Rescue boat?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Off Topic Forum - Boats >> Rescue boat?
Page: [1]
Login
Rescue boat? - 7/23/2008 1:40:36 AM
MOVMX Racer
Status: offline
Hey guys... I was wondering if anyone makes a CHEAP rc boat that I can use as a rescue boat. I need one for like $30 or below (or a little more), I plan on modding it anyway, I just need a decent sized hull that I can base one off of, and it needs to stand up to polyester fiberglass resin (not sure if abs does or not). I would prefer something from a walmart or similar store, as my LHS is far away, and not really local...
_____________________________
My Rc: SV27 Nitro boat, 3.3 Maxx, stock RC10B4, 5400KV 45mph RC18T, and stock Losi XXX-S.
       Post #: 1
RE: Rescue boat? - 7/24/2008 2:35:22 AM
Ron Olson
Status: offline
Go to Wally-world and get yourself a 2-man inflatable boat instead. We have Aldi's stores up here and I just picked up one with a pump and oars for $20.00. I really didn't need it as I already had 2 other inflatables. I carry a 12-volt inflator along used for air mattresses and these boats. It'll blow it up in a matter of minutes while I'm unloading my other gear. If you're tight for space they don't take up much room at all.
With a cheap R/C boat you might run into other problems that it can't handle like a flipped boat or one hung up in weeds. A partially submerged boat will be very difficult to move also.
Member, Southwest Michigan Model Boat Club.
(in reply to MOVMX Racer)
       Post #: 2
RE: Rescue boat? - 7/24/2008 11:19:40 PM
MOVMX Racer
Status: offline
quote:
ORIGINAL: Ron Olson
Been there done that. I already have an inflatable boat and rechargeable coleman pump. I wanted a retrival boat so I dont always have to use the inflatable. I just hit walmart and bought a small abs boat and stripped it, and now I am having trouble deciding whether to glass it and bake it a brushless surface drive, or whether I should just make it a rescue boat...
(in reply to Ron Olson)
       Post #: 3
RE: Rescue boat? - 7/24/2008 11:39:31 PM
Ron Olson
Status: offline
I picked up a Zig-Zag Racer at one of my LHS's just to blow some money and to use it for bringing my dead boats back to shore with it. That was my intent for the ZZR but I'd toss it in the water and would end up by running the batteries dead playing with it!
What I did was put a cup hook low on the transom then I used one of the included balls and line to attach to the hook with a fishing swivel snap. The ball would snag on the rudder usually and I could drag the dead boat back to shore.
       Post #: 4
RE: Rescue boat? - 7/25/2008 4:10:09 PM
firelite_marine
Status: offline
finally got the decals I drew up for my rescue boat. I just have to be carefull not to skewer my 57apache.
in case your wondering bout the name, its a fishing boat and i dropped a 3500watt stereo system in it, hence the name.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
If it aint broken, your not using it right
Pics and Vids at www.firelite-marine.com
       Post #: 5
RE: Rescue boat? - 9/26/2008 5:53:39 PM
HoaRC
Status: offline
Option #1: Nikko Sea Racer ($7-21)
Stock Video: http://www.youtube.com/watch?v=LCpBKYUnbSE
Where to buy:
http://www.hobbytron.com/NIKKO-SEA-RACER.html
http://www.toysrus.com/family/index.jsp?pg=1&categoryId=2290619&s=A-StorePrice-TRUS
http://desc.shop.ebay.com/items/Radio-Control-Control-Line__rc-boat?LH_TitleDesc=1&_nkw=rc%20boat&_fln=1&_sacat=2562&_sc=1&_sop=15&_ssov=1&_trksid=p3286.c0.m282&_mPrRngCbx=1&_udlo=&_udhi=22
Needed for rc conversion:
soldering iron, solder, wire, isolation tape, liquid flux, box of plastic gloves, electrical fan,
75 Mhz AM transmitter, 75 Mhz AM receiver, speed controller (ESC), Servo with servo horn, 2 Servo Rods, two pliers, silicon and/or plastic glue, screw driver, 7.2 volt battery, 8 imitation deans plugs, charger.
I am posting detailed building instructions to help other newbies!
Options: You can build a custom deck, attach a fishing pole, use it as a rescue boat, you put an rc electric bb gun on top (what I plan to do) for rc combat.
Cheers!
youtube.com/group/traxxasstampede
(in reply to firelite_marine)
       Post #: 6
RE: Rescue boat? - 9/26/2008 6:43:17 PM
soundguykaraoke50
Status: offline
this is one i used
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by soundguykaraoke50 -- 9/26/2008 6:45:23 PM >
(in reply to HoaRC)
       Post #: 7
RE: Rescue boat? - 9/26/2008 6:50:55 PM
soundguykaraoke50
Status: offline
more pictures
Click for fullsize
Click for fullsize
(in reply to soundguykaraoke50)
       Post #: 8
RE: Rescue boat? - 9/28/2008 6:34:57 AM
HoaRC
Status: offline
quote:
ORIGINAL: soundguykaraoke50
more pictures
That's a huge rescue apparatus right there. I will use same design but on a 5 inch size scale.
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.922RCU1
