Help with the Clutch Bell
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Help with the Clutch Bell
Page: [1] 2   next >   >>
Login
Help with the Clutch Bell - 7/24/2008 11:43:19 PM
r\c justin
Status: offline
HElp can't figure it out!!
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 1
RE: Help with the Clutch Bell - 7/24/2008 11:50:49 PM
Kodiac400
Status: online
the parts look to be in the right order. what seems to be the problem?
(in reply to r\c justin)
       Post #: 2
RE: Help with the Clutch Bell - 7/24/2008 11:57:44 PM
Kodiac400
Status: online
the only thing different from you setup and mine is I have 2 extra washers.
(in reply to Kodiac400)
       Post #: 3
RE: Help with the Clutch Bell - 7/25/2008 12:01:40 AM
r\c justin
Status: offline
it jumps forward alot didn't want it to mess my spurs up ill get a pic before and after the pics are before after before after
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 4
RE: Help with the Clutch Bell - 7/25/2008 1:27:01 AM
Encaged Rage 22
Status: offline
hey ive got the same problem i went to ace and found sum washers but when i tightin it up the clutch bell wont turn. ****???
       Post #: 5
RE: Help with the Clutch Bell - 7/25/2008 1:27:44 AM
stagga
Status: offline
u probably have the same issue i did lol. just get a small washer and put it after the outside washer but before the other small washers...make sure it can go around the shaft
       Post #: 6
RE: Help with the Clutch Bell - 7/25/2008 1:28:58 AM
Encaged Rage 22
Status: offline
       Post #: 7
RE: Help with the Clutch Bell - 7/25/2008 1:37:04 AM
stagga
Status: offline
u need a washer small enough to fit inside like the bearings...but the hole in the middle big enough to fit around the shaft like the bearings
(in reply to Encaged Rage 22)
       Post #: 8
RE: Help with the Clutch Bell - 7/25/2008 1:40:33 AM
r\c justin
Status: offline
i just set mine up like i had it just got done runining about 3 tanks through it seems to be fine what ever i did to my car made it drift so much better
i have the hop up kit, with that clutch bell and unlocked my diff.. it drifts way better and heck of alot faster!!
< Message edited by r\c justin -- 7/25/2008 1:41:28 AM >
(in reply to stagga)
       Post #: 9
RE: Help with the Clutch Bell - 7/25/2008 1:47:37 AM
stagga
Status: offline
whats unlockin ur diff do? or lockin it? whats stock? lol locked or unlocked
       Post #: 10
RE: Help with the Clutch Bell - 7/25/2008 2:09:21 AM
Encaged Rage 22
Status: offline
i just got bored and took apart the chewed up tranny i had and found a small washer that would fit. Im back to runin again. YES!!!!
       Post #: 11
RE: Help with the Clutch Bell - 7/25/2008 5:54:58 AM
tihstae
Status: offline
stock your diff is unlocked, that why the wheels turn seperate ways when the car is off. When you lock the diff it makes it so that both wheels have to turn exactly the same, but when the diff is unlocked one wheel can spin with the other stopped. locking the diff is good for drifting, so you slide better because both wheels are turning. but when its locked its handing is worse because one wheel cant turn faster than the other when turning.
       Post #: 12
RE: Help with the Clutch Bell - 7/25/2008 1:43:41 PM
r\c justin
Status: offline
well i locked my diff.. couldn't control it as good as it being unlocked!! here soon pic after comeing back from the strip club
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to tihstae)
       Post #: 13
RE: Help with the Clutch Bell - 7/25/2008 3:54:03 PM
stagga
Status: offline
looks good, need some pics with the new body on it!. so they only gave u 3 alu suspension arms? lol
       Post #: 14
RE: Help with the Clutch Bell - 7/25/2008 4:23:39 PM
r\c justin
Status: offline
yea ha the other ones on the way.. yea i got to do little more work to the exhast body doesn't fit to well with the just hangin out like that and trying to get my s2000 body finished up maybe tonight?? trying to find better way for holding the muffler in this Sh*t hole of a town i am working in ,its hard to get supplies...
       Post #: 15
RE: Help with the Clutch Bell - 7/25/2008 8:31:32 PM
tihstae
Status: offline
justin where did you get those pieces to re-route your air filter? and what did you use for your exhaust?
