Did your supervee brushless come this way?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - Electric >> Did your supervee brushless come this way?
Page: [1]
Login
Did your supervee brushless come this way? - 7/24/2008 4:21:29 AM
robcaryh
Status: offline
Did your brushless come with the drive shaft strut nuts and bolts installed?
I didnt notice my 2 were embedded in packing foam and not on the boat. I ran it,it hopped uncontrollably the first time i ran it and flipped and sunk. Destroyed my batteries worth $100. I didnt notice the nuts were missing till a post mortem on the boat.Nowhere does the manual say anything about this,its supposed to be ready to run out of the box,it totally slipped past me that they werent there. Tower hobbies told me call aquacraft. Any ideas or thoughts?
***Mod edit for language use***
< Message edited by Dreamin Hemi -- 7/24/2008 4:48:17 AM >
       Post #: 1
RE: Did your supervee brushless come this way? - 7/24/2008 4:30:53 AM
quadracer111
Status: offline
people rich enough to afford a boat like that deserves that just kidding, i just read the instructions online and it said NOTHING about this, aquacraft should do something about this (replace it). Ya ready to run means charge batterys and go. Tough luck, best wishes
_____________________________
"Yes I am from CANADA!"
(in reply to robcaryh)
       Post #: 2
RE: Did your supervee brushless come this way? - 7/24/2008 4:33:42 AM
dicko
Status: offline
they should have been installed, ring aquacraft, they have good customer support.
The answer is always more power.
(in reply to quadracer111)
       Post #: 3
RE: Did your supervee brushless come this way? - 7/24/2008 4:37:27 AM
BACKEMF
Status: offline
Someone is going to get 50 lashes on that assembly line.
Give'm a ring they should help you out. Thats about the worse SV story I've heard. Sorry about your bad luck.
Ray Sch.
(in reply to dicko)
       Post #: 4
RE: Did your supervee brushless come this way? - 7/24/2008 4:40:01 AM
quadracer111
Status: offline
oh ya btw im sorry i wasnt that good of a help..
(in reply to BACKEMF)
       Post #: 5
RE: Did your supervee brushless come this way? - 7/24/2008 4:44:50 AM
robcaryh
Status: offline
Do they have email customer service? I cant find it on their site. I PM'd grimracer,hoping he can do something for me.Thanks guys,i was really hoping i wasnt a complete moron here lol
       Post #: 6
RE: Did your supervee brushless come this way? - 7/24/2008 4:53:19 AM
robcaryh
Status: offline
I just sent a mail to great planes,curious to see what they say.
       Post #: 7
RE: Did your supervee brushless come this way? - 7/24/2008 1:24:26 PM
ryan_t888
Status: offline
Did you recover the boat with batteries? Batteries aren't destroyed from water, you can dry them out and use them again. Did you tape the hatch shut?
Ryan
A theory may be so rich in descriptive possibilities that it can be made to fit any data. - P.J.L.
       Post #: 8
RE: Did your supervee brushless come this way? - 7/24/2008 3:21:06 PM
robcaryh
Status: offline
No the hatch wasnt taped shut,i wasnt racing and it was the first time in the water,i was just putting around with it,hit the throttle once and it started hopping and rolled. I know DC power sources like batteries usually arent affected by water,but these batteries now will not take a charge and are stuck at around 3.5 volts.
(in reply to ryan_t888)
       Post #: 9
RE: Did your supervee brushless come this way? - 7/24/2008 3:28:51 PM
ryan_t888
Status: offline
Water will create a short between the cells. This short is at a very low current and would take a while to drain packs. What packs are they?
Learn to use hatch tape, without it your hull will never be sealed.
Ryan
       Post #: 10
RE: Did your supervee brushless come this way? - 7/24/2008 4:27:48 PM
robcaryh
Status: offline
Duratrax 4200's. I didnt tape cause it was a first run,i wasnt racing and wasnt going to hit full throttle,this happened 75 feet out in the middle of the pond at about 50% throttle.
Whats the best tape to use anyway? any recommendations?
       Post #: 11
RE: Did your supervee brushless come this way? - 7/24/2008 4:35:32 PM
ryan_t888
Status: offline
If the boat sits in water the hatch is tapped. It will really save you a lot of trouble later whether you do 2mph or 35mph.
I use Clear Renfrew Hockey Tape
Oh, and try C/10 Charge for 16 hours. If that fails try hitting the packs at 6A. They should take a charge.
Ryan
< Message edited by ryan_t888 -- 7/24/2008 4:36:38 PM >
       Post #: 12
RE: Did your supervee brushless come this way? - 7/24/2008 5:22:35 PM
doby
Status: offline
The fact that it was the first run is no excuse not to tape the hatch,,,first runs are usually when things go wrong. Lesson learned.
Also RTR should, but does not always mean ready to run,,,,,always go over any RTR and look for things missing etc.
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
