Midwest T6 Texan gas engine?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Midwest T6 Texan gas engine?
Page: [1]
Login
Midwest T6 Texan gas engine? - 8/5/2008 1:22 AM
JohnVH
Score: 160
Last Login: 6/13/2013
Status: offline
Ok, I have this beautiful flite metal bird, it has a ST 2300 glow in it, Im tired of the glow, I love gas, simple, cheap, fun. NOW, Im running an 18x8 prop on this thing, it is far from overpowered, I need similar or better power on it with a gas engine, and I want it to fit inside the cowl, is it possible?
Ive seen alot using a G38, but hacking up the cowl on the bottom, any advice?
Thank you!
_____________________________
[quote]ORIGINAL: jefflangton
Time to bend over and let your head pop out!!!![/quote]
Hide Signatures
       Post #: 1
RE: Midwest T6 Texan gas engine? - 8/5/2008 4:23 AM
warks62
Score: 110
Last Login: 6/14/2013
Status: offline
You might check out the new Evo 40CC very compact. A Brison 2.4 is also a compact motor it has a shorter cylinder.
http://www.horizonhobby.com/Products/Default.aspx?ProdID=EVOE40GX
< Message edited by warks62 -- 8/5/2008 4:26 AM >
Randy, Enjoying Warbirds
Hide Signatures
(in reply to JohnVH)
       Post #: 2
RE: Midwest T6 Texan gas engine? - 8/5/2008 4:34 AM
All Day Dan
Score: 156
Last Login: 6/18/2013
Status: offline
If you want reliability try a Brison 3.2. They will swing a Zinger 20X10 with ease. I have three of them and they are great. If fitting within the cowl is an issue, The 2.4 could fit a little better. I have used Zinger 18X10 with them with great performance. My engines are muffled and I et arounf 7400 on the ground for a slightly rich run. I will try to up load some pdf files so you can see if they will fit. Dan.
Click to see the file in new window.Attachment.pdf Click to see the file in new window.Attachment.pdf Click to see the file in new window.Attachment.pdf Click to see the file in new window.Attachment.pdf
Dan
Hide Signatures
       Post #: 3
RE: Midwest T6 Texan gas engine? - 8/11/2008 11:20 PM
JohnVH
Score: 160
Status: offline
Ok, I did some measuring, the 2.4 and 3.2 brisons will not fit inside the cowl, maybe no gas engine will? Anyone out there done it?
Hide Signatures
(in reply to All Day Dan)
       Post #: 4
RE: Midwest T6 Texan gas engine? - 8/12/2008 4:38 AM
All Day Dan
Score: 156
Status: offline
It's too bad they don't fit. You're missing out on some great engines. Not much shows if you have to do some cutting at the bottom of the cowl because of an inverted engine. If you can't find anything that fits give the Brisons a try. Dan.
Dan
Hide Signatures
       Post #: 5
RE: Midwest T6 Texan gas engine? - 8/12/2008 4:48 AM
All Day Dan
Score: 156
Status: offline
Here are a couple of images of a 3.2 that I used in a Hughes Racer. It was pretty painful cutting away the cowl I had just got done making but I had to clear the engine. It also helps with cooling and carburator performance. Maybe you can get some ideas after seeing this. Dan.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Dan
Hide Signatures
       Post #: 6
RE: Midwest T6 Texan gas engine? - 8/12/2008 7:46 AM
Chad Veich
Score: 275
Status: online
quote:
ORIGINAL: JohnVH
If you give me a few days I can tell you if the Evolution 35 will fit in the cowl. My Midwest T-6 is getting an OS 1.60 but I do have the Evo laying around and can see how it fits the T-6 cowl. The Evo is pretty compact so it just may go.
Chad
Hide Signatures
       Post #: 7
RE: Midwest T6 Texan gas engine? - 6/13/2012 10:03 PM
JohnVH
Score: 160
Status: offline
revisiting, like a lightweight RELIABLE gas powerplant for this thing, thoughts? Thought about electric too, but a warbird being electric is just a crime. Maybe a DLE30?
Hide Signatures
(in reply to Chad Veich)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
