Carb question
Tower Hobbies
Logged in as Guest
  Printable Version
3W 3W 150i B2 F QS COMPETITION SERIES - RTR
Seller:  rodnei
Details:   $1,180.00   |  11/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Carb question
Page: [1]
Login
Carb question - 7/30/2008 5:40:41 AM
MetallicaJunkie
Status: online
I have a ST 51 that has the HS need valve on the left side, and throttle lever on the right like all traditional 2 stroked i have ever used, is it possible to switch it around to where i could have the throttle arm on the left and hsn on the right, in other words can i rotate it 180 degrees and still have it function properly? It would make setting up a whole lot easier?
< Message edited by MetallicaJunkie -- 7/30/2008 6:22:48 AM >
_____________________________
Freestyle Junkie
Revver Bro #217
       Post #: 1
RE: Carb question - 7/30/2008 5:50:17 AM
rainedave
Status: online
The problem with Super Tigre carbs is that if you rotate the needle/spraybar assembly so that the fuel nipple is pointing back (like it is right now) you will also rotate the cat's eye slit in the spraybar. This will more than likely mess up your midrange. I guess you could leave the fuel nipple pointing forward, but the tubing would have to loop around in the front.
In my photo, the brass colored piece that the fuel nipple is attached to is also attached to the spraybar. Rotating it rotates the spraybar. ST's can be finicky about their spraybar orientation, so you don't want to change it from how it looks in my photo.
David
Click to see fullsize image.
Click for fullsize
(in reply to MetallicaJunkie)
       Post #: 2
RE: Carb question - 7/30/2008 6:21:22 AM
MetallicaJunkie
Status: online
ohhh, i didnt think about the spray bar issue, im glad i asked...... ill see if its managable to use the carb with the fuel nipple pointing forward, its on a profile airplane so it might just work. Thankyou Dave
Freestyle Junkie
Revver Bro #217
(in reply to rainedave)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU3
