transfering data/memory between two 10X's
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> transfering data/memory between two 10X's
Page: [1]
Login
transfering data/memory between two 10X's - 7/23/2008 3:50:32 PM
ajcoholic
Status: offline
Is it possible to transfer a model memory between two 10X transmitters without saving to the Data safe program first?
Andrew
_____________________________
Andrew J. Coholic
Engine reviewer for FLY RC Magazine - andrewc@flyrc.com
       Post #: 1
RE: transfering data/memory between two 10X's - 7/23/2008 4:46:23 PM
GBR2
Status: offline
There should be a TRANSFER funtion that allows you to do it. You can do it with the 8103, 9303 and 12X, so it should be available in the 10X. It is probably explained in the manual. If you don't have one, you should be able to download a pdf one from the Horizon site.
(in reply to ajcoholic)
       Post #: 2
RE: transfering data/memory between two 10X's - 7/23/2008 6:43:22 PM
B58
Status: offline
put both transmitters to the model memory you are going to use, plug in the cord, go to transfer on both, and transmit from the one to the other. Very easy, and it will even copy your model name and timer. Bob
(in reply to GBR2)
       Post #: 3
RE: transfering data/memory between two 10X's - 7/23/2008 9:56:59 PM
ajcoholic
Status: offline
Thanks!
AJC
Andrew J. Coholic
(in reply to B58)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
