Removing piston from OS 91 surpass
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Removing piston from OS 91 surpass
Page: [1]
Login
Removing piston from OS 91 surpass - 7/23/2008 2:34:05 PM
flyingbells
Status: offline
Hi folks,
Just need some help in removing piston and liner on an OS surpass 91
I've removed backplate, cam gears and the head. What do I do next???
thanks!
Bill.
       Post #: 1
RE: Removing piston from OS 91 surpass - 7/23/2008 3:26:35 PM
Bax
Status: online
Remove the cylinder liner, which slides straight up. Then the connecting rod can be removed from the crankshaft. The piston/rod assembly will then slide straight up, out of the crankcase.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to flyingbells)
       Post #: 2
RE: Removing piston from OS 91 surpass - 7/23/2008 4:02:37 PM
flyingbells
Status: offline
thks for your quick reply. I've tried removing the sleeve it won't slide out, and there's no where for me to leverage on to pull or push out?
(in reply to Bax)
       Post #: 3
RE: Removing piston from OS 91 surpass - 7/23/2008 4:12:40 PM
masama1107
Status: offline
Make sure you have removed all rubber O-rings and seals and "bake" your engine block in a small toaster oven at 300-325 Degrees F for about 8 to 10 min...
The sleeve should slide right out of the block when you carefully, with out burning yourself, turn the engine block upside down. Make sure you handle the very hot engine with a thick pot holder, or something else to protect your hands.
I always use this system to remove and re-install ball bearings of both two and four stroke engines and it works great....
Hope this helps.
       Post #: 4
RE: Removing piston from OS 91 surpass - 7/23/2008 6:07:56 PM
proptop
Status: online
quote:
ORIGINAL: flyingbells
I wear leather gardening gloves (after heating the case ) and push the sleeve up and out with the handle of an old tooth brush or piece of dowel.
It's bad luck to be superstitious...
Revver Bro #77
       Post #: 5
RE: Removing piston from OS 91 surpass - 7/23/2008 8:26:51 PM
pilotpete2
Status: offline
As others have said, you have to heat up the case usually before you can remove the cylinder liner. If you have a heat gun for shrinking iron on covering, that will also work very well.
Pete
"If the woman don''t find you handsome, they should at least find you handy"
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
