am i going to blow it up if i run this
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - Electric >> am i going to blow it up if i run this Page: [1]
Login
am i going to blow it up if i run this - 7/24/2008 6:11:03 PM
ormer
Status: offline
the motor is kb 4508xl 1700kv
the esc is also what was recomended a turnigy plush 100amp opto
and running 2x 3s 30c 5000mah lipos joined to run at 6 cells
going to run subsurface in a multi hull style boat it is about 36 inches long
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: am i going to blow it up if i run this - 7/24/2008 6:23:39 PM
quadracer111
Status: offline
I don't see a problem with it, but don't take my word, im new with this boating stuff...
_____________________________
"Yes I am from CANADA!"
(in reply to ormer)
       Post #: 2
RE: am i going to blow it up if i run this - 7/24/2008 6:25:03 PM
ryan_t888
Status: offline
The KB45 is very inefficient and will draw a ton of amps. If you run 6s, be sure to start with a very small prop as 6s would be well on the "hot" side for the boat pictured.
38 000RPM unloaded would be more suited to a hydro or rigger.
Ryan
A theory may be so rich in descriptive possibilities that it can be made to fit any data. - P.J.L.
(in reply to ormer)
       Post #: 3
RE: am i going to blow it up if i run this - 7/27/2008 10:35:40 PM
ormer
Status: offline
ok i ran this the other day on a 35x prop and yes went well before i had chance to try anything else well i was running my old lipos 2200 mah still 11.1 volts and lets say
i had sealed the boat well as when it opend and air got in there was small flames
(in reply to ryan_t888)
       Post #: 4
RE: am i going to blow it up if i run this - 7/28/2008 2:29:30 AM
ryan_t888
Status: offline
Why would you use 2200mAh cells on a high amp motor? 5000mAh minimum, 10 000mAh recommended with 25C.
Ryan
(in reply to ormer)
       Post #: 5
RE: am i going to blow it up if i run this - 7/28/2008 7:43:15 PM
ormer
Status: offline
i was wondering if you had any idea on what motor you would suggest in this boat ryan as you said it is pretty amp hungry
       Post #: 6
RE: am i going to blow it up if i run this - 7/28/2008 8:03:14 PM
ryan_t888
Status: offline
NEU 1521 2D
6s LiPo 5000mAh 25C
Ryan
(in reply to ormer)
       Post #: 7
RE: am i going to blow it up if i run this - 7/28/2008 8:49:15 PM
ormer
Status: offline
where do i find these motors and i cant find that one in particular and they also look prety expencive
       Post #: 8
RE: am i going to blow it up if i run this - 7/28/2008 9:49:04 PM
ryan_t888
Status: offline
THey can be ordered off of the Castle Creations site. If you want a more cost effective motor run a KB 45 motor. I'd recommending a lower kv. This will drop current consumption at a cost of speed.
Ryan
(in reply to ormer)
       Post #: 9
RE: am i going to blow it up if i run this - 7/29/2008 1:12:17 AM
j.m.
Status: offline
he already has a kb 45.
!Signature your in it put, this read to time the took you If
If the World didn''t suck, then we would just fall off.
       Post #: 10
RE: am i going to blow it up if i run this - 7/29/2008 1:38:13 AM
eboat
Status: offline
Get the kb45 10XL (1200KV) if you want to use the 6S lipo set up
I am using this in a 36" hydro with a X450/3 blade prop (getting 53MPH so far)
I have a 200 amp esc but when I recharge the lipos I am only drawing around 80 amp average
You should start with a smaller prop when you have a V hull and work your way up as it will draw more amps than the hydro
Click for fullsize
< Message edited by eboat -- 7/29/2008 1:40:03 AM >
(in reply to j.m.)
       Post #: 11
RE: am i going to blow it up if i run this - 7/29/2008 1:40:45 AM
ryan_t888
Status: offline
quote:
ORIGINAL: j.m.
I understand but it's not the most ideal wind for a mono.
Ryan
(in reply to j.m.)
       Post #: 12
RE: am i going to blow it up if i run this - 7/29/2008 1:49:55 AM
j.m.
Status: offline
maybe a gear drive could fix his problem. It might be cheaper than a new motor.
       Post #: 13
RE: am i going to blow it up if i run this - 7/29/2008 2:36:56 AM
ryan_t888
Status: offline
I wouldn't want to put this kind of power through gears. That would be a headache.
Ryan
(in reply to j.m.)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
