro. I just didn't have long, extended vertical climbs like when a Magnum .70FS was on it.
The engine in the photo is an SK 50. The extra yellow tubingon the side is for the 4-stroke pushrod. I would pull the wire out of the 2-stroke tube and insert it into the 4-stroke tube to change over. The engine mount looked like Swiss cheese. I went through a few of them.
The Saito .56 is an excellent engine, runs just great. Right now I have it on a Tower Uproar with floats, shown just touching down with the Saito .56. This is another nice combination.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Ed Moorman, AMA 553, KD4QBM, Revver Bro #156
R/C Report Magazine, Fun Aerobatics Column
       Post #: 6
RE: FA56 for a GP Stick 40? - 7/23/2008 6:51:16 AM
RappyPilot
Status: offline
Hi guys.
I am convinced, ordered my GP Stik :-) Look forward to getting it.
Going to start off with a 12x6 prop and take it from there. Seems about half way in the range of props that one can use.
(in reply to Ed_Moorman)
       Post #: 7
RE: FA56 for a GP Stick 40? - 7/23/2008 11:32:11 AM
the pope
Status: offline
I Have a 40 size stik and a saito 82 in it and its just about spot on( a bit more oomph wouldnt go astray ) . I personally wouldnt go for any thing smaller but if you want to just putter about give it a shot. I haven't any experience with that size engine. Cheers the pope
       Post #: 8
RE: FA56 for a GP Stick 40? - 7/23/2008 12:57:37 PM
Hobbsy
Status: online
Rap, here is my newer .56GK turning a Graupner 12x6 @ 10,266 and idling below 2,000, you will be pleasantly surprised with the .56. This was on 15% wildCat/18% lube.
Click for fullsize
Click for fullsize
Click for fullsize
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
       Post #: 9
RE: FA56 for a GP Stick 40? - 7/23/2008 1:11:13 PM
RappyPilot
Status: offline
Hello Hobbsy
Thanks for the readings :-)
Was wondering what that prop and fuel combo would achieve.
(in reply to Hobbsy)
       Post #: 10
RE: FA56 for a GP Stick 40? - 7/23/2008 3:42:44 PM
blw
Status: offline
quote:
ORIGINAL: RappyPilot
Hello Hobbsy
I think I was getting around 12,400 with an APC 12x6 and Omega 15%. The .56 is a sweet running engine with very good characteristics all the way around.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
       Post #: 11
RE: FA56 for a GP Stick 40? - 7/25/2008 2:54:55 AM
sevans16
Status: offline
I think I posted my numbers in the Tach thread. My OS FSa 56
I was running a 13x6 APC sport prop @ 10,100 on 15% Cool Power. Detuned 300 rpm(10,400)
< Message edited by sevans16 -- 7/27/2008 2:18:01 AM >
AMA# 737516
(in reply to blw)
       Post #: 12
RE: FA56 for a GP Stick 40? - 7/25/2008 7:06:42 AM
RappyPilot
Status: offline
Does altitude above sea level make any difference to such readings? Johannesburg is about 5500ft above sea level.
I am running an OS46AX on my Calmato, engine is faily new and with a 10x6 I don't seem to get more that 13000 odd RPM. When they can go up to 16000. I know prop selection makes a big diffirence. But does altitude?
(in reply to sevans16)
       Post #: 13
RE: FA56 for a GP Stick 40? - 7/25/2008 10:34:34 PM
blw
Status: offline
Rappy,
The higher density altitude in S. Africa makes a big difference in performance.
       Post #: 14
