RE: RCGF Engines    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: RCGF Engines
Page: <<   < prev  226 227 [228] 229 230 231 232 233 234 235   next >   >>
Login
RE: RCGF Engines - 12/8/2011 4:58 PM
Lifer
Score: 153
Last Login: 6/19/2013
Status: offline
Consider a pair of DLE 20's instead. More power and fewer problems. IMO.
Hide Signatures
(in reply to Whistling Death)
       Post #: 5676
RE: RCGF Engines - 12/8/2011 10:17 PM
aussiesteve
Score: 216
Last Login: 5/29/2012
Status: offline
quote:
ORIGINAL: Lifer
Ain't that a fact. The DLE 20 is one of the most powerful (for it's size) and compact of any of the small gassers so far from the far east.
_____________________________
3W, BME and DA all the way. Proven power, Proven reliability and Proven support equals much cheaper in the long term.
Hide Signatures
(in reply to Lifer)
       Post #: 5677
RE: RCGF Engines - 12/8/2011 11:34 PM
Lifer
Score: 153
Status: offline
And they are light compared to other engines of that size.
Hide Signatures
(in reply to aussiesteve)
       Post #: 5678
RE: RCGF Engines - 12/23/2011 10:22 AM
steph18
Score: 100
Last Login: 4/24/2013
Status: offline
hi guy's
is someone use the RCGF 32 ?
what do you think of the use of tuned pipe on this engine ?
stephane
Hide Signatures
(in reply to Lifer)
       Post #: 5679
RE: RCGF Engines - 12/23/2011 1:22 PM
Captmicom
Score: 105
Last Login: 5/15/2013
Status: offline
Hi Stephane,
The RCGF 32cc is a very good all around engine. I have three of them on planes. A Big Ugly Stik 80” wing span, a Howard DGA-12 95” wing span, and 26% YAK-54 73” wing span. In all three planes the power is off the chart. The Stik and YAK have unlimited vertical and both will hover at less than half throttle and the Howard flies scale at about 40% throttle with a 22/8 prop. I have many happy customers using these powerful little engines. That is my two cents for what it is worth.
Kind Regards,
Captmicom
Captmicom...
RCGF Service Certer USA*Southwest AeroVista Hobbies*Team AV Pro-(We sponsor IMAC Kids)*520-508-7371
Hide Signatures
(in reply to steph18)
       Post #: 5680
RE: RCGF Engines - 12/23/2011 10:33 PM
steph18
Score: 100
Status: offline
thanks for your ansewr Capmicom,
in your opinion, is the 20x10,5 APC prop can be ru by this engine with or without tuned pipe ?
for me the objective is to run it over 7000rpm
stephane
Hide Signatures
(in reply to Captmicom)
       Post #: 5681
RE: RCGF Engines - 1/8/2012 2:57 AM
Captmicom
Score: 105
Status: offline
Sorry for getting back to you so late! It was nuts around here over Christmas. I was off so I went flying every day from 6 a.m. to 4 or 5 p.m. Now to answer your question. Yes the RCGF 32cc can turn your APC prop but I do not like APCs on gas engines. They are very dangerous to begin with and they are not that efficient. I would us something like a Xoar wood prop 18x10, 20x8 or 20x10 depending on how you are going to fly the plane.
Captmicom...
Hide Signatures
       Post #: 5682
RE: RCGF Engines - 1/8/2012 3:07 AM
Captmicom
Score: 105
Status: offline
Hi Everyone,
Happy New Year!!! I have a favor to ask you guys that I have done engine work for over the past year. My records computer tanked last week so if it would not be to much of an inconvenience could you “PM me with your name, engine size, and serial number so I can re-input it into the new computer. I would greatly appreciate it.
Thanks in advance,
Captmicom
Captmicom...
Hide Signatures
       Post #: 5683
RE: RCGF Engines - 1/8/2012 6:35 PM
steph18
Score: 100
Status: offline
thanks for your answer,
as i have some time i do mesurement of these prop. and you can see the results on the following table :
as i have few time yet I done orther measurements :
the used tuned pipe is this used on the webra 145AAR.
I think it is very interesting because I only have SP95 for the RCGF and there is 30% of nitro for all the the tested YS
stephane
Hide Signatures
       Post #: 5684
RE: RCGF Engines - 1/15/2012 7:29 PM
acerc
Score: 221
Status: offline
Here's another one of these sweet little engine's. Sig clipped wing, RCGF 26cc with J-Tec pipe. Started as expected- five flip's pop, choke off - one flip start. Gotta love it.
Click to see fullsize image.
Click for fullsize
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 5685
RE: RCGF Engines - 1/24/2012 5:37 PM
Oupagryse
Score: 100
Last Login: 7/8/2012
Status: offline
Hi Steph,
Could you please show the dyno that you used to test the engine? I'm busy designing my own and it would help a lot.
Regards
Gerrit-Jan
Hide Signatures
       Post #: 5686
RE: RCGF Engines - 1/24/2012 9:13 PM
steph18
Score: 100
Status: offline
hello Gerrit-Jan
here one part of my post in RC pattern flying
about measurement realized on YS engines : I take measurement of rpm that all members of the forum post on RC universe and on F3A.fr. it is interested to see that all measures was realized with APC propellers and it is more simple for me because it reduces  drasticlly the number of prop to caracterize in power. for RCGF and webra I used my own measures because I have these engines at homre. after you must know one thing : when your engine runs a prop the power absorbed by the propeller is eqaul to the power provided by the engine, so if you measure the curve power of your prop it becomes easy to determinate the power of all engine just by knowing the dimension of the prop and its rpm.  and you can write :  where N is the RPM  and D the prop diameter and gamma the power coefficient of the prop.
stephane
PS : sorry for my english, I am no native english
Hide Signatures
(in reply to Oupagryse)
       Post #: 5687
RE: RCGF Engines - 1/30/2012 9:02 PM
yurdakut
Score: 100
Last Login: 4/7/2013
Status: offline
dear friends I m trying to read this thread as fast as I can do..so if this was answered before sorry for your time...I m planning to make  seagull edge 540-60+rcgf gas engine.. so its weight is 8.4-8.8 lbs(3.8-4 kg) including engine and all accesories flying weight is almost 10 lbs(5 kg)..I wanna fly 3D should I buy rcgf 20 cc?26 cc?or 30 cc?? as far as I know 20 cc is not enough but on the other hand 30 cc will be too heavy wht about the 26 cc I need your experinences, informations and advices..thank you for your interest..
Hide Signatures
       Post #: 5688
RE: RCGF Engines - 1/31/2012 12:51 AM
ahicks
Score: 669
Status: offline
quote:
ORIGINAL: yurdakut
If you are looking to do/learn 3D, I would find another plane. At 750 sq. in. of wing area and 10lbs, it would be way low on wing area. Something that weight needs to have 950 minimum, or better yet over 1000 sq in. It might make a decent sport plane, but you will have to keep your air speeds up, and it may snap a little too easily?
Backing off to something the weight of a DLE 20 will save you 8 oz. That would be a step in the right direction, but still not to the point where you'll be able to do much in the way of those maneuvers where the plane really has to "float".
If you just want something that might hover, you might be OK? My opinion, FWIW.
Hide Signatures
(in reply to yurdakut)
       Post #: 5689
RE: RCGF Engines - 1/31/2012 8:26 AM
yurdakut
Score: 100
Status: offline
quote:
ORIGINAL: ahicks
quote:
ORIGINAL: yurdakut
first of all thank you..which plane do you offer me?for example I m flying about 7-8 months with profile katana 46 61 magnum..I m flying not completely 3D but I m forwarding day by day..so I thought extra 260/90, extra  300 s and edge 540/60 I like edge..I have many modeller friends in other cities flying with rcgf and they are happy with them but as I wrote up seagull edge is close 10 lbs(5 kg) as a result of this I m confused..I read seGULL edge 540/60+dle 20 combo in other forums and they are happy..I want to know which is better  rcgf 20 cc or 26 cc?or which combo do you offer?on the other hand in other forums som pilots think that 26 cc class is not cost/force/torque effective its not so stronger that seems..I hope I could explain wht I mean..thank you again..
Hide Signatures
(in reply to ahicks)
       Post #: 5690
RE: RCGF Engines - 1/31/2012 12:52 PM
ahicks
Score: 669
Status: offline
quote:
ORIGINAL: yurdakut
quote:
ORIGINAL: ahicks
quote:
ORIGINAL: yurdakut
Backing off to something the weight of a DLE 20 will save you 8 oz. That would be a step in the right direction, but still not to the point where you'll be able to do much in the way of those maneuvers where the plane really has to ''float''.
Here is a sample of what I'm thinking of when considering something that might work well for a 26cc powered 3D plane. Please don't focus on this plane only as there are more like it built by other manyfacturers and sold by different suppliers. The H9 Funtana would be another example that just came to me.
http://www.troybuiltmodels.com/items/GWRACERE540-030V3BAF.html
Wingspan 75.2"(1910mm)
Length 73"(1860mm)
Wing Area 1026sq in(66.2sq dm)
Flying Weight 9.7-11lbs(4400g-5000g)
Regarding an RCGF 20cc, it would be a similar plane, just scaled down. 750 sq in is still on the small side if the plane weighs 10lbs. It would have to weigh something closer to 8lbs for that amount of wing area? Large 1.20 size planes, in the 8-10 lb class would be what you're looking for. The Funtana specifications actually work here as well.... though it would be on the larger side.
Not intending to say the plane you provided doesn't fly well. Saying it's not a good example of a 3D plane...
Hide Signatures
       Post #: 5691
RE: RCGF Engines - 1/31/2012 2:27 PM
Captmicom
Score: 105
Status: offline
Hey Guys,
Good call on the plane Ahicks. We sell the fire out of the 26% Gold Wing 30cc size planes. Those are planes in the 72” to 76” wing span range. My personal experience with the RCGF 26cc in planes this size is the 26cc has more than enough power to fly the plane and do scale aerobatics. While the RCGF 26cc engine can do the 3D in the 26% size planes it has to work harder to do it. Most of the guys flying 3D will step up to the 32cc engines power increase to put the plane over the top. The RCGF 32cc engine does not have to work as hard to do the 3D maneuvers and there is extra power to get you out trouble if you need it.That is my two cents for what its worth.
Captmicom
Captmicom...
Hide Signatures
       Post #: 5692
RE: RCGF Engines - 1/31/2012 2:46 PM
ahicks
Score: 669
Status: offline
quote:
ORIGINAL: Captmicom
Hey Guys,
Captmicom
I had an 26cc RCGF in a 10 lb Funtana, so I know about what to expect. There were no DLE 30's or RCGF 32's available at the time - so I thought it flew great! Certainly no trouble pulling out of a hover. Now though, I'm in total agreement with you. Especially if you don't already have an engine and are buying one for the purpose. 32cc on power to weight, or bucks spent for bang received, works out to be a much better plan.... Awesome how far we've come in just a couple of years!
Hide Signatures
       Post #: 5693
RE: RCGF Engines - 1/31/2012 3:00 PM
acerc
Score: 221
Status: offline
To anyone who has the 20cc beam mount. Could I get a measurement from the front of the mount to the rear of the carb.
Thank's
Robert
Hide Signatures
       Post #: 5694
RE: RCGF Engines - 1/31/2012 3:51 PM
Captmicom
Score: 105
Status: offline
Hey Rob,
From the front of the beam itself to just beyond the butterfly is 3 3/8” I would go to 3 ½” for air clearance. From the front of the prop hub to just beyond the butterfly is 5 3/8” again I would go to 5 ½” for the air clearance.
Captmicom
Captmicom...
Hide Signatures
(in reply to acerc)
       Post #: 5695
RE: RCGF Engines - 1/31/2012 4:21 PM
acerc
Score: 221
Status: offline
Thank you!
Robert
Hide Signatures
       Post #: 5696
RE: RCGF Engines - 1/31/2012 5:18 PM
Captmicom
Score: 105
Status: offline
You Are welcome!
Captmicom...
Hide Signatures
(in reply to acerc)
       Post #: 5697
RE: RCGF Engines - 1/31/2012 8:20 PM
yurdakut
Score: 100
Status: offline
quote:
ORIGINAL: ahicks
quote:
ORIGINAL: yurdakut
quote:
ORIGINAL: ahicks
quote:
ORIGINAL: yurdakut
Length 73"(1860mm)
ahicks do you mean "not a good example of a 3D plane"switching to gas engine model instead of nitro designed model?or different brand and you dont like seagull?
Hide Signatures
       Post #: 5698
RE: RCGF Engines - 1/31/2012 8:25 PM
yurdakut
Score: 100
Status: offline
quote:
ORIGINAL: Captmicom
Hey Guys,
Captmicom
Captmicom if I m not wrong you mean rcgf 26 cc is not as much as strong like 32 cc?I understand like that wht I wrote up..thank you
Hide Signatures
       Post #: 5699
RE: RCGF Engines - 1/31/2012 9:37 PM
ahicks
Score: 669
Status: offline
quote:
ORIGINAL: yurdakut
ahicks do you mean ''not a good example of a 3D plane''switching to gas engine model instead of nitro designed model?or different brand and you dont like seagull?
There's nothing wrong with Seagull models. That's not what I'm saying at all. What I'm saying is the plane you've chosen will not work as well as others you could choose from. The weight of the gas engine is too much for that airframe (20 or 26cc) - if you are looking for good 3D performance.
Hide Signatures
       Post #: 5700
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: RCGF Engines
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.270RCU1
