RE: RCGF Engines    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: RCGF Engines
Page: <<   < prev  228 229 230 231 [232] 233 234 235 236 237   next >   >>
Login
RE: RCGF Engines - 4/19/2012 5:50 AM
Captmicom
Score: 105
Last Login: 5/15/2013
Status: offline
Don't feel too picked on.. We have all messed up like that at least once.... When you are ready for another RCGF just give BP or me a call we got your back..
Captmicom
_____________________________
Captmicom...
RCGF Service Certer USA*Southwest AeroVista Hobbies*Team AV Pro-(We sponsor IMAC Kids)*520-508-7371
Hide Signatures
(in reply to oneaew@msn.com)
       Post #: 5776
RE: RCGF Engines - 4/19/2012 2:19 PM
gringopete
Score: 100
Last Login: 5/6/2013
Status: offline
I agree with Capmitcom.
Gregg
Gregg P
Hide Signatures
(in reply to Captmicom)
       Post #: 5777
RE: RCGF Engines - 4/19/2012 2:32 PM
sgrady
Score: 100
Last Login: 5/14/2013
Status: offline
Just bought the twin 50CC, it looks good, look forward to firing it soon.  I agree dealer is the issue.
Hide Signatures
(in reply to gringopete)
       Post #: 5778
RE: RCGF Engines - 4/19/2012 6:21 PM
VF84sluggo
Score: 345
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: ahicks
Guys expecting customer service from Hobby King, well they're gamblers, or about to get an education...
That's the way you have to look at buying from HK. It may work out, it may not.
For me, I've been pretty lucky with HK, but I always understand that when buying at HK, I am operating under the old adage, "You pays your money, you takes your chances!"
JetCat P100-RX
Kingtech K60G
Hide Signatures
(in reply to ahicks)
       Post #: 5779
RE: RCGF Engines - 4/19/2012 10:08 PM
Heli-NuBee
Score: 100
Status: offline
I was not sucessful in figuring out why my RCGF 45 engine would not run well. I finally gave up and sent it into Joe Nelso for a lookie loo. Maybe he can sort out the problem.
Hide Signatures
(in reply to VF84sluggo)
       Post #: 5780
RE: RCGF Engines - 4/19/2012 10:44 PM
Captmicom
Score: 105
Status: offline
I will do my best to make it spit fire again.....!
Captmicom...
Hide Signatures
(in reply to Heli-NuBee)
       Post #: 5781
RE: RCGF Engines - 4/20/2012 2:14 PM
gringopete
Score: 100
Status: offline
Sounds like the crankcase is leaking air. The best thing to do is dissasemble the engine and put it back together with good RTV.
Gregg P
Hide Signatures
       Post #: 5782
RE: RCGF Engines - 4/20/2012 4:31 PM
sailr
Score: 100
Last Login: 5/21/2013
Status: offline
What prop(s) are suggested for the RCGF 20CC? BP Hobbies site gives a rediculous range! 15x6, 16x6, 17x8, 18x8? Which do you feel would be best for engine longevity? I have the engine installed on a 58" bipe. Not sure of the weight but probably around 8 lbs.
Thanks!
< Message edited by sailr -- 4/20/2012 5:05 PM >
President of Mini Cat Racing USA
Manufacturer of Fast Electric Boats
Hide Signatures
       Post #: 5783
RE: RCGF Engines - 4/20/2012 4:42 PM
Captmicom
Score: 105
Status: offline
That is what I am thinking too.... It's one of the older "Henry" 45s. I get it apart as soon as it gets here and get it fixed for him.
Captmicom...
Hide Signatures
       Post #: 5784
RE: RCGF Engines - 4/20/2012 5:07 PM
Captmicom
Score: 105
Status: offline
15x6 will give you 9500 rpm on the ground
16x6 will give you 9000 rpm on the ground
18x8 should give you about 7600 to maybe 8000 on the ground depending on the prop.
It is all about whant you want to do with the engine. It is best for the life and performance of the engine to prop it so you don't go much over 9500 rpm unloaded in the air. You can usually count on the engine unloading between 500 to 1000 rpm once it gets in the air again depending on the prop you put on it (i.e. Xoar, Zinger, Master Air screw and so on). I hope this helps some.
Captmicom...
Hide Signatures
(in reply to sailr)
       Post #: 5785
RE: RCGF Engines - 4/20/2012 6:07 PM
sailr
Score: 100
Status: offline
quote:
ORIGINAL: Captmicom
Thanks! Great info. Much appreciated. Do you have a website? I checked your profile but the site listed there is 404 not found.
Hide Signatures
       Post #: 5786
RE: RCGF Engines - 4/20/2012 9:24 PM
raydar
Score: 142
Last Login: 5/23/2013
Status: offline
If its the latest 20cc the xoar 17 6 wooden prop gives the best performance with that engine, you should get between 8200 and 8400 with that prop static, bringing the engine right into its power band.
Hide Signatures
(in reply to sailr)
       Post #: 5787
RE: RCGF Engines - 4/20/2012 11:17 PM
sailr
Score: 100
Status: offline
Great! Thanks for that info
Hide Signatures
(in reply to raydar)
       Post #: 5788
RE: RCGF Engines - 4/20/2012 11:36 PM
Captmicom
Score: 105
Status: offline
Sorry about the web site.... I put the http:// on and the blog was putting it on too.
Captmicom...
Hide Signatures
(in reply to sailr)
       Post #: 5789
RE: RCGF Engines - 4/23/2012 12:30 AM
Heli-NuBee
Score: 100
Status: offline
Joe sent me an e-mail indicating he received my RCGF 45 engine. He said it was one of the old monsters and I may not recognize it when it comes home. I sure hope he can fix it, I would love to fly my Great Plans Giant Super Sportster again.
Hide Signatures
       Post #: 5790
RE: RCGF Engines - 4/23/2012 12:48 AM
oneaew@msn.com
Score: 122
Status: online
sure wish some one could help me get my rcg 15cc back from china they have had it 4 months now no word yet gotit from hobby king
Hide Signatures
       Post #: 5791
RE: RCGF Engines - 4/23/2012 1:32 AM
sailr
Score: 100
Status: offline
quote:
ORIGINAL: Captmicom
Whatever, it still doesn't work for me. Never mind.
Hide Signatures
       Post #: 5792
RE: RCGF Engines - 4/23/2012 1:51 AM
acerc
Score: 221
Status: offline
Try clicking on this, go ahead, put your mouse over the blue and click    http://www.swaerovista.com/
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to sailr)
       Post #: 5793
RE: RCGF Engines - 5/6/2012 10:46 PM
Captmicom
Score: 105
Status: offline
Hey Big "R",
I got Good News and Bad News.........
I guess I will go with the Bad News first... I can't get the cases or jug to seal well enough to get the darn thing to draw fuel.
All of the decks are warped. The Good News is... I can't get the thing to seal and draw fuel..!! Remember when I told you that you might not recognize it when you got it back? I am going to have to rebuild the bottom end with new cases crank and so on. I hope that you were not in love with that one "BIG" bolt that you were holding the prop on with because it will be gone most likely. I don't think that I can make it work on the new RCGF cases and crank. I will use what I can off your engine. So stay tuned I will get back to you next week end.
Captmicom...
Hide Signatures
       Post #: 5794
RE: RCGF Engines - 5/23/2012 10:11 PM
Heli-NuBee
Score: 100
Status: offline
Hey Guys,
I sent my RCGF 45 to Joe Nelson after I gave up on trying to make it run. As you can see by Joe's posts, the engine was beyond repair and he had to pretty much just replace it. I bench ran the new engine yesterday for the first time and I gotta tell ya that it is awsome! It runs like a Swiss Watch, great idle, fast acceleration and a good solid full throttle run. I was hoping to have a maiden flight report for you today but the weather just would not cooperate. We have 40 MPH winds with a storm comming in and it will be several days before the weather clears. My hats is off to Joe Nelson and RCGF for the support of their products. I had less that six flights on that engine before it went south but I have also had it for some time. I believe that Joe and RCGF went above and beyond where most other Companies would do to support their products. I can't say thank you enough to Joe for his support.
Roger
Hide Signatures
       Post #: 5795
RE: RCGF Engines - 5/30/2012 9:43 PM
Heli-NuBee
Score: 100
Status: offline
I finally had a chance to get that maiden flight in with my new RCGF 45 engine on my GP Giant Super Sportster. The performance was good, great, wonderful, super, awesome, fantastic & stupendous!!! I just can't say how neat is was to get my Super Sportster into the air again after such a long struggle with the old engine. Again I will say, I just don't know any other mfg. that would step up to the plate like Joe Nelson and RCGF did. That is the best customer service I have seen anywhere. Joe certainly made a believer out of me.
Roger Anderson
Hide Signatures
       Post #: 5796
RE: RCGF Engines - 5/30/2012 9:51 PM
Heli-NuBee
Score: 100
Status: offline
Here are some pictures of my RCGF 45 powered GP Giant Super Sportster that I enjoyed flying so much today thanks to Joe Nelson and RCGF.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 5797
RE: RCGF Engines - 5/30/2012 10:54 PM
Captmicom
Score: 105
Status: offline
Hey Big "R",
I still think that is a GREAT looking plane.... Now I want one.. Nice job.
Captmicom...
Hide Signatures
       Post #: 5798
RE: RCGF Engines - 6/6/2012 11:39 PM
Captmicom
Score: 105
Status: offline
Hey Gang!!
My new RCGF 60cc twin showed up for me to start the Beta Testing on this afternoon!! It is a great looking little twin. I will pust pics as soon as I can so you all can see what it looks like......!!!
Captmicom...
Hide Signatures
       Post #: 5799
RE: RCGF Engines - 6/6/2012 11:41 PM
Captmicom
Score: 105
Status: offline
Let Me try this again....
Hey Gang!!
My new RCGF 60cc twin showed up for me to start the Beta Testing on this afternoon!! It is a great looking little twin. I will post pics as soon as I can so you all can see what it looks like......!!!
Captmicom...
Hide Signatures
       Post #: 5800
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: RCGF Engines
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
