RE: RCGF Engines    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: RCGF Engines
Page: <<   < prev  199 200 [201] 202 203 204 205 206 207 208   next >   >>
Login
RE: RCGF Engines - 9/12/2010 10:14 AM
TestPilot6
Score: 100
Last Login: 11/8/2011
Status: offline
aussiesteve,
Thank you very much for the useful info plus extra.
Hide Signatures
(in reply to aussiesteve)
       Post #: 5001
RE: RCGF Engines - 9/22/2010 10:06 PM
Falcon32
Score: 105
Last Login: 5/15/2013
Status: offline
Hi aussiesteve
I got myself a helicoil kit but I'm afraid I've made a bit of a mess of it.
OK it was getting dark and I was tired but that's no excuse.
I drilled out the one hole and that was OK but I messed up on the other one and drilled all the way through the insulator block.
No one to blame it was my fault, does that mean I have to get a new one??
Falcon
_____________________________
I’d rather be twiddling my thumbs.
Hide Signatures
       Post #: 5002
RE: RCGF Engines - 9/23/2010 12:47 AM
fhm101
Score: 100
Last Login: 10/17/2010
Status: offline
If the hole is the correct size, why not install the helicoil, then insert a greased bolt and fill (from the back side) the remainder of the hole with some kind of good epoxy like this
http://www.jamestowndistributors.com/userportal/show_product.do?pid=7899
I've used this stuff and it performs as advertised.
Hi, I'm FHM and I suffer from terminal tinkeritus.
Hide Signatures
(in reply to Falcon32)
       Post #: 5003
RE: RCGF Engines - 9/23/2010 3:49 PM
aussiesteve
Score: 216
Last Login: 5/29/2012
Status: offline
Hey Falcon32
Don't sweat it dude.
You could just use the block with the hole all the way through. The bolt should seal it just fine.
If you are worried, Do as fhm101 suggested. If you can't find the exact product he linked to, there is most likely a similar product at you local bearing / automotive store (possibly the same place you got the helicoil from).
If you use a bolt to space out the hole, Make sure it goes a little further into the the block than it would when the engine is assembled.
3W, BME and DA all the way. Proven power, Proven reliability and Proven support equals much cheaper in the long term.
Hide Signatures
(in reply to fhm101)
       Post #: 5004
RE: RCGF Engines - 9/23/2010 10:50 PM
Falcon32
Score: 105
Status: offline
Hey Guys
Great news I had visions of trying to get a new one on a slow boat from China
Even better news I just found that epoxy available at Amazon here in the UK
Falcon
Hide Signatures
       Post #: 5005
RE: RCGF Engines - 9/24/2010 11:01 PM
Falcon32
Score: 105
Status: offline
Just realised that product is from a U.S.A. seller and shipping would be about 4 times the cost of the epoxy
I did find this one though available here, do you think it would work?
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 5006
RE: RCGF Engines - 9/24/2010 11:43 PM
cold_reboot
Score: 102
Last Login: 4/12/2013
Status: offline
I don't see where the JB would be insufficient. Uncle once used it to repair a rather large hole in a busted magnesium clutch cover on a CR80 Dirt Bike. The repair outlasted the rest of the motorcycle. If it'll stand up to that kind of heat and abuse, pretty sure your little airplane engine wouldn't cause it any stress. I actually use the stuff quite a bit in place of solder on metal to metal connections (because I'm woefully terrible with soldering)
Sig 4*40, GP Corsair, TF P47D, P40, Spitfire. Future Projects: Ty Brown''s ME109 84", Dave Anderson TA152
Hide Signatures
       Post #: 5007
RE: RCGF Engines - 9/28/2010 4:34 PM
jaless
Score: 100
Last Login: 11/8/2012
Status: offline
Does anyone know what Walbro carb to use with an RCGF 26cc?
Sorry to ask this but for the life of me I cannot easily find the answer.
Joe
Joe from Howell, MI
Hide Signatures
(in reply to cold_reboot)
       Post #: 5008
RE: RCGF Engines - 9/28/2010 9:59 PM
v8mini
Score: 103
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: jaless
Joe
i also would like to know what Walbro should be used on the RCGF 15cc
thanks Si
Hide Signatures
(in reply to jaless)
       Post #: 5009
RE: RCGF Engines - 10/17/2010 6:26 PM
billhass
Score: 100
Last Login: 5/3/2013
Status: offline
Jaless
I have a SPE 26 that has a WT 433 on it .
the orginal Carb was a WT 419.
The WT 433 works a lot better.
I was swinging a18x10 prop a 6900 rpms
Bill H
William C Hassell
Hide Signatures
(in reply to v8mini)
       Post #: 5010
RE: RCGF Engines - 10/18/2010 5:04 AM
93octane
Score: 105
Last Login: 4/14/2013
Status: offline
I used a WA 190 carb on my RCGF 15cc made a BIG difference! Try it if you can find one.....
Hide Signatures
       Post #: 5011
RE: RCGF Engines - 10/18/2010 7:30 PM
MAJOR SPLAT
Score: 100
Last Login: 8/26/2012
Status: offline
The question is whats wrong with the carb it comes with I have a RCGF 15,20,26,45 and 50cc and they have all been fine what issues are you having that makes you buy another carb?.
Regards
Major
Hide Signatures
(in reply to 93octane)
       Post #: 5012
RE: RCGF Engines - 10/18/2010 11:57 PM
93octane
Score: 105
Status: offline
quote:
ORIGINAL: MAJOR SPLAT
Regards
Major
[/quote I guess the carbs that come stock are ok..but are copies of the walbro...My 15cc ran ok for a while then would not draw fuel well , hard to start, poor transistion, then would not take full throttle no matter where the needles were, seemed a little restrictive also. I had a couple of 190 walbros and tried one..works very well with better power and rpm, I guess some are ok and some are not.
Hide Signatures
(in reply to MAJOR SPLAT)
       Post #: 5013
RE: RCGF Engines - 10/19/2010 2:17 AM
v8mini
Score: 103
Status: offline
Regards
Major
the carb on my RCGF 15cc would never run right from new and i found the high end needle had snapped off in the carb, supplier wouldn't take any responsibility saying i must have screwed it in too far... not the case. so i have had to buy another at an extra cost to me and would have preferred to have got a walbro not another bad copy
Hide Signatures
       Post #: 5014
RE: RCGF Engines - 10/19/2010 2:31 AM
laryboy
Score: 100
Status: offline
how about you guys list what real walbro can go on what engines. i had a20 cc that the carb corroded so bad i could not free the choke
Hide Signatures
       Post #: 5015
RE: RCGF Engines - 10/19/2010 3:21 AM
aussiesteve
Score: 216
Status: offline
quote:
ORIGINAL: laryboy
Easy to do
RCGF 15cc Carb - replace with one attached to a JBA 15cc
RCGF 20cc Carb - replace with carb attached to DLE 20cc
RCGF 26cc Carb - Replace with one attached to a DLE 30
RCGF 45cc Carb - Replace with one attached to a CRRC 50
RCGF 50cc Carb - Replace with one attached to a CRRC 50
RCGF 55cc Carb - replace with one attached to a DLE 55
RCGF 62cc Carb - replace with one attached to a DLE 55
RCGF 100cc Carb - replace with one atached to a DLE110
RCGF 110cc Carb - replace with one attached to a DLE110
RCGF 150cc Carb - replace with one attached to a DA150
Preferably whilst the replacements are still attached to their original engines
I give this one about 30 minutes
Hide Signatures
(in reply to laryboy)
       Post #: 5016
RE: RCGF Engines - 10/19/2010 3:27 AM
93octane
Score: 105
Status: offline
quote:
ORIGINAL: aussiesteve
quote:
ORIGINAL: laryboy
Easy to do
I'm guessing you dont care for RCGF engines
Hide Signatures
       Post #: 5017
RE: RCGF Engines - 10/19/2010 3:41 AM
Super08
Score: 135
Last Login: 5/17/2013
Status: offline
LMAO Steve!
Quote: Hey, who put that tree there?
Ultra Sport brotherhood #125
Hide Signatures
       Post #: 5018
aussiesteve
Score: 216
Status: offline
quote:
ORIGINAL: 93octane
Used to - then I dealt with them.
The percentage of them with major defects that they sent me was well in excess of 25%
When I orderd parts to fix them (At my own cost - I had given up on ever expecting the factory to support me) they abused me, Made up a bunch of lies about me then stopped talking to me altogehter. Still have that e-mail chain - it makes for entertaining reading as their rep tried to wiggle out of supplying parts (mainly because there are so many variations of the engines that they wouldn't know what they supplied and to whom).
Meanwhile they had given many other distributorships to people in my "sole distributorship" area (I guess they got confused with the fish)
Despite the efforts of some of the new distributors to show otherwise, they are still the same horse as always.
Now I use much better products (not frmo China - In fact, I don't even fly any of the alternatives I posted - but they are in a similar price range). Cost a bit more to start but the cost per flying hour is way less. Stress levels are much better too.
Hide Signatures
       Post #: 5019
RE: RCGF Engines - 10/19/2010 3:56 AM  1 votes
93octane
Score: 105
Status: offline
quote:
ORIGINAL: 93octane
Meanwhile they had given many other distributorships to people in my ''sole distributorship'' area (I guess they got confused with the fish)
Well I can see your point...I had no idea it was so difficult to get parts in Australia...I have no problem on the east coast of USA
Hide Signatures
       Post #: 5020
RE: RCGF Engines - 10/19/2010 5:43 AM
aussiesteve
Score: 216
Status: offline
quote:
ORIGINAL: 93octane
Luckily most don't need to bother with parts as they are a throw away product anyway.
Just wait until you do need parts and get supplied with parts for a different version to what you have - or even better, a reduction in quality (I am not going to mention things like prop hubs or carb blocks here - oops - already did ). Or when you get told that those parts are not available to you (or they just refuse to reply at all)
Time will show you what I refer to.
I learnt my lesson the hard way in dealing with this factory, sometimes those can be the best lessons learnt.
Unfortunately there are some great guys still dealing with the brand and some of them do try very hard to support the product. My prediction is that they will get burnt in the not too distant future as history has a way of repeating itself. Heck, one of those good guys even has been known to tell people that their engine isn't worth fixing "because the parts will be too expensive". If only those guys were aligned with a better company, they would be truly world beaters in the service delivery area.
Have a close look at the early parts of this thread (and others) - I WAS one of the guys who tried to make it work. I now know better and i am not alone in that knowledge.
Hide Signatures
       Post #: 5021
RE: RCGF Engines - 10/20/2010 3:32 AM
rcflyinmike
Score: 100
Last Login: 3/1/2013
Status: offline
OK you guys got me a little concerned, I see this an old forum and hopefully rcgf  has rifined their products.  I just finished a Nosen 106" Citabria, My first 1/4 scale and my first gasser. Im trying to get the initial 2500 rpm run in for my rcgf 20cc  and I can only get it to sputter a little bit.  Does anyone know What the plug gap be set at? Also I'm using 89 oct. Help!! Please.
Buy Build Crash Cry Repeat, Fun!!
Hide Signatures
       Post #: 5022
RE: RCGF Engines - 10/20/2010 3:45 AM
mesaflyer
Score: 120
Last Login: 5/8/2013
Status: offline
"Preferably whilst the replacements are still attached to their original engines "
Now that's funny!
I'm just keeping an eye on this thread because I have an RCGF 20cc rear carb that I bought from Henry.
Had issues at first, but runs great now, knock on wood.
Funny part is that I was e-mailing Henry for his help. He suggested what was wrong (not a big enough hole in the cowl, so the engine was not getting enough air) right off the bat, but I just did not believe him.
After cutting a larger hole in the cowl (and smacking myself upside the head), the engine runs great. Thanks Henry.
Hide Signatures
       Post #: 5023
RE: RCGF Engines - 10/20/2010 3:49 AM
aussiesteve
Score: 216
Status: offline
quote:
ORIGINAL: rcflyinmike
OK you guys got me a little concerned, I see this an old forum and hopefully rcgf  has rifined their products.  I just finished a Nosen 106'' Citabria, My first 1/4 scale and my first gasser. Im trying to get the initial 2500 rpm run in for my rcgf 20cc  and I can only get it to sputter a little bit.  Does anyone know What the plug gap be set at? Also I'm using 89 oct. Help!! Please.
Not really but here is some info that might help you
1 - Plug Gap - 0.020" (0.5mm) - the same thickness as a #11 Hobby blade
2 - Check your timing is set at 28 - 30 degrees BTDC. The easiest way to do this is to find TDC, make a pencil (or scriber) mark across the hub and extend it to the crankcase - then measure the hub diameter and multiply that by 0.244 - that distance is how far before TDC the ignition should fire - make a mark there for future reference too (a bit like the old timing marks on a car engine)
3 - Check your needles are set at 1 3/4 turns out on both
If it isn't one of those 3 things, you will need to do some further investigation - there are many things that it could be. Feel free to PM me if you have more problems.
89 Oct should be fine - mix it at the recommended ratio for the oil you are using (I use 40:1 Redline from day one - others use 25:1 mineral or 32:1 Pennzoil Air cooled - there are other choices too).
Hide Signatures
(in reply to rcflyinmike)
       Post #: 5024
RE: RCGF Engines - 10/23/2010 2:21 PM
rcflyinmike
Score: 100
Status: offline
Turns out  the low speed needle valve was bent right out of the box. I sent the engine back to  B P Hobbies  for a replacement. Thanks for the help!!
Hide Signatures
       Post #: 5025
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: RCGF Engines
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.156RCU1
