newbie needs help with rx
Tower Hobbies
Logged in as Guest
  Printable Version
Spektrum DX3 - FULL SYSTEM!
Seller:  Erick Royer
Details:   $240.00   |  7/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> newbie needs help with rx
Page: [1]
Login
newbie needs help with rx - 7/24/2008 9:02:33 AM
trice0683
Status: offline
hi my receiver has a sensor with it that i think you mount to the bottom of the plane. can anyone tell me what this is and how it works. much thanks trent
       Post #: 1
RE: newbie needs help with rx - 7/24/2008 1:19:43 PM
SoCalSal
Status: offline
quote:
ORIGINAL: trice0683
How about telling us what type receiver you have???????????????? Give us a bit more information on what you have.
_____________________________
Let''s be open minded.... But not so open that your brain falls out
(in reply to trice0683)
       Post #: 2
RE: newbie needs help with rx - 7/24/2008 3:11:45 PM
BuschBarber
Status: online
I know that the Nextar ARF comes with an Auto Pilot. I have not played with it but I have used an FMA CoPilot. which I am told is similar.
You calibrate the Auto Pilot for the surrounding landscape and then set the sensitivity (gain). As you fly, it will force the aircraft back to Upright and Neutral. The higher the gain, the harder it is to force the aircraft off level.
It looks like a small kitchen cabinet knob.
Is that what you have?
(in reply to SoCalSal)
       Post #: 3
RE: newbie needs help with rx - 7/24/2008 7:15:35 PM
trice0683
Status: offline
yes this is exactly what i have. does it matter where i mount it on the bottom of the plane
(in reply to BuschBarber)
       Post #: 4
RE: newbie needs help with rx - 7/24/2008 8:53:06 PM
Rodney
Status: offline
Beware of these; if you are flying over water or sand they will give you big problems. In every case where we have had them, they were soon disconnected and thrown away as they caused more problems than they solved.
       Post #: 5
RE: newbie needs help with rx - 7/24/2008 9:25:36 PM
JohnBuckner
Status: online
If you are going to be working with a experianced and competant instructor/mentor then you will be asked to disconnect it.
If you are going to try to teach yourself then this device will make it worse and likely to contribute to your failure to acheve your goal.
John
"Keep your controllines tight"
(in reply to Rodney)
       Post #: 6
RE: newbie needs help with rx - 7/25/2008 4:56:01 AM
BuschBarber
Status: online
I do not think it matters where on the bottom you mount it. I have always seen it under the fuse, below the leading edge of the wing.
I do agree with the others that these devices can be somewhat of an aid, but can also fight you if the gain is too high. I found that I like to turn down the gain when landing as the device tries to keep you from turning on to final.
(in reply to JohnBuckner)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU1
