RE: RCGF Engines    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: RCGF Engines
Page: <<   < prev  213 214 [215] 216 217 218 219 220 221 222   next >   >>
Login
RE: RCGF Engines - 8/15/2011 9:39 PM
goirish
Last Login: 5/18/2013
Status: offline
what should the spark plug be gaped at? Is there a certain kind of plug that I should buy? I got the dang thing so messed up now. Why don't we leave well enough alone. Just have to keep fooling with it. That little miss just bothered the heck out of me. Now I can't get it to go over 5000. I took the plug out and it is dark in color, which would indicate to me that it is rich. Is the HSN the one farthest way of the engine body. I don't have any manual so I shooting in the dark. I'm about to put one of my 4 strokes on it. The plug has a gap on it of .020, is that close? I am using ultra full synthetic at 50:1 by stihl.
_____________________________
DX-7,RDS8000. big Bingo,1/4 Scale Cub, SeaMaster 120, Forget the health food, I need all the preservatives I can get
Hide Signatures
(in reply to karolh)
       Post #: 5351
littlera
Last Login: 5/3/2013
Status: offline
Speaking of throttle curves (and lack of sensitivity of throttle when nearing wide open throttle) this treatise I did last year may be of some value for those wanting to do it electronically instead of fiddling with the geometry of throttle arm / servo arm.
http://www.rcuniverse.com/forum/m_10062619/anchors_10062619/mpage_1/key_/anchor/tm.htm#10062619
Cheers,
littlera
AMA #386
Hide Signatures
(in reply to ahicks)
       Post #: 5352
RE: RCGF Engines - 8/15/2011 10:44 PM
mjohnst3
Last Login: 5/15/2013
Status: offline
Hey goirish,
Thats the right gap, 0.018-0.020, the CM6 NGK is a good plug. The electrode coming out of the plug should look like below nice light whitish tan and clean. Set you needles back to factory setting LSN is closets to the engine HSN is away. Start your engine and let it warm up a couple of min, then using a tach go to 2000 rpm set the low speed needle to peak rpm , then go full throttle using tach and set peak rpm idle back to 2000rpm check for peak rpm then throttle up full and check peak rpm. Now let the engine cool off about 15-20 min and check it again. As the engine breaks in you will need to do this about 2 more times. Also these engine don not respond to needle movement like nitro engines you may need to burp the throttle a little during tuning. The oil your using is good stuff but for break in you should be at 40:1.
Here is a good read for new gasser people, it helped me lots.
http://www.rcuniverse.com/forum/m_8673009/anchors_8673009/mpage_1/key_/anchor/tm.htm#8673009
Mark
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to goirish)
       Post #: 5353
RE: RCGF Engines - 8/15/2011 11:51 PM
RJConnet
Last Login: 5/17/2013
Status: offline
p51tom,
The prop bolt in my RCGF 45 is drilled and tapped for a 5mm spinner bolt. A 10-32 bolt will screw in but is very sloppy and should not be used. The Tru-Turn spinner on my Extra is not nearly as long as your P51 prop spinner is and I found a 5mm bolt long enough at a local Ace Hardware store. Good luck finding one long enough for you P51..............RJ
Hide Signatures
(in reply to p51tom)
       Post #: 5354
RE: RCGF Engines - 8/16/2011 12:37 AM
ahicks
Status: offline
quote:
ORIGINAL: karolh
quote:
ORIGINAL: gringopete
I'll see if I can answer a couple of questions here.
Jim at Agape Racing and hobby has the timing wheel. http://www.agaperacingandhobby.com/
 Hope this helps everyone in the tuning and troubleshooting their engines. The following applies to just about any engine that uses a Walbro type carb.
Try changing the plug. If that does not work here is the easiest way to set the needles on the engines.
1) Start by turning out both the high and low needles 1 5/8 to 1 3/4 turns.
2) Go full throttle and peak the high end with the high speed needle valve. When the engine sags you have gone too far. Back the needle off 1 hour or 1/12 of at turn.
3) Go full throttle and peak the engine using the low speed needle valve. When the engine sags back off the low end needle 1 hour or 1/12 of a turn. That’s right peak the engine using the low end needle. The reason for this is that the engine gets fuel from both needles once the engine comes off of idle.
4) Bring the engine down to idle. Adjust the low end rpm idle with the trim on your transmitter. The engine should not need any adjustment at this point.
The engine at this point should be almost perfect. It should transition from low to High speed without any burps. If the engine does not run good after this setup look for an air leek, bad reed valve or carb diaphragm.
I never tried this method of engine tuning, but will give it a try and see how it all pans out. Guess there is some truth in the saying, '' more ways than one to skin a cat or tune an engine ''
Karol
X2! Different, but I can see the logic. Will have to try it as well. -Al
Hide Signatures
       Post #: 5355
RE: RCGF Engines - 8/16/2011 1:58 AM
Captmicom
Status: offline
Very Good Point Gregg...
Captmicom
Captmicom...
RCGF Service Certer USA*Southwest AeroVista Hobbies*Team AV Pro-(We sponsor IMAC Kids)*520-508-7371
Hide Signatures
(in reply to gringopete)
       Post #: 5356
RE: RCGF Engines - 8/16/2011 2:12 AM
Captmicom
Status: offline
That is reasonable.... any where in the 7k range is good because it will unload in the air by 500 to 800 RPM depending on the prop you are running.
Captmicom
Captmicom...
Hide Signatures
       Post #: 5357
RE: RCGF Engines - 8/16/2011 2:48 AM
goirish
Status: offline
I will try again tomorrow. If I get it close this time I'm gonna leave it alone
Hide Signatures
(in reply to Captmicom)
       Post #: 5358
RE: RCGF Engines - 8/16/2011 11:56 AM
Aug
Last Login: 4/23/2013
Status: offline
I got my 26cc RCGF engine from BP Hobbies and put it on a Seagull Laser 200. I'm very happy with the engine and the support I got from BP Hobbies.
http://www.bphobbies.com/view.asp?id=V815101
I will always remember 9-11
Hide Signatures
(in reply to SunShyne)
       Post #: 5359
RE: RCGF Engines - 8/16/2011 1:09 PM
gringopete
Last Login: 5/6/2013
Status: offline
P51Tom
We have the long spinner bolts that you are looking for. Here is the link
http://www.bphobbies.com/view.asp?id=E1294667
Gregg
Gregg P
Hide Signatures
(in reply to Aug)
       Post #: 5360
RE: RCGF Engines - 8/16/2011 1:12 PM
gringopete
Status: offline
Goirish
send me an email with your address and i'll send you the manual for your engine.
Gregg
Gregg P
Hide Signatures
       Post #: 5361
RE: RCGF Engines - 8/16/2011 2:11 PM
karolh
Status: offline
quote:
ORIGINAL: Captmicom
Captmicom
It is not unsual for some small capacity gas engines to unload as much as 1,500 + rpm in the air.
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
       Post #: 5362
RE: RCGF Engines - 8/17/2011 3:48 AM
rfk1381
Status: offline
Greg,
Thanks for the tuning technique!
Question - in steps 2 and 3, can you please explain, "1 hour or 1/12 of a turn", which seems like a text format error that happened when posted.
Thanks...Ron
Hide Signatures
       Post #: 5363
RE: RCGF Engines - 8/17/2011 4:01 AM
karolh
Status: offline
quote:
ORIGINAL: rfk1381
Greg,
Question - in steps 2 and 3, can you please explain, ''1 hour or 1/12 of a turn'', which seems like a text format error that happened when posted.
Thanks...Ron
Adjusting the high or low needles by "1 hour or 1/12 of a turn" also means 5 mins. of the hour hand or 5 sec. of the second hand on the clock face.
Karol
Hide Signatures
(in reply to rfk1381)
       Post #: 5364
RE: RCGF Engines - 8/17/2011 4:47 AM
p51tom
Last Login: 5/14/2013
Status: offline
I decided to tap the shaft for a 6mm bolt and use a 6mmx1.0x110mm bolt from Bolt Depot. They do not carry 5mm bolts that long. Thank you BP Hobbies but your 5mm bolts are too short. I will let everyone know how things work out. This Don Brown 5" P51 spinner needs a bolt about 4.25" long. Bolt Depot on the InterNet has a great assortment of hardware and does not require a minimum order.
Thanks everyone, P51Tom
Hide Signatures
       Post #: 5365
RE: RCGF Engines - 8/17/2011 5:26 AM
rfk1381
Status: offline
I learn something new every day, even at my doddering old age!
Hide Signatures
       Post #: 5366
RE: RCGF Engines - 8/17/2011 4:07 PM
mesaflyer
Last Login: 5/8/2013
Status: offline
quote:
ORIGINAL: p51tom
I decided to tap the shaft for a 6mm bolt and use a 6mmx1.0x110mm bolt from Bolt Depot. They do not carry 5mm bolts that long. Thank you BP Hobbies but your 5mm bolts are too short. I will let everyone know how things work out. This Don Brown 5'' P51 spinner needs a bolt about 4.25'' long. Bolt Depot on the InterNet has a great assortment of hardware and does not require a minimum order.
I don't know for sure, but I thought that I read on here somewhere that the shafts on these motors have been heat treated and hardened, so it might be pretty tough going to drill and tap. Just a thought. I could be wrong.
I would like to know how it works out for you.
Hide Signatures
       Post #: 5367
RE: RCGF Engines - 8/17/2011 4:25 PM
Captmicom
Status: offline
You are right about the cranks but most of these engines have a prop bolt or shaft that is softer and can be drilled.
Captmicom
Captmicom...
Hide Signatures
(in reply to mesaflyer)
       Post #: 5368
RE: RCGF Engines - 8/17/2011 10:59 PM
acerc
Status: online
Got some more run time in today. This little engine just blows me away. Had to replace the fish scale, found to be inaccurate. 18x8 @ 7000+ rpm's and 14lbs of thrust. The plane only weight's 16.5
SWEEEEEET!
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 5369
RE: RCGF Engines - 8/18/2011 2:06 PM
raydar
Last Login: 5/9/2013
Status: offline
Rcg 20 beam mount 16 3 8 graupner prop 7400 rpm and 11.6 lbs thrust,
Had extended my throttle arm and adjusted my servo arm position to help with the throttle curve (huge difference) so even with full end points on the radio I was only 95 % thottle open but this does not mean much, the 16 3 8 graupner is to much for this engine.
Remarkably with the big prop and having more control over the idle with the trim button the engine would idle at 1400 rpm! Though I dont think I would be comfortable leaving it that low.
This is not totally bad news for me though as the reason im trying 3 blade props is a ground clearance issue with a skybolt kit im building with this engine, will try a grapner 15 3 8 when I get one.
Click for fullsize
Hide Signatures
(in reply to acerc)
       Post #: 5370
RE: RCGF Engines - 8/18/2011 8:52 PM
p51tom
Status: offline
I discovered that a 6mm bolt would require drilling the spinner hole out. I do not feel it has enough room so I need to use 5mm bolt. Because I have not been able to find a 5mmx.8x110 I decided to make my own. I used a 90mm and a 25mm bolt and sodered them together to get the proper length. I taped a section of brass tubing screwed the bolt in from each end then sodered them. Because the bolt is used to only hold on the cone I think it will be strong enough. Any ideas out there?
Have a good day, P51Tom
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to raydar)
       Post #: 5371
RE: RCGF Engines - 8/18/2011 9:33 PM
gringopete
Status: offline
P51tom
follow this link to Mcmaster Car they have what you are looking for. http://www.mcmaster.com/#socket-head-cap-screws/=dodezw.
Gregg
Gregg P
Hide Signatures
       Post #: 5372
RE: RCGF Engines - 8/19/2011 3:24 PM
p51tom
Status: offline
Thank you Greg, I put my order in today. I bought this 45cc engine from BP Hobbies. I have 7 RCGF Engines and I am very happy with them. My P51 is three years old and I am replacing the ST 3250 with the 45cc. I love the way it fits in this plane. I will be buying 3 more 45cc rear carb in the near future.
Click for fullsize
Hide Signatures
       Post #: 5373
RE: RCGF Engines - 8/19/2011 3:36 PM
p51tom
Status: offline
I will be running my RCGF 45cc in my TFGS P51 soon and need to make a decision on the prop size. The plane has been flown over the past few years with a 18x10 Zinger on a ST3250 engine. I am planning on using a 20x8 Zinger on the 45cc. Is this the correct prop to break in the engine or should I use a 20x10?
Have good day, P51Tom
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 5374
RE: RCGF Engines - 8/19/2011 4:11 PM
gringopete
Status: offline
Tom
McMaster -Car is here in Jersey you should have it by Monday , maybe tomorrow.
Use a 20x8 prop for break in.
Gregg P
Hide Signatures
       Post #: 5375
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: RCGF Engines
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.266RCU1
