Dodgey99
Joined: 4/30/2003 From: london, IL, UNITED KINGDOM Status: offline
You are right about the Govenor mode on CP. Not used for FP though. The Hacker, Phoenix 10 combo I have is great. (the Phoenix 10 is awesome). The Razor package certianly looks like good value for money! Can't tell the difference between the Phoenix 10 and 25. I also run my Eco 8 on a Mega 22/20/4 with a Phoenix 45. Sweet too. As far as tail setups go, you have definately made the right choice to start with the HB. It may not be ideal having a motor for the tail control, but they only cost a few quid to replace, and when you crash, not a lot happens. When you crash a hornet, you usually break the tail boom (which can't be bodged as it has a drive shaft in it), drive shaft, maybe gears, blades... you get the picture. This is definately for the more experienced flyer. I'm getting into the swing of things but I still crash all the time. Probably because I use the HBto practive stuff before I attempt it on my Eco 8 :-)
