servo: radial to linear motion???
Tower Hobbies
Logged in as Guest
  Printable Version
Low profile on/off switch with external charging jack
Seller:  k4lpcm
Details:   $19.99   |  9/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> servo: radial to linear motion???
Page: [1]
Login
servo: radial to linear motion??? - 7/22/2008 11:15:59 PM
Capt Jim
Status: online
I have an application that could benefit from a more linear push rod actuation. Is there any clever way to reduce the typical arc produced by a standard servo arm?
I do not need a lot of torque or speed but I do need a full inch of push rod movement.
Thank.
_____________________________
Captain Jim
       Post #: 1
RE: servo: radial to linear motion??? - 7/23/2008 12:35:36 AM
fizzwater2
Status: offline
Use a really long arm, and reduce the amount of radial throw with your transmitter - less radial action would give you a more linear response.
Many years back you could get servos with both a rotary output, and two "rack" outputs in the same servo. There was an internal gear that drove the racks, sort of a rack and pinion design. You might rig up something like that external to a servo.
no matter where you go, there you are..
(in reply to Capt Jim)
       Post #: 2
RE: servo: radial to linear motion??? - 7/23/2008 12:41:01 AM
TLH101
Status: offline
http://www.e-clec-tech.com/lisekits.html
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCJG6
If that don't work, try laying the servo on it's side. That's what I do when I need a linear motion (like 1 servo to actuate a very short Y shaped push rod).
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
       Post #: 3
RE: servo: radial to linear motion??? - 7/23/2008 1:21:54 AM
Campgems
Status: offline
quote:
ORIGINAL: TLH101
I've got to keep these in mind. They don't look like they will work for Capt Jim though as they only have 3/4" travel vs the 1" he needs.
Capt, you could use a long servo arm, and then use expo to flaten out the movement in relation to the stick. I don't know if it would work for you or not. The only other thing would be to find a rack and gear and mount the gear on a servo wheel. You would have to build a trough for the rack though.
Another answer is to use one of the linear actuators for Robotics. The Cal Poly Aerospace guys were out to the field last month with a big parasail and a cage below with a DA50 engine. The thing was radio controled The pull handles for control was handled by a couple linear actuators having about 4 to 6" of stroke. They amplified it what a long arm so the actual pull was 12" or more
Unfortunatly, the first flight wasn't the best. I don't know where they got the acuators, and the college is in summer mode now.
Don
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to TLH101)
       Post #: 4
RE: servo: radial to linear motion??? - 7/23/2008 2:28:24 AM
sfsjkid
Status: offline
Servo City has actuators that look similar to the Cal Poly ones.
http://www.servocity.com/html/servo_actuators.html
Also, back in the days when mixing was not available, one option to set up a y-tail was to put one servo (rudder) on a sliding tray and have another servo (elevator) actually move that tray. You wouldn't need the second servo, and it would require some space, but you'd probably would be able to get your inch movement by adjusting the lenght of the actuating servo arm.
Good luck!
(in reply to Campgems)
       Post #: 5
RE: servo: radial to linear motion??? - 7/23/2008 3:12:45 PM
BarracudaHockey
Status: offline
Hehe yea, I had a glider with the sliding servo arrangement.
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
(in reply to sfsjkid)
       Post #: 6
RE: servo: radial to linear motion??? - 7/23/2008 3:40:05 PM
sfsjkid
Status: offline
quote:
ORIGINAL: BarracudaHockey
Watch out that is a sure sign of how long one has been in the hobby and age .
I had another thought, in this case where only one servo is needed, one could set up the servo to move itself on the servo tray.
(in reply to BarracudaHockey)
       Post #: 7
RE: servo: radial to linear motion??? - 7/23/2008 3:50:23 PM
Capt Jim
Status: online
I really like those linear conversion kits. That would do the trick...I would just have to modify things to get happy with only 3/4" motion.
Until I get a couple of those little gismos in the mail, I may just have to lengthen the pushrod so that the radial excursion is no longer an issue.
Back to the bench...
Thanx everyone.
jim
Just to make things a little more clear....or maybe not. The application is for a (2 stage) multiple release mechanism. Banner tow/drop, parachute drop, etc etc.
The push rod that causes the release must operate within a small...3/8" diameter tube. When the servo is mounted close to the mouth of the tube, the radial motion of the servo arm causes the push rod to rub the inside wall of the tube. By moving the servo away significantly, the angle created by the radial motion is reduced at the mouth of the tube. It makes the installation less compact, but still workable.
Captain Jim
       Post #: 8
RE: servo: radial to linear motion??? - 7/23/2008 8:24:10 PM
Dsegal
Status: offline
quote:
ORIGINAL: TLH101
That doesn't make a lot of sense to me- no matter what the attitude of the servo the motion of the output arm will still be rotary and not linear.
< Message edited by Dsegal -- 7/23/2008 10:17:38 PM >
Dave Segal
       Post #: 9
RE: servo: radial to linear motion??? - 7/24/2008 12:22:18 PM
Hibrass
Status: offline
Dave,
It does indeed if you think of it in this way... With the Y rod in the horizontal plane and the Server Vertical there will be deflection left and right on the Horzontal plane as the servo rotates and moves the Y rod back and forth... If the Y rod was connected to say a pair of Elevators you would see a change in deflection on one half compared to the other depending on what point the servo is at during its travel..
Now if the same setup as above is used but the servo is now horizontal i.e. on its side, the left to right deflection will be change to up and down deflection. since the Y rod is still the Horizontal plane the up and down deflection will have no impact on the Elevator halves deflection...
I'm using the very same setup in a 27% Midwest Cap 232 and it works great and I only need one really big servo... LOL In this case a S9152..
I hope this long winded explantion helps..
Ed "Hibrass" Harley Club Saito #457
"If you don't know the Dog, don't yank his chain."
(in reply to Dsegal)
       Post #: 10
RE: servo: radial to linear motion??? - 7/24/2008 1:29:20 PM
TLH101
Status: offline
quote:
ORIGINAL: Hibrass
Dave,
Exactly. I learned this many years ago, when trying to set up the flaps on a GP Cherokee. The flap push rod "yoke" was very short. When I would hook up the flaps with the servo up right, the deflection from servo wheel rotation made the flaps uneven. After turning the servo on it's side the, the deflection was in the vertical plane and the flaps were more synchronized.
Terry
(in reply to Hibrass)
       Post #: 11
RE: servo: radial to linear motion??? - 7/24/2008 2:48:08 PM
GBR2
Status: offline
While I can see that putting the servo on its side would not make the rod move from side to side any longer, the movement of the rod is still non-liner in its travel.
       Post #: 12
RE: servo: radial to linear motion??? - 7/24/2008 3:09:07 PM
Silent-AV8R
Status: offline
Laying the servo on it's side will still result in non-linear motion. The pushrod will move up and down instead of side to side. And the throw will still be non-linear.
Reality is Subjective. At least that's what I think.
(in reply to GBR2)
       Post #: 13
RE: servo: radial to linear motion??? - 7/24/2008 3:22:16 PM
TLH101
Status: offline
OK............
Terry
(in reply to Silent-AV8R)
       Post #: 14
