Best way to clean up old carb
Tower Hobbies
Logged in as Guest
  Printable Version
PARK ZONE F-4U CORSAIR
Seller:  harleydoberman
Details:   $279.99   |  8/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> Best way to clean up old carb
Page: [1]
Login
Best way to clean up old carb - 7/23/2008 3:40:25 PM
Roo Man
Status: offline
What is the best way to de-gum an old carb? I have an OS46 that has not been run for several years and the carb is locked up with what I call gum, kind of a yellow sticky stuff.
Gary
_____________________________
Roo Man
WTRCF Jackson, TN
       Post #: 1
RE: Best way to clean up old carb - 7/23/2008 3:44:08 PM
RCKen
Status: offline
The "gum" is just old dried up castor oil and fuel. You can soak the carb in a little bit of fuel and it will loosen up that "gum" and remove it.
Ken
The take off is optional, but the landing is MANDATORY!!
AMA # 712539 www.gettingairborne.com
Moderator- Beginner's, Sport Flying, Off-Topic, & AMA Discussions
RCU Community Moderator
(in reply to Roo Man)
       Post #: 2
RE: Best way to clean up old carb - 7/23/2008 4:49:22 PM
opjose
Status: offline
"Dawn Power Dissolver" REALLY works well for buildup.
You basically wash the engine/carb in it, let it sit for a while with the liquid on, then wash it off with water.
Finally you remove the water by apply something that will displace the water.
I use air to blow out the water, then WD40 followed by glow fuel and/or afterun oil.
The excess castor disappears completely and your engine/carb looks brand new too!
Build em'', fly em'', crash em'' and build more.
(in reply to RCKen)
       Post #: 3
RE: Best way to clean up old carb - 7/23/2008 5:13:35 PM
brett65
Status: offline
I had a gummed up OS 25 that the carb wouldn't move at all. I sprayed it with WD-40 and let it set a minute and it loosened up as I actuated it and put more wd-40 on it.
Truckzilla w/LRP28,Firestorm,Spek DX3.0,Micro-T,uglystik,SkyRaider Mach 1 TTpro 46,Phoenix Extra 300S OS 55AX Futaba 2.4 6EX
(in reply to opjose)
       Post #: 4
RE: Best way to clean up old carb - 7/23/2008 6:58:14 PM
Roo Man
Status: offline
Thanks to all.
Gary
Roo Man
WTRCF Jackson, TN
(in reply to brett65)
       Post #: 5
RE: Best way to clean up old carb - 7/23/2008 8:50:43 PM
greybucket
Status: offline
I did the old antifreeze technique to clean up my old engine. Looks like I just bought it. I will probably try the Dawn Power Dissolver next time on another engine I gotta do... seems easier! lol
If practice makes perfect, and nobody is perfect... why practice? - AMA #910567 - http://www.greybucket.com
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
