RE: RCGF Engines    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: RCGF Engines
Page: <<   < prev  228 229 230 231 232 233 [234] 235 236 237   next >   >>
Login
RE: RCGF Engines - 12/7/2012 6:45 AM
Captmicom
Score: 105
Last Login: 5/15/2013
Status: offline
Hey Marvin,
If you have a NAPA auto parts you can also look and see is they might have any of these model numbers.
Denso #U20M-U ( This is a Great plug)
AC Delco M8
Champion Y82
Motorcraft BT8
Any of these will be an NGK CM6 look alike....
Kind Regards,
_____________________________
Captmicom...
RCGF Service Certer USA*Southwest AeroVista Hobbies*Team AV Pro-(We sponsor IMAC Kids)*520-508-7371
Hide Signatures
(in reply to MarvinLoomis)
       Post #: 5826
RE: RCGF Engines - 12/7/2012 6:49 AM
apalsson
Score: 168
Status: offline
With the Denso plug probably the best one of the ones on the list
quote:
ORIGINAL: Captmicom
Hey Marvin,
AC Delco M8
Champion Y82
Motorcraft BT8
Kind Regards,
MVVS Australia
MVVS Engines, Mejzlik Props, Accessories.
www.mvvs-australia.com.au
Hide Signatures
(in reply to Captmicom)
       Post #: 5827
RE: RCGF Engines - 12/7/2012 12:05 PM
Bpar4
Score: 105
Last Login: 5/19/2013
Status: offline
Don't forget the Honda folks. Good stuff. Bob
Hide Signatures
       Post #: 5828
RE: RCGF Engines - 12/7/2012 2:44 PM
nextofkin
Score: 100
Last Login: 5/18/2013
Status: offline
O'Riley Autoparts will sale you one thay may have to order it but the price is cheeper than other places that you might buy more than one.
nextofkin
Hide Signatures
(in reply to Bpar4)
       Post #: 5829
RE: RCGF Engines - 12/8/2012 12:47 AM
MarvinLoomis
Score: 100
Status: offline
Thanks guys, have tried any brands that they might handle, but wouldn't order or sell less that standard package. I'll give O'Relly a try have one a few miles away.
Hide Signatures
(in reply to nextofkin)
       Post #: 5830
RE: RCGF Engines - 12/9/2012 9:59 PM
MarvinLoomis
Score: 100
Status: offline
Lordy, lordy I found my problem!! The hall sensor lead that runs back up under the mount into the fuselage had come partially unplugged. I had the plastic keeper on the lead, but apparently was just enough slack that it was not plugged in tightly. Hope this might help some of you other guys with similar problems. I'm suprised that is would run at all, but apparently makeing enough contact to fire and then with vibration started breaking down.
Marv
Hide Signatures
       Post #: 5831
RE: RCGF Engines - 12/12/2012 3:14 AM
captinjohn
Score: 247
Status: offline
You can get CM 6  or a Desnso spark plug at Advanced Auto.  Call ahead...if they do not have one they get them quick and at fair prices.  I Even got a NGK ME8 1/4x32 sparkplug from them. They had to order it, but got it in 2 days.   Regards    Capt,n
Click to see fullsize image.
Click for fullsize
I never met a engine I did not like !
Hide Signatures
       Post #: 5832
RE: RCGF Engines - 12/27/2012 5:42 PM
thevirginian
Score: 100
Last Login: 4/25/2013
Status: offline
I bought a RCGF 50 with rear carb from Raves.com. Left it in the box for about a year or so, because my damaged Wildhare Honda Sukhoi was not ready yet. After the repairs were done I installed the new RCGF 50 in her nose replacing my good old reliable DL-50. When I first fired up the motor it ran terribly. It sputtered and wouldn't respond to the throttle. I put another carb on it, same result. I started to think I bought me a piece of junk. Then I found out mt MPI- Miracle switch was causing ingniton problems by cutting off intermittently. After fixing that issue the motor ran fine. As a matter of fact, it runs better than my old DL-50 and has definitely more power. I am still breaking it in, but with every new tank I can feel the great power this motor has. So far I am very pleased with it considering what I paid for it. Unfortunately I cannot find this particular motor anymore on Rave's website. Only Hobbyking advertises it as a RCG 50. I wonder if this is the same motor, because it truely could be the DLE-killer, as they say.
Hide Signatures
(in reply to captinjohn)
       Post #: 5833
RE: RCGF Engines - 12/27/2012 5:58 PM
Captmicom
Score: 105
Status: offline
If it is an RCGF 50cc engine it is at least 3+ years old. I have not been able to get a 50cc single from the factory for over three years now. I can't even get replacement parts for them.
I have heard that there was some very old RCGF stock floating around but I can't verify that. What did the box it came in look like? Let me know and I can tell you what you have.
Captmicom...
Hide Signatures
(in reply to thevirginian)
       Post #: 5834
RE: RCGF Engines - 12/27/2012 7:18 PM
raydar
Score: 142
Last Login: 5/9/2013
Status: offline
http://www.youtube.com/watch?feature=player_embedded&v=P5Ip61DQlt4
Thats a video taken today of my  hobbyking RCG 50 with a xoar 23 8 carbon running slightly rich,  only a gallon through her and I have not touched the needles since the second tank with another prop. The RCG 50 from hobbyking is actually a 55cc.  It has the RCGF 55 crank, head and piston. Dont think she is a DLE beater but is not far off it.
Dont have a RCGF 55 but if I did I bet it would be a great motor.
Hide Signatures
       Post #: 5835
RE: RCGF Engines - 12/28/2012 4:04 PM
thevirginian
Score: 100
Status: offline
I tried to upload a picture of my RCGF 50, but it gives me a "500-Internal Error" message. It is basically the same motor Hobbyking sells for $206.00. As I said, I bought it about a year ago from Rave's. It came in a blue box.
Hide Signatures
(in reply to raydar)
       Post #: 5836
RE: RCGF Engines - 12/28/2012 8:15 PM
Captmicom
Score: 105
Status: offline
Ok if it was a blue box with the nose of a YAK-54 on one side and the 50cc engine on the other it is an RCGF 50cc. They made two models back in the day, if it is a cast case it would be an "A" model and if it was a CNC case it would be a "B" model.
Kind Regards,
Captmicom...
Hide Signatures
       Post #: 5837
RE: RCGF Engines - 12/31/2012 9:45 PM
thevirginian
Score: 100
Status: offline
That's the one I have. Must be the A-model
Hide Signatures
       Post #: 5838
RE: RCGF Engines - 12/31/2012 9:46 PM
thevirginian
Score: 100
Status: offline
Picture didn't upload. Try again.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 5839
RE: RCGF Engines - 12/31/2012 9:55 PM
Captmicom
Score: 105
Status: offline
Yup....That is the 50cc "A" Model if it came out of that blue box...
Captmicom...
Hide Signatures
       Post #: 5840
RE: RCGF Engines - 1/1/2013 2:43 PM
thevirginian
Score: 100
Status: offline
BP Hobbies out of NJ show this engine on their website for $307.00. In case I need parts, what's the best place to call?
Hide Signatures
       Post #: 5841
RE: RCGF Engines - 1/1/2013 3:41 PM  1 votes
ahicks
Score: 669
Status: offline
Check out Captmicom's signature. I think you'll likely see he's the second source for parts? Both good sources, and both support their product on this website.
Hide Signatures
       Post #: 5842
RE: RCGF Engines - 1/1/2013 3:46 PM
Captmicom
Score: 105
Status: offline
Good Point. Gregg may still have some NOS on this engine. I would call Gregg at BP Hobbies and see if he has what you need. If he does not have what the part you need then your only choice for this engine would be Hobby King. But Try Gregg First.
Captmicom...
Hide Signatures
       Post #: 5843
RE: RCGF Engines - 1/1/2013 4:38 PM
Captmicom
Score: 105
Status: offline
Thanx AHicks. I have not been able to get new replacement parts for the 50cc single engines from RCGF for some time now. I just used up the last of my NOS parts to repair a 50cc "A" model engine for a flyer in Ca. So I am taped out right now. As I said Gregg may have some still. If not we can probably find the left over parts elsewhere (aka) Hobby King or I still have contacts at SV Group that may still make parts for this particular engine.
SIDE NOTE: If I have mentioned this before sorry for the repeat! I have had a lot of repair work lately on engines that have set for a while with fuel in the carb. Some of this repair work might be avoided by running your engine "DRY" after you drain your fuel at the end of your flying day. Remember that the gas we have had to use for some time now has at least 10% alcohol/methanol in it and sometime more. The carb parts that were made to run with gas don't like this much and will go bad faster when left exposed to this fuel combo. This is also the reason we can't get much more than about 6 to 8 months out of our standard Tygon fuel line before it gets stiff and hard. We have developed fuel line and tank stoppers that are better suited to today's fuels but the carb parts are a much harder build.
Captmicom...
Hide Signatures
       Post #: 5844
RE: RCGF Engines - 1/2/2013 6:49 PM
thevirginian
Score: 100
Status: offline
Thanks captmicom. Hopefully I will not need any parts (soon), if this engine performs nearly as good, as my good ol' trusty DL-50 did. So far, so good. After about five years of usage I just put a new seal kit in my DL's Walbro-carb. Other tan that, the motor shows no signs of aging. Still running strong.
Hide Signatures
       Post #: 5845
RE: RCGF Engines - 1/2/2013 8:12 PM
Captmicom
Score: 105
Status: offline
Cool just keep them flying...
Captmicom...
Hide Signatures
       Post #: 5846
RE: RCGF Engines - 1/22/2013 3:30 PM
DaleD
Score: 105
Status: offline
Can anyone tell me which Walbro carb would be appropriate to use on the RCGF15? Would the WT793A work?
DaleD
Hide Signatures
       Post #: 5847
RE: RCGF Engines - 1/22/2013 3:39 PM
Lifer
Score: 148
Status: offline
The carb for the DLE 20 works quite well on the RCGF 15cc.
Hide Signatures
(in reply to DaleD)
       Post #: 5848
RE: RCGF Engines - 1/22/2013 4:10 PM
DaleD
Score: 105
Status: offline
quote:
ORIGINAL: Lifer
Thanks a million for your response.  I was thinking of getting a Walbro because my DLE30 carb eventually starting acting up and nothing I did would correct the issues.  Can you recommend a Walbro?
DaleD
Hide Signatures
(in reply to Lifer)
       Post #: 5849
RE: RCGF Engines - 1/22/2013 7:07 PM
Lifer
Score: 148
Status: offline
I like to run carbs the next size up. I think the bolt pattern for the 55 is the same......
Hide Signatures
(in reply to DaleD)
       Post #: 5850
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: RCGF Engines
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.812RCU1
